Date/Time: Sat, 04 May 2024 22:41:04 +0000
SC Forex data and TradeAndCurrentQuoteSymbol
View Count: 676
[2015-10-19 15:21:21] |
jesslinn - Posts: 108 |
Thank you for adding support for the SC Forex Data in trading instances of SC. Can you verify that, unlike with the SC futures, it is necessary to set the "Trade and Current Quote Symbol", in order to actually trade SC forex symbols on IB? Is there a way to set up a symbol and trading symbol pair so that whenever the symbol is put in a chart (as via a link), that the trading symbol is also used? For example, I have a Quote Board (or an associated watch list) with many symbols and a set of linked trading windows. When I click on the QuoteBoard, the linked windows are now populated with the better SC forex data but I have to then manually add a trade symbol each time, or set up a separate DOM with the appropriate trade symbol. If there is not a way to do this, by editing the GlobalSymbolSettings.xml or some other way, I suppose I can write a custom study that will set the TradeAndCurrentQuoteSymbol, but I thought I would ask if there is a better way before taking such an ad hoc approach. |
[2015-10-19 23:40:14] |
Yes you will need to set the "Trade and Current Quote Symbol": http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TradeAndCurrentQuoteSymbol You can set that field through the Global Symbol Settings now: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
