Date/Time: Wed, 15 May 2024 04:46:15 +0000
can not connect to cts date feed
View Count: 917
[2015-05-05 14:45:44] |
User794098 - Posts: 1 |
Software version: 1252 | 2015-05-05 10:33:38 Uses New Spreadsheets | 2015-05-05 10:33:38 Usage end date: 2015-05-20 | 2015-05-05 10:33:38 Enabled for: Advanced Features. | 2015-05-05 10:33:38 Enabled for: Advanced Features 2. | 2015-05-05 10:33:38 Enabled for: Sierra Chart Historical Data Service. | 2015-05-05 10:33:38 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-05-05 10:33:38 Active service: CTS T4 FIX | 2015-05-05 10:33:38 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-05-05 10:33:38 2015-05-05 10:33:38 Local computer clock time | 2015-05-05 10:33:38 2015-05-05 14:33:38 GMT time | 2015-05-05 10:33:38 2015-05-05 10:33:38 Time zone adjusted time | 2015-05-05 10:33:38 Time difference to server time: 5 seconds. | 2015-05-05 10:33:38 Program path: C:\SierraChart\ | 2015-05-05 10:33:38 Data Files path: C:\SierraChart\Data\ | 2015-05-05 10:33:38 OS Version Number: 6.2 | 2015-05-05 10:33:38 Locale Information: C | 2015-05-05 10:33:38 Checking for new symbol settings for cts | 2015-05-05 10:33:38 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-05 10:33:38 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-05-05 10:33:38 Requesting symbol settings for cts. Overwrite = on. | 2015-05-05 10:33:38 Symbol settings received. | 2015-05-05 10:33:41 Processed received symbol settings | 2015-05-05 10:33:41 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:33:43 CTS FIX - Firm: CTS | 2015-05-05 10:33:43 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:33:43 CTS FIX socket (2) | Connected. | 2015-05-05 10:33:43 CTS FIX socket (2) | Starting SSL connection. | 2015-05-05 10:33:43 CTS FIX socket (2) | SSL connection established. | 2015-05-05 10:33:44 CTS FIX: Sending the Logon message. | 2015-05-05 10:33:45 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-05-05 10:33:45 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-05-05 10:33:45 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:33:45 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:33:45 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:33:45 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:33:45 CTS FIX socket (2) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:33:45 CTS FIX socket (2) | SSL has been shut down. | 2015-05-05 10:33:45 CTS FIX socket (2) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:33:45 CTS FIX socket (2) | Shutdown and closed. | 2015-05-05 10:33:45 CTS FIX: Logged out and disconnected. | 2015-05-05 10:33:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:33:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:33:45 CTS FIX: DisconnectFIX called. | 2015-05-05 10:33:45 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:33:45 CTS FIX: Disconnected. | 2015-05-05 10:33:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:33:45 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:33:48 CTS FIX - Firm: CTS | 2015-05-05 10:33:48 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:33:48 CTS FIX socket (3) | Connected. | 2015-05-05 10:33:48 CTS FIX socket (3) | Starting SSL connection. | 2015-05-05 10:33:48 CTS FIX socket (3) | SSL connection established. | 2015-05-05 10:33:48 CTS FIX: Sending the Logon message. | 2015-05-05 10:33:48 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:33:48 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:33:48 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:33:48 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:33:48 CTS FIX socket (3) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:33:48 CTS FIX socket (3) | SSL has been shut down. | 2015-05-05 10:33:48 CTS FIX socket (3) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:33:48 CTS FIX socket (3) | Shutdown and closed. | 2015-05-05 10:33:48 CTS FIX: Logged out and disconnected. | 2015-05-05 10:33:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:33:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:33:48 CTS FIX: DisconnectFIX called. | 2015-05-05 10:33:48 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:33:48 CTS FIX: Disconnected. | 2015-05-05 10:33:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:33:48 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:33:51 CTS FIX - Firm: CTS | 2015-05-05 10:33:51 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:33:51 CTS FIX socket (4) | Connected. | 2015-05-05 10:33:51 CTS FIX socket (4) | Starting SSL connection. | 2015-05-05 10:33:51 CTS FIX socket (4) | SSL connection established. | 2015-05-05 10:33:52 CTS FIX: Sending the Logon message. | 2015-05-05 10:33:52 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:33:52 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:33:52 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:33:52 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:33:52 CTS FIX socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:33:52 CTS FIX socket (4) | SSL has been shut down. | 2015-05-05 10:33:52 CTS FIX socket (4) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:33:52 CTS FIX socket (4) | Shutdown and closed. | 2015-05-05 10:33:52 CTS FIX: Logged out and disconnected. | 2015-05-05 