Date/Time: Tue, 07 May 2024 22:32:40 +0000
Error Message help
View Count: 740
[2015-09-10 14:53:35] |
AP - Posts: 117 |
Error Message - Trade Activity Log file read result: 41855 records inserted. 0 records filtered. | 2015-09-10 09:01:28 1. Can you please tell me what is the above all about? 2. Can I silent this error in future? Also, this does not have a CQG Service id - so this is clearly generated internally in SC. PLEASE HELP. |
[2015-09-10 17:37:47] |
This is an informational message. It is not an error message. You can disregard it.
[2015-09-10 17:42:21] |
AP - Posts: 117 |
Understood - but how about the pause it generates when the message pops up. Is there a way to have it not pause trading or order entry? |
[2015-09-10 18:00:47] |
AP - Posts: 117 |
Also, is there a way to have these messages not pop up in the first place - please?
[2015-09-10 18:30:31] |
See our response here: Another error - PLEASE HELP | Post: 68388 The error message you are referencing above is unrelated and does not open the Trade Service Log. Please also do not start any new Support Request on our Support Board about this issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-10 18:30:59
[2015-09-10 18:38:09] |
AP - Posts: 117 |
Well - I understood this. And thanks but what I am asking is if - Is there a way I can have the Trade Service Log not pop up at all? |
[2015-09-10 18:41:40] |
Yes. By leaving it open and moving it to the edge of the screen. However, if that window is opening, then there is some important message that needs to be communicated to you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
