Date/Time: Sun, 05 May 2024 12:07:46 +0000
Bid Ask Volume Bar Setting
View Count: 1175
[2015-08-21 22:53:17] |
User83814 - Posts: 26 |
Hello, I wanted to point out the help page for the Bid Ask Volume Bars is out of date. http://www.sierrachart.com/index.php?page=doc/doc_PriceGraphTypes.html#BidAskVolumeBars On that page, you only refer to 3 categories: large/medium/light, while recent versions offer 4 categories: large/medium-large/light-medium/light. Kindly please update. Additionally, the help page explains large/medium/light depends on proportion of bid(or ask) volume compared with total volume. Top third is classified as large volume, middle third goes to medium, and bottom third light volume. With 4 categories, I can imagine 1/3 is replaced by 1/4. Is this correct? I actually prefer to use some other percentage settings. Is there an option to customize? Thank you Date Time Of Last Edit: 2015-08-22 02:26:51
[2015-08-24 03:01:51] |
The documentation has now been updated. There is no way to customize the percentages. They are fixed. Refer to the updated documentation for the current percentages. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
