Date/Time: Sat, 18 May 2024 13:22:30 +0000
Stock chart data error?
View Count: 870
[2015-05-15 12:49:46] |
EuropeanTrader - Posts: 290 |
Hi, I am using SC Historical data and I see a price gap in AAPL that I dont see on other charting packages. Where is the reason please? Pls see attached pics Thank you. |
AAPL Daily #1 2015-05-15 14_46_51.904.png / V - Attached On 2015-05-15 12:49:44 UTC - Size: 70.28 KB - 336 views |
[2015-05-15 17:16:15] |
Re-download the data in the chart by selecting Edit >> Delete All Data and Download: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.2 Historical Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-16 07:48:40] |
ok, thank you does that mean I only need to do this once or for each stock on my watchlist? |
[2015-05-16 08:40:23] |
Yes. If there is a Daily data error like this, which is the result of a stock split, then you just need to re-download the data once per symbol.
