Date/Time: Mon, 29 Apr 2024 11:16:29 +0000
Increased ATR precision
View Count: 877
[2015-09-08 11:40:43] |
wat - Posts: 67 |
Is it possible to get Average True Range with increased precision (3 or more decimal places)? Only 2 decimal places are insufficient for instruments like NG. Thanks for your reply. |
[2015-09-08 14:03:44] |
SC Developer - David - Posts: 660 |
You should go to "Analysis >> Studies" then open Study settings window for Average True Range study and on "Settings and Inputs" tab change the precision by "Value Format" combo box. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#SettingsandInputsTab |
[2015-09-08 17:29:47] |
This is also explained here: Changing the Price/Value Display Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
