Date/Time: Wed, 02 Jul 2025 00:19:24 +0000
Chartbook for Rockwell trading - Simple Day Trading Strategy
View Count: 1893
[2015-12-02 12:02:41]
User129630 - Posts: 22
I am reading this thread: https://www.sierrachart.com/supportboard/showthread.php?t=18542.
I am NOT able to get the chartbook at the following link as discussed in the thread:
We created a chartbook based on that video:
https://www.sierrachart.com/supportb...2&postcount=21
I am wondering if the chartbook is still available. Or is there some other issues?
Thanks,
Joseph
[2015-12-02 19:57:44]
Actually, please ignore the ask. I found out there is the Rockwell chartbook available as part of the Sierra Chart package.
Regards,
Joseph
Date Time Of Last Edit: 2015-12-02 19:58:03
[2015-12-02 21:53:19]
You can download the Rockwell Chartbook from here:
http://www.sierrachart.com/index.php?page=doc/AdditionalFiles.php
Let us know if it works properly for you.
[2023-01-20 20:39:40]
John M - Posts: 172
I realize this is an ancient thread but I wanted to look at the Rockwell chartbook.
Unfortunately, the only chart that appears is chart #1, none of the others are present.
Chart #1 even shows a study referenced in Chart #2 which is not present.
Has this been deleted or what?
Thank you.
[2023-01-20 22:32:24]
John - SC Support - Posts: 40702
The Rockwell chartbook only has 1 chart in it. So if you are able to see that one chart, then that is all there is.
We do not see any reference to another chart.
Make sure you are downloading the Rockwell Chartbook found in the Additional Files page here:
https://www.sierrachart.com/AdditionalFiles/Rockwell.cht
