Date/Time: Thu, 10 Jul 2025 02:33:01 +0000
Parallel Rays
View Count: 1071
[2015-10-31 17:00:20] |
JRA - Posts: 97 |
Is there any setting to add alert, like on the ray line tool with left click menu "Alerts", on the Parallel Ray tool?
[2015-11-01 19:29:02] |
We will see about this. This is not currently supported.
[2015-11-25 04:32:02] |
Al SC Developer - Posts: 434 |
In the next version, parallel lines/rays will allow alerts to be set. Any alert that is set, will be active for all lines that make up the chart drawing.
[2023-08-17 19:49:31] |
User676363 - Posts: 83 |
May I continue this same topic regarding Parallel Rays/Lines? Can we please consider allowing the menu option "Make Line Parallel" and "Make Parallel to Previous" and also perhaps "Create Parallel Line" to work with the following? 1) Pitchforks 2) Parallel Lines 3) Parallel Rays I find that I cannot make align a pitchfork to a parallel line set. I also cannot align a parallel line set to a pitchfork. The line tool can be used and duplicated, but I would like to have some more flexibility and all of these tools might be better if they align, so to speak. Thank you. |
