Date/Time: Thu, 02 May 2024 22:45:29 +0000
indicator DIFFERENCE candlestick problem
View Count: 819
[2015-09-08 08:38:34] |
User75772 - Posts: 1 |
There is a problem when the indicator DIFFERENCE present in CANDLESTICK.. it did not recall the high and low and it is constantly changing and most of the time it do not show tails tnx akiva |
[2015-09-08 08:47:24] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Also refer to this page to see if answers the question: How to Create High Accuracy Spread or Ratio Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
