Date/Time: Sun, 05 May 2024 11:06:22 +0000
SC Volume by price gives different results from other trading platforms.
View Count: 2349
[2015-10-15 15:14:08] |
User503358 - Posts: 50 |
My Volume by price results from SierraChart differ form other trading platforms volume by price results. Live results are identical, but little back are different. Somebody knows why? Somebody compare VBP results from different trading platforms?
Attachment Deleted. |
[2015-10-15 19:43:23] |
today's data
[2015-10-15 20:23:01] |
ganz - Posts: 1048 |
User503358 be careful using that "other trading platform" |
[2015-10-15 20:24:33] |
why?
[2015-10-15 20:31:33] |
User503358 these guys are not pedantic |
[2015-10-15 20:41:51] |
I don't have other way to check results.
[2015-10-16 01:42:58] |
We see you are using the Rithmic data feed. This is a good data feed. The historical data comes from the Sierra Chart Historical Data Service which is also good. You can trust results that you are getting. However, refer to the steps of information here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#VolumeProfileDifferences To make sure you have done everything you should to ensure the Volume Profiles are accurate. Some slight inaccuracies are inevitable due to CME packet loss when volumes are high. Percentagewise this would probably be .01% or less. Usually less. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-16 01:43:58
[2015-10-16 14:38:49] |
If You see 2 of 4 bars are identical. it means, that options are synchronized (time, time scale, price scale etc). If somebody could recheck my results, please post it here.
[2015-10-18 22:05:29] |
Last 30 minutes distribution: total volume exactly the same for every bar, price count for every bar is identical, but volume distribution between prices is differ. what do you suggest to check?
[2015-10-18 22:27:01] |
As long as you have a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php You can be assured that the volume of each price level is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-19 11:49:42] |
I connect to ES Rythmic Data feed 4:45 Chicago time and collect data till 6:00 (see picture before). At 6:00 I delete and download data from 2:00 and get different result from 4:45. (see picture after). data feed "before" is identical with other TF data (see picture other TF) from 4:45 till 6:00. It means online data is distributed right, and historical data from server not right? Why I get different result after delete and download? Maybe is time synchrinization problem between online data and server?
Before.png / V - Attached On 2015-10-19 11:49:09 UTC - Size: 47.59 KB - 298 views other TP.png / V - Attached On 2015-10-19 11:49:19 UTC - Size: 56.48 KB - 309 views |
[2015-10-20 00:04:18] |
We need some time to check on this. We will get back to you.
[2015-10-22 16:24:37] |
check this volumes please. https://gyazo.com/8cf7e13bf674b248e3ed60119e57a4d9 |
[2015-10-24 04:28:18] |
We apologize for the delay. We need to know what that Time Zone you have Sierra Chart set to, and the Session Times settings in Chart >> Chart Settings. Also post an image of the chart contain the Volume by Price study by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image We will compare to the data we have on the server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-24 04:29:21
[2015-10-24 09:06:15] |
here: http://www.sierrachart.com/image.php?l=1445677190284.png |
Time Zone 1.jpg / V - Attached On 2015-10-24 09:05:53 UTC - Size: 181.06 KB - 309 views Time Zone 2.jpg / V - Attached On 2015-10-24 09:06:02 UTC - Size: 205.94 KB - 307 views |
[2015-10-27 20:12:21] |
First we want to apologize for the long delay with this. We are quite busy. We needed to have the time to examine this closely. We have now done that. We have only examined one of the charts and that is the chart in post #16. We will not examine any other charts. We can see that the volume at price levels are significantly inaccurate in that chart. This is what you should see for 2015-10-23: http://www.sierrachart.com/image.php?l=1445976552303.png (IQ Feed) http://www.sierrachart.com/image.php?l=1445976642993.png (SC Historical Data) All times are US central time. If you re-download the data in the chart by following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart You should get a match to what we show. For reliable data feed, we recommend using the Sierra Chart Real-time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed To use this data feed you need a direct account: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-27 20:13:58
