Date/Time: Sun, 12 May 2024 06:43:25 +0000
Issue after upgrading to 1324.
View Count: 853
[2015-11-12 04:49:13] |
User204005 - Posts: 2 |
Hello support team. After upgrading to the latest version all my charts look like this. The Volume Weighted Rolling Moving Average is not calculating correctly anymore. I am using tick data per instructions. I am also using number of trades per bar for to create my bars. I had to rollback to version 1316 to correct this. When i change Base On Underlying Data to NO it corrects the problem but i want the more accurate moving average based on the instructions given and the way my charts were before. I have also been using this study from post 68 here: It has worked flawlessly with all new versions except this latest one. Orderflowanalytics-style reversal bars. thank you. http://www.sierrachart.com/image.php?l=144730354171.png Date Time Of Last Edit: 2015-11-12 04:57:44
[2015-11-12 04:54:03] |
OK we will check on this. There were some recent changes to that study.
[2015-11-12 13:57:59] |
Al SC Developer - Posts: 434 |
This is addressed in the next version.
[2015-11-18 18:54:10] |
Hi Al, I upgraded to version 1325 and my all my charts look like this still. Need to rollback again to correct the issues with the volume weighted rolling moving average. Has this been addressed yet? Thank you. http://www.sierrachart.com/image.php?l=1447872666692.png |
[2015-11-18 19:30:45] |
The change may not be in 1325. It may only be in the prerelease. Update to the latest prerelease with Help >> Download Prerelease. Also regarding this: I have also been using this study from post 68 here: It has worked flawlessly with all new versions except this latest one. Orderflowanalytics-style reversal bars. We are not sure what the issue is. The developer of those studies will need to look into it. If they have any questions for us they can ask us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
