Date/Time: Sun, 05 May 2024 18:41:35 +0000
Data used for TPO and Volume Profile Charts
View Count: 1002
[2015-08-19 17:29:16] |
Sierra Chart supports numerous Data and Trading services for data. What Data or Trading service are you using or do you wish to use? See this page for the list: http://www.sierrachart.com/index.php?page=data.php Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. The documentation for these studies explains the rest of these details. Refer to this page for the documentation: https://www.sierrachart.com/index.php?page=doc/doc_Contents.php The step-by-step instructions will indicate to use tick by tick data if that is what is needed for highest accuracy and provides instructions on how to use this data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-19 21:59:58] |
Volume Profiles can be created from tick by tick data. This a setting that you can change. And TPO Profiles do not require data with a timeframe shorter than 1 minute. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-19 22:15:40] |
Volume Profiles can be created from tick by tick data on 30 minute and 1 day per bar charts. TPO Profile Charts do not require data with a timeframe any less than 1 minute. These kinds of charts do not use chart bars in the usual way and the bars are not visible. So the timeframe per bar, is not even controllable. It is automatically managed and the underlying bars are not visible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-19 22:16:15