[2015-10-28 22:04:09] |
I re-download the data nothing changes, I delete all the data from hdd and re-download it nothing changes: http://www.sierrachart.com/image.php?l=144606942359.png What you suggest? change data feed? |
[2015-10-29 07:28:19] |
Make sure Sierra Chart is set to a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Also perform a Full Reset of the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps The volume data should be accurate after deleting and downloading the data again. So long as Sierra Chart is set to a tick by tick data configuration, the symbol settings are correct, and you re-download the data, it is a 100% certainty, you will get a match to the images we posted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-29 07:30:36
[2015-10-29 10:14:41] |
I performed full reset. nothing changes. http://www.sierrachart.com/image.php?l=1446113090349.png my configurations is here: |
[2015-10-30 15:12:10] |
Is difference in ticker name ESZ5-CME and @ESZ15 significant? The same problem is for CL future! http://www.sierrachart.com/image.php?l=1446217608684.png |
[2015-10-31 12:07:37] |
No, it does not matter.Really this is not making sense. We continue to see differences when we should not after you re-download the data. We want you to restart Sierra Chart. Only open a chart for ESZ5-CME and no other symbol. Re-download the data with Edit >> Delete All Data and Download. After this, post a copy of the Message Log. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Here is a chart with 60 minute bars showing the volume at price at each price level: http://www.sierrachart.com/image.php?l=1446293204251.png The time zone is US Central. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-31 21:57:25] |
My log Software version: 1312 | 2015-10-31 16:52:58 Uses New Spreadsheets | 2015-10-31 16:52:58 Enabled for: Advanced Features. | 2015-10-31 16:52:58 Enabled for: Sierra Chart Historical Data Service. | 2015-10-31 16:52:58 Allow Support for Sierra Chart Data Feeds is disabled. | 2015-10-31 16:52:58 Current selected Data/Trading service: Rithmic Trading | 2015-10-31 16:52:58 Chart Update Interval: 500 | 2015-10-31 16:52:58 Data/Trade Service Settings automatically set. | 2015-10-31 16:52:58 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-10-31 16:52:58 2015-11-01 00:52:58 Local computer time | 2015-10-31 16:52:58 2015-10-31 21:52:58 Local computer time in UTC | 2015-10-31 16:52:58 2015-10-31 16:52:58 Local computer time in SC Time Zone | 2015-10-31 16:52:58 2015-10-31 21:52:58 Server time in UTC | 2015-10-31 16:52:58 Local computer UTC time and Server UTC time difference: 1 seconds. | 2015-10-31 16:52:58 Program path: D:\SierraChart\ | 2015-10-31 16:52:58 Data Files path: D:\SierraChart\Data\ | 2015-10-31 16:52:58 OS Version Number: 6.2 | 2015-10-31 16:52:58 Locale Information: C | 2015-10-31 16:52:58 Checking for new symbol settings for rim | 2015-10-31 16:52:58 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-10-31 16:52:59 HTTP connection to www.sierrachart.com:80 (3) | Connected. | 2015-10-31 16:53:00 Symbol settings are up-to-date for rim | 2015-10-31 16:53:00 Rithmic Trading | Port for executable: 64176 | 2015-10-31 16:53:03 Listening socket (760), port 64176 | Closed. | 2015-10-31 16:53:04 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2015-10-31 16:53:04 HTTP connection to www.sierrachart.com:80 (3) | Closed. No error. | 2015-10-31 16:53:05 HTTP connection to www.sierrachart.com:80 (3) | Shutdown and closed. | 2015-10-31 16:53:05 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64176 | 2015-10-31 16:53:06 Socket (4) | Connected. | 2015-10-31 16:53:06 Rithmic Trading | Connected to server. | 2015-10-31 16:53:06 Rithmic Trading | Sending logon request message. | 2015-10-31 16:53:06 Rithmic Trading | Starting the connection process to data and trading service. | 2015-10-31 16:53:06 Rithmic Trading | Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2015-10-31 16:53:06 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-10-31 16:53:06 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-10-31 16:53:08 Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-10-31 16:53:08 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-10-31 