Date/Time: Sat, 04 May 2024 17:02:20 +0000
How do I correct a price misprint on overlain chart?
View Count: 676
[2015-11-20 14:00:46] |
trader1 - Posts: 128 |
Hi, On a chart that is overlain on my main chart there is a price misprint. How do I correct that? When I use edit data it tries to edit the main chart data even though I am clicking on the overlain chart region. Thanks. |
[2015-11-20 17:00:34] |
You need to go to the source chart you are overlaying and refer to the instructions in help topic 2: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-23 15:51:12] |
The data is correct in the source chart I am overlaying. The price misprint only appears in the overlain chart.
[2015-11-23 18:12:57] |
This does not make sense. We need to understand this better. Post an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