10:33:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:33:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:33:52 CTS FIX: DisconnectFIX called. | 2015-05-05 10:33:52 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:33:52 CTS FIX: Disconnected. | 2015-05-05 10:33:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:33:52 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:33:55 CTS FIX - Firm: CTS | 2015-05-05 10:33:55 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:33:55 CTS FIX socket (5) | Connected. | 2015-05-05 10:33:55 CTS FIX socket (5) | Starting SSL connection. | 2015-05-05 10:33:55 CTS FIX socket (5) | SSL connection established. | 2015-05-05 10:33:55 CTS FIX: Sending the Logon message. | 2015-05-05 10:33:56 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:33:56 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:33:56 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:33:56 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:33:56 CTS FIX socket (5) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:33:56 CTS FIX socket (5) | SSL has been shut down. | 2015-05-05 10:33:56 CTS FIX socket (5) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:33:56 CTS FIX socket (5) | Shutdown and closed. | 2015-05-05 10:33:56 CTS FIX: Logged out and disconnected. | 2015-05-05 10:33:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:33:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:33:56 CTS FIX: DisconnectFIX called. | 2015-05-05 10:33:56 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:33:56 CTS FIX: Disconnected. | 2015-05-05 10:33:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:33:56 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:33:59 CTS FIX - Firm: CTS | 2015-05-05 10:33:59 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:33:59 CTS FIX socket (6) | Connected. | 2015-05-05 10:33:59 CTS FIX socket (6) | Starting SSL connection. | 2015-05-05 10:33:59 CTS FIX socket (6) | SSL connection established. | 2015-05-05 10:33:59 CTS FIX: Sending the Logon message. | 2015-05-05 10:33:59 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:33:59 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:33:59 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:33:59 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:33:59 CTS FIX socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:33:59 CTS FIX socket (6) | SSL has been shut down. | 2015-05-05 10:33:59 CTS FIX socket (6) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:33:59 CTS FIX socket (6) | Shutdown and closed. | 2015-05-05 10:33:59 CTS FIX: Logged out and disconnected. | 2015-05-05 10:33:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:33:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:33:59 CTS FIX: DisconnectFIX called. | 2015-05-05 10:33:59 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:33:59 CTS FIX: Disconnected. | 2015-05-05 10:33:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:33:59 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:34:02 CTS FIX - Firm: CTS | 2015-05-05 10:34:02 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:34:02 CTS FIX socket (7) | Connected. | 2015-05-05 10:34:02 CTS FIX socket (7) | Starting SSL connection. | 2015-05-05 10:34:02 CTS FIX socket (7) | SSL connection established. | 2015-05-05 10:34:03 CTS FIX: Sending the Logon message. | 2015-05-05 10:34:03 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:34:05 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:34:05 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:34:05 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:34:05 CTS FIX socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:34:05 CTS FIX socket (7) | SSL has been shut down. | 2015-05-05 10:34:05 CTS FIX socket (7) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:34:05 CTS FIX socket (7) | Shutdown and closed. | 2015-05-05 10:34:05 CTS FIX: Logged out and disconnected. | 2015-05-05 10:34:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:34:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:34:05 CTS FIX: DisconnectFIX called. | 2015-05-05 10:34:05 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:34:05 CTS FIX: Disconnected. | 2015-05-05 10:34:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:34:05 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:34:08 CTS FIX - Firm: CTS | 2015-05-05 10:34:08 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:34:08 CTS FIX socket (8) | Connected. | 2015-05-05 10:34:08 CTS FIX socket (8) | Starting SSL connection. | 2015-05-05 10:34:08 CTS FIX socket (8) | SSL connection established. | 2015-05-05 10:34:08 CTS FIX: Sending the Logon message. | 2015-05-05 10:34:09 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:34:09 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:34:09 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:34:09 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:34:09 CTS FIX socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:34:09 CTS FIX socket (8) | SSL has been shut down. | 2015-05-05 10:34:09 CTS FIX socket (8) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:34:09 CTS FIX socket (8) | Shutdown and closed. | 2015-05-05 10:34:09 CTS FIX: Logged out and disconnected. | 2015-05-05 