Date/Time: Tue, 21 May 2024 16:52:32 +0000
VIX download failure
View Count: 706
[2016-01-10 23:02:40] |
brown555 - Posts: 35 |
Interactive Brokers symbol VIX / SC symbol VIX-201601-CFE-USD / Continuous Futures Contract Volume Based rollover. December 4 is the last day SC loaded data. |
[2016-01-11 18:42:04] |
That is no longer the correct symbol to use with Interactive Brokers . The symbol needs to also contain the day of the month. Refer to the symbol format here: https://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Futures The continuous Futures Contract feature will also no longer work with that symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
