Date/Time: Wed, 01 May 2024 01:50:26 +0000
FXCM On Chart Trading
View Count: 828
[2015-08-22 19:16:57] |
esMike - Posts: 67 |
In order to enter and adjust trades on chart, what is the minimum account type for FXCM? Normal Account + 10k Balance, or are micro accounts supported too? |
[2015-08-22 23:19:54] |
We do not think micro accounts are supported. You will need a 10K FXCM account to use FXCM FIX.
[2015-08-23 19:31:15] |
Hieronymus - Posts: 51 |
Fxcm is 10k for sure, I've talked with them a good deal last month about this. There is no good option if you want to trade spot FX yet, unless you have 10k or more. OEC is through forex.com and I use that but it's not ideal, bad spreads, crappy candle formations, bad volume feed and the prices are always off all other spot feeds. I suggest anyone interested in trading spot FX votes on the "DTC protocol support by trading services" sticky. Date Time Of Last Edit: 2015-08-23 19:37:31
