Date/Time: Fri, 03 May 2024 14:41:16 +0000
Multiple Sierra instances on 1 PC
View Count: 786
[2015-08-12 12:13:50] |
User53687 - Posts: 1 |
I would like to run live trading strategies and sim strategies on the same PC (VPS) simultaneously. Is this possible? How to configure this? If not what is the easiest workaround? |
[2015-08-12 13:21:42] |
Yes this is possible. Refer to the instructions on this page: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
