Date/Time: Sat, 18 May 2024 16:13:42 +0000
historical ticks charts
View Count: 676
[2015-12-12 16:56:17] |
User16558 - Posts: 5 |
Good morning, it's possible to see dax index historical ticks charts? I need to see 30 ticks charts. regards |
[2015-12-12 23:03:09] |
Yes, this is supported in Sierra Chart.
[2015-12-13 14:23:28] |
i've seen data from about september ...it's possible to have more historical data? If yes how can i do it? |
[2015-12-14 01:44:33] |
You need to pay for Sierra Chart usage time: https://www.sierrachart.com/usercp.php?page=SCUsageTimePayments Update Sierra Chart to the current version by following the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Do you require the Cash DAX futures DAX price data? For more data follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-14 15:33:00] |
It's better the futures DAX but if not possible it's ok the cash...it's possibile to download or buy ticks data from february or march 2015 ? Regards |
[2015-12-14 21:49:35] |
Therefore, use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service You will find the symbol in File >> Find Symbol >> Futures-Indices. The data is tick by tick. You will also want to use the Continuous Futures Contract feature: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-14 21:50:42
