Date/Time: Sun, 19 May 2024 03:16:12 +0000
Live Data Stopped Working
View Count: 606
[2015-09-30 23:20:45] |
dennismed - Posts: 62 |
Live Data Stopped Working What do I need to do ?
[2015-10-01 01:43:30] |
What Data or Trading service are you using or do you wish to use? Select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Refer to help topic 3.4: http://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
