Date/Time: Sat, 18 May 2024 19:03:33 +0000
How to keep decimal places at .01 across all chart symbols in a window?
View Count: 759
[2015-09-29 17:45:25] |
trader1 - Posts: 128 |
Hi, When I change symbols in a chart using the /symbol method, often the decimal place setting on the price ladder on the right hand side changes from .01 to .001. I would like to have it always stay at two decimal places. Can you please tell me how to do that? Thanks. |
[2015-09-29 18:27:31] |
Refer to the instructions here: Changing the Price/Value Display Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-29 19:28:50] |
Hi, I am switching from symbol to symbol and do not have them set up as individual symbols in the global settings. Is there a way to have any stock symbol that appears on a chart use a price display format of .01? Thanks. |
[2015-09-29 19:48:45] |
We see you are using Interactive Brokers and there are Symbol Patterns for Stock symbols which will use .01 for the Price Display Format. Give us an example of one of the symbols you are using. You might also have to update Sierra Chart to the current version for this to work properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-29 20:03:27] |
Well, for example if I have AAPL on the chart and then I use the command /AHS or /BAC the price display format changes from .01 to .001
[2015-09-30 04:36:05] |
Update to the current version of Sierra Chart: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate And also update Symbol Settings as explained here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps You should not have a problem with this. The Price Display Format should be .01. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-30 04:36:51
