Date/Time: Sun, 28 Apr 2024 06:54:03 +0000
Big Gap in data download
View Count: 708
[2015-07-13 05:33:42] |
User17920 - Posts: 1 |
Hi I am trying to download 30 min data for the SI 2015 09 futures contract and have a big gap in the data (missing almost a month). Daily chart is OK no missing data. I am using an IB feed and also have that feed working on a ninjatrader chart with no problems. All other 30 min charts are ok but this one is causing problems Thanks for your help |
[2015-07-13 10:54:38] |
What is the exact symbol of the chart you are using? Be sure you are using the symbol only listed in File >> Find Symbol so the historical data is mapped to the Sierra Chart Historical Data Service. And also are using the Continuous Futures Contract feature? Follow the instructions here to re-download the data: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
