Date/Time: Thu, 08 Oct 2026 10:01:09 +0000
Is there an ACSIL sc.Variable to show Trade >> Chart Trade Mode On status?
View Count: 1307
| [2015-08-03 19:32:55] |
| bjohnson777 (Brett Johnson) - Posts: 284 |
Is there an ACSIL sc.Variable to show Trade >> Chart Trade Mode On status? Searching hasn't turned up anything. Some functionality and order types need this enabled to work properly. It would be easier to check for it before using it. Thanks |
| [2015-08-03 21:40:18] |
No there is not.
| [2015-08-03 22:18:36] |
I'd like to request it for the reasons first listed. Read Only is fine. Thanks |
| [2015-08-05 09:52:52] |
We will add this.
| [2015-08-08 02:34:23] |
This will be added as a read/write ACSIL variable in version 1282: sc.IsChartTradeModeOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
