Date/Time: Sat, 18 May 2024 09:54:19 +0000
Spreads on Daily/Weekly/Monthly Charts
View Count: 732
[2015-10-03 03:22:48] |
Acro - Posts: 436 |
Hi, I'm assuming the instructions for creating Spreads (Difference Line Study and OHLC study) should apply equally to historical charts if one wanted to, for example, look at a spread between two highly correlated stocks. Will they work exactly as they do for intraday charts or is there some adjustment that needs to be made ? Thanks |
[2015-10-05 18:38:10] |
If you are referring to the documentation here: How to Create High Accuracy Spread or Ratio Charts It is not going to make any difference to use a Daily chart if the final result is a Daily chart. It would help to use a Daily chart if the final result is a Weekly or Monthly chart. Although you might just want to use the Difference study by itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-05 18:38:49
