Date/Time: Wed, 15 May 2024 12:18:23 +0000
chart values
View Count: 789
[2015-09-17 19:30:19] |
Crtfyd - Posts: 277 |
vs 1282 For the last three versions I noticed that my "Chart Values" as I move the curser, is not at the top of the graph (horizontally)right above/below the chart tabs as it use to be. Has this been illuminated or how do I enable it? I don't know if that was the correct name for it, but basically as I move the crosshair curser over a bar, it will show the OHLC, vol, bid, ask, etc of the bar. I see under Windows>Tools Value Window (if checked) will bring up a separate window. And I guess that's the info I want, but it use to be a "Chart Header on my graph" (horizontal info above the chart tabs). Thanks |
[2015-09-17 19:39:48] |
What you are referring to is the old Status Bar which has been removed. Refer to this information here for the replacement: New Control Bar to replace ToolBar and Status Bar | Post: 66601 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