10:34:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:34:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:34:09 CTS FIX: DisconnectFIX called. | 2015-05-05 10:34:09 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:34:09 CTS FIX: Disconnected. | 2015-05-05 10:34:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:34:09 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:34:12 CTS FIX - Firm: CTS | 2015-05-05 10:34:12 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:34:12 CTS FIX socket (9) | Connected. | 2015-05-05 10:34:12 CTS FIX socket (9) | Starting SSL connection. | 2015-05-05 10:34:12 CTS FIX socket (9) | SSL connection established. | 2015-05-05 10:34:12 CTS FIX: Sending the Logon message. | 2015-05-05 10:34:12 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:34:12 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:34:12 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:34:12 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:34:12 CTS FIX socket (9) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:34:12 CTS FIX socket (9) | SSL has been shut down. | 2015-05-05 10:34:12 CTS FIX socket (9) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:34:12 CTS FIX socket (9) | Shutdown and closed. | 2015-05-05 10:34:12 CTS FIX: Logged out and disconnected. | 2015-05-05 10:34:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:34:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:34:12 CTS FIX: DisconnectFIX called. | 2015-05-05 10:34:12 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:34:12 CTS FIX: Disconnected. | 2015-05-05 10:34:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:34:12 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:34:15 CTS FIX - Firm: CTS | 2015-05-05 10:34:15 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:34:15 CTS FIX socket (10) | Connected. | 2015-05-05 10:34:15 CTS FIX socket (10) | Starting SSL connection. | 2015-05-05 10:34:15 CTS FIX socket (10) | SSL connection established. | 2015-05-05 10:34:16 CTS FIX: Sending the Logon message. | 2015-05-05 10:34:16 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:34:16 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:34:16 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:34:16 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:34:16 CTS FIX socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:34:16 CTS FIX socket (10) | SSL has been shut down. | 2015-05-05 10:34:16 CTS FIX socket (10) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:34:16 CTS FIX socket (10) | Shutdown and closed. | 2015-05-05 10:34:16 CTS FIX: Logged out and disconnected. | 2015-05-05 10:34:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:34:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:34:16 CTS FIX: DisconnectFIX called. | 2015-05-05 10:34:16 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:34:16 CTS FIX: Disconnected. | 2015-05-05 10:34:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:34:16 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:34:19 CTS FIX - Firm: CTS | 2015-05-05 10:34:19 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:34:19 CTS FIX socket (11) | Connected. | 2015-05-05 10:34:19 CTS FIX socket (11) | Starting SSL connection. | 2015-05-05 10:34:19 CTS FIX socket (11) | SSL connection established. | 2015-05-05 10:34:19 CTS FIX: Sending the Logon message. | 2015-05-05 10:34:19 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:34:20 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:34:20 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:34:20 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:34:20 CTS FIX socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:34:20 CTS FIX socket (11) | SSL has been shut down. | 2015-05-05 10:34:20 CTS FIX socket (11) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:34:20 CTS FIX socket (11) | Shutdown and closed. | 2015-05-05 10:34:20 CTS FIX: Logged out and disconnected. | 2015-05-05 10:34:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:34:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:34:20 CTS FIX: DisconnectFIX called. | 2015-05-05 10:34:20 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:34:20 CTS FIX: Disconnected. | 2015-05-05 10:34:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:34:20 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:34:23 CTS FIX - Firm: CTS | 2015-05-05 10:34:23 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:34:23 CTS FIX socket (12) | Connected. | 2015-05-05 10:34:23 CTS FIX socket (12) | Starting SSL connection. | 2015-05-05 10:34:23 CTS FIX socket (12) | SSL connection established. | 2015-05-05 10:34:23 CTS FIX: Sending the Logon message. | 2015-05-05 10:34:23 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:34:23 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:34:23 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:34:23 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:34:23 CTS FIX socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:34:23 CTS FIX socket (12) | SSL has been shut down. | 2015-05-05 10:34:23 CTS FIX socket (12) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:34:23 CTS FIX socket (12) | Shutdown and closed. | 2015-05-05 10:34:23 CTS FIX: Logged out and disconnected. | 2015-05-05 