Date/Time: Thu, 16 May 2024 05:34:05 +0000
New Control Bar Questions
View Count: 974
[2015-08-01 15:24:07] |
blknsxy - Posts: 29 |
What happened to the ability to copy the workings of one toolBar to another? Also I can no longer attach a toolbar to right and left as a nice compact unit, as it displays at the top and bottom, instead I get this very wide, Fat Toolbar, how to fix this. Thanks |
Attachment Deleted. |
[2015-08-01 21:16:51] |
This did not exist previously and also is too vague as to what you exactly mean.The reason for the wide Control Bar is you need to remove the "Status Bar" item on it through Global Settings >> Customize Toolbars. Any Control Bar that you want to attach to the left or right should not contain the Status Bar item. There are 8 Tool/Control bars you can customize any way you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-01 22:08:10
[2015-08-01 22:43:53] |
User201106 - Posts: 61 |
Attached is a screenshot of the Modify/Copy Toolbar feature from the earlier version. I think it is a good feature to retain and should be included. You have to right click in the body of the Toolbar to get the menu.
ModifyOrCopyToolbar.png / V - Attached On 2015-08-01 22:42:51 UTC - Size: 4.54 KB - 344 views |
[2015-08-02 03:10:56] |
OK I did not know about this. This needs to be documented and also included through Global Settings >> Customize Toolbars. We will also add it to the right-click Shortcut menu for Control Bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-02 03:11:15
[2015-08-02 14:17:14] |
Thank you Canyon2 for the detailed explanation.
[2015-08-08 15:27:22] |
Thanks for fixing this with the latest version. 1281
