Date/Time: Mon, 06 May 2024 07:09:43 +0000
Switch to Sierra Charts
View Count: 861
[2015-11-27 17:14:28] |
User614036 - Posts: 3 |
Hello, I want to switch from Green Charts to Sierra Charts. How do I transfer my indicators and tools to do that?
[2015-11-27 17:46:45] |
You just need to use your own Sierra Chart account and log into Sierra Chart with that account. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-27 20:13:18] |
now that I downloaded the sierra charts and selected the data trade service setting, how do I copy all my previous saved charts to the new sierra charts?
[2015-11-27 21:23:41] |
The easiest thing to do is to start the Sierra Chart that is located in the C:\GreenChart\ folder and login using your own direct Account Name and Password following these instructions: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
