Date/Time: Mon, 29 Apr 2024 11:19:45 +0000
Off-chart CTV information
View Count: 769
[2015-08-26 07:13:38] |
knowle - Posts: 25 |
I am forced to use the CTV in horizonatl layout because it is the least chart obstruct layout of this chart obstructive tool. For all charts use I have it permanently positioned centre screen with half the width covering the sierra chart title bar (immediately below the tool bar) and half on the chart. I cannot move it any further up off the chart because it would then obstruct the tool bar. I have searched the support board re this information displayed in an off-chart layout and location. The closes appears to be a request-thread regarding the removal of the status bar, the reinstatement of the status bar, then revolvoing door ambiguity. Is there a definitive answer to having the CTV information displayed in an off-the-chart location such as the the Sierra Chart title bar (immediately below the tool bar)?
Date Time Of Last Edit: 2015-08-26 07:27:10
[2015-08-26 07:48:20] |
Seems like there should not be such a problem with this especially being under usual cases it is temporarily displayed. You can also remove fields from it by following the instructions here: https://www.sierrachart.com/index.php?page=doc/helpdetails67.html#HidingMainPriceGraphValuesVW Although in the latest prerelease there is an option in Global Settings >> Tool Settings to keep it always visible when using the Chart Values tool. If you have Chartbook or MDI window tabs displayed on the main window, you can always place it over those. Here is documentation: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#Tabs You can also move to the very top title bar of the main window. We also recommend referring to the information here: New Control Bar to replace ToolBar and Status Bar | Post: 66601 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-26 07:48:58