10:34:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:34:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:34:23 CTS FIX: DisconnectFIX called. | 2015-05-05 10:34:23 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:34:23 CTS FIX: Disconnected. | 2015-05-05 10:34:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:34:23 File >> Disconnect selected. | 2015-05-05 10:34:24 CTS FIX: DisconnectFIX called. | 2015-05-05 10:34:24 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:34:24 CTS FIX: Disconnected. | 2015-05-05 10:34:24 Current selected Data/Trading service: CTS T4 FIX | 2015-05-05 10:36:11 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:15 CTS FIX - Firm: CTS | 2015-05-05 10:36:15 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:15 CTS FIX socket (13) | Connected. | 2015-05-05 10:36:15 CTS FIX socket (13) | Starting SSL connection. | 2015-05-05 10:36:15 CTS FIX socket (13) | SSL connection established. | 2015-05-05 10:36:15 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:15 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:16 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:16 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:16 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:16 CTS FIX socket (13) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:16 CTS FIX socket (13) | SSL has been shut down. | 2015-05-05 10:36:16 CTS FIX socket (13) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:16 CTS FIX socket (13) | Shutdown and closed. | 2015-05-05 10:36:16 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:16 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:16 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:16 CTS FIX: Disconnected. | 2015-05-05 10:36:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:16 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:19 CTS FIX - Firm: CTS | 2015-05-05 10:36:19 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:19 CTS FIX socket (14) | Connected. | 2015-05-05 10:36:19 CTS FIX socket (14) | Starting SSL connection. | 2015-05-05 10:36:19 CTS FIX socket (14) | SSL connection established. | 2015-05-05 10:36:19 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:19 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:19 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:19 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:19 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:19 CTS FIX socket (14) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:19 CTS FIX socket (14) | SSL has been shut down. | 2015-05-05 10:36:19 CTS FIX socket (14) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:19 CTS FIX socket (14) | Shutdown and closed. | 2015-05-05 10:36:19 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:19 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:19 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:19 CTS FIX: Disconnected. | 2015-05-05 10:36:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:19 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:22 CTS FIX - Firm: CTS | 2015-05-05 10:36:22 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:22 CTS FIX socket (15) | Connected. | 2015-05-05 10:36:22 CTS FIX socket (15) | Starting SSL connection. | 2015-05-05 10:36:22 CTS FIX socket (15) | SSL connection established. | 2015-05-05 10:36:22 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:23 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:23 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:23 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:23 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:23 CTS FIX socket (15) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:23 CTS FIX socket (15) | SSL has been shut down. | 2015-05-05 10:36:23 CTS FIX socket (15) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:23 CTS FIX socket (15) | Shutdown and closed. | 2015-05-05 10:36:23 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:23 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:23 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:23 CTS FIX: Disconnected. | 2015-05-05 10:36:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:23 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:26 CTS FIX - Firm: CTS | 2015-05-05 10:36:26 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:26 CTS FIX socket (16) | Connected. | 2015-05-05 10:36:26 CTS FIX socket (16) | Starting SSL connection. | 2015-05-05 10:36:26 CTS FIX socket (16) | SSL connection established. | 2015-05-05 10:36:26 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:26 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:27 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:27 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:27 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:27 CTS FIX socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:27 CTS FIX socket (16) | SSL has been shut down. | 2015-05-05 10:36:27 CTS FIX socket (16) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:27 CTS FIX socket (16) | Shutdown and closed. | 2015-05-05 10:36:27 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:27 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:27 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:27 CTS FIX: Disconnected. | 