Date/Time: Sun, 19 May 2024 02:34:52 +0000
How to remove a Time and Sales widow?
View Count: 1659
[2015-08-29 17:42:27] |
Rino - Posts: 124 |
Hi, Please forgive me I would not ask without spending ample time to research and answer for myself. I give up. I have several Time and Sales windows open. I for the life of me can not figure out how to close one if I wanted to. There is nothing in Settings and there is not a menu bar like on a chart. Thanks, Rino |
[2015-08-29 18:38:22] |
Cavalry3162 - Posts: 523 |
but there is an X where you can close it
2015-08-29_14-37-17.png / V - Attached On 2015-08-29 18:38:02 UTC - Size: 17.41 KB - 355 views |
[2015-08-29 18:54:08] |
Rino - Posts: 124 |
Thanks and kind of you to reply. Mine does not look like that, no X. I use Infinity I wonder if time and sales is different because of them? https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=5856 |
[2015-08-29 18:58:13] |
i posted a market depth window first.. was missreading your post. however, you may want to visit the T&S settings and check that there is "Show Titlebar" checked. Andreas |
2015-08-29_14-56-45.png / V - Attached On 2015-08-29 18:57:17 UTC - Size: 66.21 KB - 386 views |
[2015-08-29 18:59:23] |
Rino - Posts: 124 |
Settings looks like this.
[2015-08-29 19:01:07] |
yeah, so as you can see on my screenshot, check on the "Show Titlebar" setting and you're all set
[2015-08-29 19:04:31] |
Rino - Posts: 124 |
Sorry for all the post. It does have a "Show Title Bar" When I click on it it does not change it. It still looks like the first image I posted. Crazy.......... |
[2015-08-29 19:08:57] |
yeah, that sounds odd.. lets wait for the SC guys, maybe they know whats going on. |
[2015-08-29 19:11:17] |
Rino - Posts: 124 |
I am now punching myself in the face to try and relive some of the pain of this cr%^Y&*&*c............... PS Nothing personal Time and Sales but I just want you to go away....... PSS I am now breaking down.:o( |
[2015-08-30 05:18:08] |
The next release will correct this problem. We understand the reason why this is happening. For now go to the chart associated with the Time and Sales window and select Chart >> Reload and Recalculate after enabling Show Title Bar in the Time and Sales Settings. This is an excellent example of why in general, we are hesitant to add functionality like hiding of title bars and menus because it does create a general problem where there is not an obvious intuitive way to restore these things. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-30 07:03:15] |
@SierraChart but be aware of the fact that exactly these functionalities are the ones you stand out and are really usefull. Not adding those cause of a potential problem (what can be fixed) that *might* pop up here and there doesnt make sense either. Thats what prereleases (beta's) are for. i am a heavy user of "no title bar", in fact i have (except for the Sierra Chart main window, where you cant disable it) no window with a title bar whatsoever. |
2015-08-30_02-52-04.png / V - Attached On 2015-08-30 07:02:21 UTC - Size: 1.27 MB - 326 views |
[2015-08-30 18:33:13] |
GPST10 - Posts: 139 |
Andreas, Yep |
