Date/Time: Mon, 29 Apr 2024 17:32:28 +0000
Ellipse tool - radius incorrect
View Count: 738
[2015-11-28 11:07:55] |
ehlaban - Posts: 50 |
I've been looking at the ellipse tool and especially the option 2nd point is radius. I think this option is not implemented the right way. The 2nd point should be on the circumference of the circle as that defines the radius. I was really looking forward to this option and hope a correction will be made to correctly draw an ellipse or circle with the desired radius.
Radius.jpg / V - Attached On 2015-11-28 11:01:53 UTC - Size: 6.05 KB - 252 views sierra ellipse.png / V - Attached On 2015-11-28 11:06:31 UTC - Size: 50.3 KB - 284 views |
[2015-11-28 11:40:44] |
We cannot duplicate the behavior that you show in that chart image with the Ellipse tool . Update to the latest prerelease of Sierra Chart with Help >> Download Prerelease. Those new options do work correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-28 22:16:25
[2015-11-28 12:39:33] |
I redownloaded the new version and set the desired options as default. It now indeed works perfect!
