Date/Time: Tue, 14 May 2024 15:57:42 +0000
Windows Error Code 32
View Count: 1572
[2015-05-05 15:15:35] |
User46930 - Posts: 28 |
Sometimes when I open SC and my YM chartbook after closing I get this error message: Failed to open the file C:\SierraChart\Data\F.US.YMM15.scid for adding records. Error: Windows error code 32: The process cannot access the file because it is being used by another process. Failed to open the intraday data file for F.US.YMM15. | 2015-05-05 10:13:16 * On chart there is a message: "Download failed" After next or few next restart it seems ok but there is missing backfill Any idea what could cause this? Date Time Of Last Edit: 2015-05-05 15:16:07
[2015-05-05 17:09:41] |
Sierra Chart - Max - Posts: 5609 |
Make sure that your anti-virus is not locking the Sierra Chart files. Refer to help topic 16: http://www.sierrachart.com/index.php?page=doc/helpdetails16.html Sierra Chart Support Date Time Of Last Edit: 2015-05-05 17:22:35
[2015-05-05 17:36:13] |
Most likely this is caused by antivirus/anti-malware software. Refer to help topic 30.8: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.8 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
