Date/Time: Mon, 29 Apr 2024 00:58:47 +0000
Cocoa and sugar tick data
View Count: 1001
[2015-11-06 11:14:22] |
User757410 - Posts: 1 |
Hi, I began downloading daily bars and 100 (one hundred) tick bars data for cocoa (CC) and sugar (SB) beginning from contracts expiring May 2012. I have service package 3. There seems to be a problem with tick data in some contract months in 2012. Daily bars are ok for all contracts I think. For example, 100 tick bars for CCK12 (May 2012), CCN12 (July 2012) and CCU12 (September 2012) seem to be OK. However, 100 tick bars for CCZ12 (December 2012) seem to be very packed somehow. I tried re-downloading the data. Could the reason be that tick data for sugar and cocoa are only available beginning January 2013, or should I be able to download tick data for 2012? |
[2015-11-06 11:31:40] |
A quick check based on file size shows that tick by tick data does not go back earlier than CCN13. Previous to this, the data will be in 1 minute units. SB will be the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-06 11:32:26