16:53:09 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-10-31 16:53:09 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-10-31 16:53:10 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-10-31 16:53:10 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-10-31 16:53:11 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-10-31 16:53:11 Rithmic Trading | Server Name: SC DTC Bridge. | 2015-10-31 16:53:12 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2015-10-31 16:53:12 Rithmic Trading | Successfully connected. IB='AMP'. | 2015-10-31 16:53:12 Rithmic Trading | Trading is supported. | 2015-10-31 16:53:12 Rithmic Trading | Order cancel and replace is supported. | 2015-10-31 16:53:12 Rithmic Trading | Connected to data and trading server. | 2015-10-31 16:53:12 Rithmic Trading | Starting real-time market data updates for: ESZ5-CME. ID: 1 | 2015-10-31 16:53:12 Intraday data recording state for symbol ESZ5-CME is set to download 'Pending'. | 2015-10-31 16:53:12 Intraday data recording state for symbol ESZ5-CME is set to download 'Pending'. | 2015-10-31 16:53:12 Historical Intraday data request for ESZ5-CME is discarded because a matching download is already pending and the new one is not for earlier data. | 2015-10-31 16:53:12 Rithmic Trading | OCO Orders supported. | 2015-10-31 16:53:12 HD Request # 2 | Downloading Intraday chart data for ESZ5-CME to the file ESZ5-CME.scid. Service: cme | 2015-10-31 16:53:12 HD Request # 2 | Download start Date-Time: 2015-10-30 15:59:59.000 | 2015-10-31 16:53:12 HD Request # 2 | Using server: scdf1.sierracharts.com port 10149 | 2015-10-31 16:53:12 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-10-31 16:53:12 Socket (5) | Connected. | 2015-10-31 16:53:12 HD Request # 2 | Sending historical data logon request message. | 2015-10-31 16:53:12 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-10-30 15:59:59. Record interval: 1. Symbol: ESZ15 | 2015-10-31 16:53:12 HD Request # 2 | Decompressing data. | 2015-10-31 16:53:12 HD Request # 2 | Receiving Intraday data for ESZ5-CME starting at 2015-10-30 15:59:59 | 2015-10-31 16:53:12 HD Request # 2 | Timestamp of first Intraday data file record written: 2015-10-30 15:59:59 | 2015-10-31 16:53:12 Socket (5) | Shutdown and closed. | 2015-10-31 16:53:12 The network socket for historical data has been closed. | 2015-10-31 16:53:12 HD Request # 2 | Received 1 record from 2015-10-30 15:59:59 to 2015-10-30 15:59:59 (0.0 seconds) and wrote 1 record for ESZ5-CME | 2015-10-31 16:53:12 HD Request # 2 | Intraday download COMPLETE for ESZ5-CME. Completion time: 0s. Unique request ID: 1 | 2015-10-31 16:53:12 Removed historical data download ID 1 | 2015-10-31 16:53:12 Real-time Intraday chart data file updates started for ESZ5-CME | 2015-10-31 16:53:12 Intraday data recording state for symbol ESZ5-CME is set to download 'Pending'. | 2015-10-31 16:53:12 HD Request # 3 | Downloading Intraday chart data for ESZ5-CME to the file ESZ5-CME.scid. Service: rim | 2015-10-31 16:53:12 HD Request # 3 | Download start Date-Time: 2015-10-30 15:59:59.000 | 2015-10-31 16:53:12 HD Request # 3 | Sending historical data request. Start Date-Time: 2015-10-30 15:59:59. Record interval: 0. Symbol: ESZ5-CME | 2015-10-31 16:53:12 Rithmic Trading | Requesting historical Tick data. | 2015-10-31 16:53:12 HD Request # 3 | Error downloading historical Intraday data for ESZ5-CME. Error downloading historical Tick data. Error: no data | 2015-10-31 16:53:12 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ5-CME | 2015-10-31 16:53:12 HD Request # 3 | Intraday download COMPLETE for ESZ5-CME. Completion time: 0s. Unique request ID: 3 | 2015-10-31 16:53:12 Removed historical data download ID 3 | 2015-10-31 16:53:12 Real-time Intraday chart data file updates started for ESZ5-CME | 2015-10-31 16:53:12 | Reloading chart. | 2015-10-31 16:53:26 ESZ5-CME 60 Min #1 | Reloading chart. | 2015-10-31 16:54:00 Requesting symbol settings for ddf. Overwrite = on. | 2015-10-31 16:55:29 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-10-31 16:55:29 HTTP connection to www.sierrachart.com:80 (7) | Connected. | 2015-10-31 16:55:29 Symbol settings received. | 2015-10-31 16:55:32 Processed received symbol settings | 2015-10-31 16:55:32 HTTP connection to www.sierrachart.com:80 (7) | Closed. No error. | 2015-10-31 16:55:37 HTTP connection to www.sierrachart.com:80 (7) | Shutdown and closed. | 2015-10-31 16:55:37 Requesting symbol settings for rim. Overwrite = on. | 2015-10-31 16:55:51 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-10-31 16:55:51 HTTP connection to www.sierrachart.com:80 (8) | Connected. | 2015-10-31 16:55:51 Symbol settings received. | 2015-10-31 16:55:51 Processed received symbol settings | 2015-10-31 16:55:51 HTTP connection to www.sierrachart.com:80 (8) | Closed. No error. | 2015-10-31 16:55:56 HTTP connection to www.sierrachart.com:80 (8) | Shutdown and closed. | 2015-10-31 16:55:56 Intraday data recording state for symbol ESZ5-CME is set to download 'Pending'. | 2015-10-31 16:56:07 Reloading all charts with filename: ESZ5-CME.scid | 2015-10-31 16:56:07 HD Request # 4 | Downloading Intraday chart data for ESZ5-CME to the file ESZ5-CME.scid. Service: cme | 2015-10-31 16:56:07 HD Request # 4 | Download start Date-Time: 2015-04-28 16:56:07.000 | 2015-10-31 16:56:07 HD Request # 4 | Using server: scdf2.sierracharts.com port 10149 | 2015-10-31 16:56:07 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-10-31 16:56:07 Socket (9) | Connected. | 2015-10-31 16:56:07 HD Request # 4 | Sending historical data logon request message. | 2015-10-31 16:56:07 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-04-28 16:56:07. Record interval: 1. Symbol: ESZ15 | 2015-10-31 16:56:07 ESZ5-CME 60 Min #1 | Reloading chart. | 2015-10-31 16:56:07 Currently no data in file to display. Will start historical data download and real-time updates. File: D:\SierraChart\Data\ESZ5-CME.scid | 2015-10-31 16:56:07 HD Request # 4 | Decompressing data. | 2015-10-31 16:56:07 HD Request # 4 | Receiving Intraday data for ESZ5-CME starting at 2015-04-28 23:52:30 | 2015-10-31 16:56:07 HD Request # 4 | Timestamp of first Intraday data file record written: 2015-04-28 23:52:30 | 2015-10-31 16:56:07 Socket (9) | Shutdown and closed. | 2015-10-31 16:56:37 The network socket for historical data has been closed. | 2015-10-31 16:56:37 HD Request # 4 | Received 1429337 records from 2015-04-28 23:52:30 to 2015-10-30 15:59:59 (184.7 days) and wrote 1429337 records for ESZ5-CME | 2015-10-31 16:56:37 HD Request # 4 | Intraday download COMPLETE for ESZ5-CME. Completion time: 30s. Unique request ID: 4 | 2015-10-31 16:56:37 Removed historical data download ID 4 | 2015-10-31 16:56:37 Real-time Intraday chart data file updates started for ESZ5-CME | 2015-10-31 16:56:37 Intraday data recording state for symbol ESZ5-CME is set to download 'Pending'. | 2015-10-31 16:56:37 HD Request # 5 | Downloading Intraday chart data for ESZ5-CME to the file ESZ5-CME.scid. Service: rim | 2015-10-31 16:56:37 HD Request # 5 | Download start Date-Time: 2015-10-30 15:59:59.000 | 2015-10-31 16:56:37 HD Request # 5 | Sending historical data request. Start Date-Time: 2015-10-30 15:59:59. Record interval: 0. Symbol: ESZ5-CME | 2015-10-31 16:56:37 Rithmic Trading | Requesting historical Tick data. | 2015-10-31 16:56:37 HD Request # 5 | Error downloading historical Intraday data for ESZ5-CME. Error downloading historical Tick data. Error: no data | 2015-10-31 16:56:38 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ5-CME | 2015-10-31 16:56:38 HD Request # 5 | Intraday download COMPLETE for ESZ5-CME. Completion time: 0s. Unique request ID: 5 | 2015-10-31 16:56:38 Removed historical data download ID 5 | 2015-10-31 16:56:38 Real-time Intraday chart data file updates started for ESZ5-CME | 2015-10-31 16:56:38 |
[2015-11-01 00:51:39] |
As we indicated in post #10 and #18 you need to set Sierra Chart to a tick by tick data configuration as explained here: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Also the documentation we linked you to in the beginning did state this as well. This is the problem: HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-04-28 16:56:07. Record interval: 1. Symbol: ESZ15 | 2015-10-31 16:56:07 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-01 00:52:21
[2015-11-02 07:37:15] |
Yes, I see, that I can't download tick by tick data. I set 1 tick data, but download failed and SC shows me 1 second data. What is the problem? Rythmic? What to do?
[2015-11-02 07:54:38] |
Yes actually that is true and that is a detail we overlooked. The problem is you are on Sierra Chart service package 3. You will need to contact your broker and have them put you on service package 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
