Date/Time: Sat, 17 Jan 2026 00:47:25 +0000
ACSIL QUESTION DYNAMIC HEADERS
View Count: 1518
[2015-05-22 06:06:08]
enemyspy - Posts: 306
Hi, I have made some modifications to the writebardatatofile study in order to instead output study subgraphs.
I have replaced the float references to the OHLC arrays, with the following omitting everything except the key changes:
  SCSFExport scsf_WriteSGDatatofile(SCStudyInterfaceRef sc)
SCInputRef Separator = sc.Input[0];
  SCInputRef UseGMTTime = sc.Input[1];
  SCInputRef DateFormat = sc.Input[2];
  SCInputRef OutputMilliseconds = sc.Input[3];
  SCInputRef StudyReference1 = sc.Input[4];
if(sc.SetDefaults)
StudyReference1.Name = "Subgraph Input 1";
sc.Input[4].SetChartStudySubgraphValues(1,1,12);
return;
SCFloatArray SGInput1;
  sc.GetStudyArrayUsingID(StudyReference1.GetStudyID(),StudyReference1.GetSubgraphIndex(), SGInput1);
//These references are later used to define the string variables below in the exact same way that the original study is done
So in the Header section which I have currently modified to look like this:
SCString fileHeader;
    switch(Separator.GetInt())
    case 0:
      fileHeader = "Date Time SGInput1\r\n";
      break;
    case 1:
      fileHeader = "Date, Time, SGInput1\r\n";
      break;
    case 2:
      fileHeader = "Date\Time\SGInput1\r\n";
      break;
Is there a way to make the Header references Dynamic based on references to the subgraphs in the original study that I am pulling the SG arrays from so that I do not have to customize them for every application I require this study for?
Date Time Of Last Edit: 2015-05-22 06:09:43
[2015-05-23 03:53:15]
Currently there is no way to get a Subgraph name from another study in ACSIL. Longer-term this capability will be developed.
We could quickly add a function to do this, but we really want to add comprehensive and organized support for something like this.
Date Time Of Last Edit: 2015-05-23 03:54:14
[2015-05-23 04:20:11]
I may try writing a function for to do it for learning purposes, and because it would be easier longer term. But I was also thinking that I would have to build it in to each indicator being used, a couple of which I did not write myself or understand.
I am wondering if I should create a class file, and build a function which somehow automatically pulls the .name as strings from each indicator. Would it be possible with an approach like this or am I way off base.
[2015-05-24 06:39:32]
Really we have to add a function for you to do this. That really is the only practical way.
Let us see what we can do.
[2015-05-24 18:32:12]
ok thank you I appreciate your consideration of this, especially considering I doubt it is a very in demand feature. Also if you have a quick and dirty solution, that does not take too much of your time, and then I cannot get it to work. I certainly will not expect additional support to be provided.
