Date/Time: Tue, 09 Jun 2026 15:29:51 +0000
scale-in/scale-out and oco qty
View Count: 2294
| [2013-06-04 21:41:50] |
| Bedhog - Posts: 187 |
Hello Support, This has always worked and it may be my doing, but I believe it stopped after updating to 982. I trade with 2 charts open and each chart has its own trade book. I use ChartA to make an entry and it is set for 2-lots, Use Attached Orders, with Scale-in/Scale-out enabled. I use ChartB to perform the actual scaling using a qty of 1. Use Attached Orders is not selected and Scale-in/Scale-out are enabled. Prior to the update, I could scale-in and scale-out with ChartB and the OCO would always reflect the current position size. At the moment, scale-in/scale-out from ChartB does not update the OCO quantities. Thank you. |
| [2013-06-05 07:39:25] |
Some brief testing did not indicate a problem. Scale In requires that Use Attached Orders is enabled. Scale Out does not require it. Please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#ScalingOut Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
