Date/Time: Sun, 19 May 2024 01:12:12 +0000
BMF Cash Soybean with SC Historical Data
View Count: 1711
[2015-09-21 13:28:06] |
slompiks - Posts: 11 |
Hello! Can you enable this ticker? I have only empty screen with it.. BMF Cash CORN - it's fully OK! But i need a Soybean also...! Palm Oil - MDEX -not working too ;( Many tickers not working at this datafeed ;((((( Thank you VERY MUCH! Date Time Of Last Edit: 2015-09-21 19:57:55
[2015-09-22 17:36:14] |
We need a little more time to review this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-25 06:09:28
[2015-09-23 19:20:04] |
ok! Thank u! i will be waiting...
[2015-09-25 05:51:10] |
We are working on these. We have completed: Crude Palm Kernel Oil USD (FOPO) - MDEX You need to restart Sierra Chart for the updated settings. We will let you know when the others are done. Update: One thing we realized is that possibly the problem is you are trying to get an Intraday chart? If you do not receive any Intraday chart data, it means Intraday chart data is not available. But you should not have any trouble with Historical Daily charts. We verified that. Basically what we are doing is making sure all of the Symbol Settings for the mentioned symbols are correct. And that there are rollover rules for continuous contracts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-25 05:58:59
[2015-09-25 08:05:13] |
Yes, i use intraday of course. But i still dont understand why BMF corn is working intraday, but BMF soybean no? (daily too - not working!!!) Crude Palm Kernel Oil USD (FOPO) - MDEX - working daily - intraday not ;( |
[2015-09-28 08:52:56] |
We have correctly set all of the symbol settings. The next step is for us to check the data and see if there is anything that looks unusual. In some cases you definitely will not get historical Intraday data and that is not unusual for these exchanges. Will check on BMF soybeans. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-29 04:08:05] |
For the most reliable historical data connectivity, update Sierra Chart to the current version by following the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate We did get a chart of BMF cash settled soybeans: http://www.sierrachart.com/image.php?l=1443499442951.png However there is no historical Intraday data available for this symbol. We are checking on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-29 09:05:47] |
Thank u very much Sierra for your work!!!!!
[2015-09-29 17:15:38] |
Our data provider says there is no Intraday data for the SJ futures because there is no trading activity for it. You can tell by looking at the Volume of each bar on a Daily chart. It will be zero. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-29 17:16:04
[2015-09-30 06:13:07] |
Very strange, i thought SoyBean futures contract on BM&F SunPaulo Stock Exchange this is one of main futures... I need soybean from Brazil ;)