2015-05-05 10:36:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:27 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:30 CTS FIX - Firm: CTS | 2015-05-05 10:36:30 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:30 CTS FIX socket (17) | Connected. | 2015-05-05 10:36:30 CTS FIX socket (17) | Starting SSL connection. | 2015-05-05 10:36:30 CTS FIX socket (17) | SSL connection established. | 2015-05-05 10:36:30 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:30 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:30 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:30 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:30 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:30 CTS FIX socket (17) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:30 CTS FIX socket (17) | SSL has been shut down. | 2015-05-05 10:36:30 CTS FIX socket (17) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:30 CTS FIX socket (17) | Shutdown and closed. | 2015-05-05 10:36:30 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:30 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:30 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:30 CTS FIX: Disconnected. | 2015-05-05 10:36:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:30 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:33 CTS FIX - Firm: CTS | 2015-05-05 10:36:33 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:33 CTS FIX socket (18) | Connected. | 2015-05-05 10:36:33 CTS FIX socket (18) | Starting SSL connection. | 2015-05-05 10:36:33 CTS FIX socket (18) | SSL connection established. | 2015-05-05 10:36:34 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:34 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:34 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:34 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:34 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:34 CTS FIX socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:34 CTS FIX socket (18) | SSL has been shut down. | 2015-05-05 10:36:34 CTS FIX socket (18) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:34 CTS FIX socket (18) | Shutdown and closed. | 2015-05-05 10:36:34 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:34 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:34 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:34 CTS FIX: Disconnected. | 2015-05-05 10:36:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:34 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:37 CTS FIX - Firm: CTS | 2015-05-05 10:36:37 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:37 CTS FIX socket (19) | Connected. | 2015-05-05 10:36:37 CTS FIX socket (19) | Starting SSL connection. | 2015-05-05 10:36:37 CTS FIX socket (19) | SSL connection established. | 2015-05-05 10:36:37 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:37 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:37 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:37 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:37 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:37 CTS FIX socket (19) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:37 CTS FIX socket (19) | SSL has been shut down. | 2015-05-05 10:36:37 CTS FIX socket (19) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:37 CTS FIX socket (19) | Shutdown and closed. | 2015-05-05 10:36:37 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:38 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:38 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:38 CTS FIX: Disconnected. | 2015-05-05 10:36:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:38 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:41 CTS FIX - Firm: CTS | 2015-05-05 10:36:41 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:41 CTS FIX socket (20) | Connected. | 2015-05-05 10:36:41 CTS FIX socket (20) | Starting SSL connection. | 2015-05-05 10:36:41 CTS FIX socket (20) | SSL connection established. | 2015-05-05 10:36:41 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:41 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:41 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:41 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:41 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:41 CTS FIX socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:41 CTS FIX socket (20) | SSL has been shut down. | 2015-05-05 10:36:41 CTS FIX socket (20) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:41 CTS FIX socket (20) | Shutdown and closed. | 2015-05-05 10:36:41 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:41 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:41 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:41 CTS FIX: Disconnected. | 2015-05-05 10:36:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:41 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:44 CTS FIX - Firm: CTS | 2015-05-05 10:36:44 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:44 CTS FIX socket (21) | Connected. | 2015-05-05 10:36:44 CTS FIX socket (21) | Starting SSL connection. | 2015-05-05 10:36:44 CTS FIX socket (21) | SSL connection established. | 2015-05-05 10:36:44 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:45 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:45 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:45 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:45 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:45 CTS FIX socket (21) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:45 CTS FIX socket (21) | SSL has been shut down. | 2015-05-05 10:36:45 CTS FIX socket (21) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:45 CTS FIX socket (21) | Shutdown and closed. | 2015-05-05 10:36:45 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:45 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:45 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:45 CTS FIX: Disconnected. | 2015-05-05 10:36:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:45 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:48 CTS FIX - Firm: CTS | 2015-05-05 10:36:48 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:48 CTS FIX socket (22) | Connected. | 2015-05-05 10:36:48 CTS FIX socket (22) | Starting SSL connection. | 2015-05-05 10:36:48 CTS FIX socket (22) | SSL connection established. | 2015-05-05 10:36:48 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:48 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:49 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:49 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:49 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:49 CTS FIX socket (22) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:49 CTS FIX socket (22) | SSL has been shut down. | 2015-05-05 10:36:49 CTS FIX socket (22) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:49 CTS FIX socket (22) | Shutdown and closed. | 2015-05-05 10:36:49 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:49 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:49 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:49 CTS FIX: Disconnected. | 2015-05-05 10:36:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:49 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:52 CTS FIX - Firm: CTS | 2015-05-05 10:36:52 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:52 CTS FIX socket (23) | Connected. | 2015-05-05 10:36:52 CTS FIX socket (23) | Starting SSL connection. | 2015-05-05 10:36:52 CTS FIX socket (23) | SSL connection established. | 2015-05-05 10:36:52 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:52 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:52 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:52 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:52 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:52 CTS FIX socket (23) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:52 CTS FIX socket (23) | SSL has been shut down. | 2015-05-05 10:36:52 CTS FIX socket (23) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:52 CTS FIX socket (23) | Shutdown and closed. | 2015-05-05 10:36:52 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:52 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:52 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:52 CTS FIX: Disconnected. | 2015-05-05 10:36:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:52 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:55 CTS FIX - Firm: CTS | 2015-05-05 10:36:55 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:36:55 CTS FIX socket (24) | Connected. | 2015-05-05 10:36:55 CTS FIX socket (24) | Starting SSL connection. | 2015-05-05 10:36:55 CTS FIX socket (24) | SSL connection established. | 2015-05-05 10:36:56 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:56 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:56 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:56 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:56 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:56 CTS FIX socket (24) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:56 CTS FIX socket (24) | SSL has been shut down. | 2015-05-05 10:36:56 CTS FIX socket (24) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:56 CTS FIX socket (24) | Shutdown and closed. | 2015-05-05 10:36:56 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:56 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:56 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:56 CTS FIX: Disconnected. | 2015-05-05 10:36:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:56 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:36:59 CTS FIX - Firm: CTS | 2015-05-05 10:36:59 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:36:59 CTS FIX socket (25) | Connected. | 2015-05-05 10:36:59 CTS FIX socket (25) | Starting SSL connection. | 2015-05-05 10:36:59 CTS FIX socket (25) | SSL connection established. | 2015-05-05 10:36:59 CTS FIX: Sending the Logon message. | 2015-05-05 10:36:59 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:36:59 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:36:59 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:36:59 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:36:59 CTS FIX socket (25) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:36:59 CTS FIX socket (25) | SSL has been shut down. | 2015-05-05 10:36:59 CTS FIX socket (25) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:36:59 CTS FIX socket (25) | Shutdown and closed. | 2015-05-05 10:36:59 CTS FIX: Logged out and disconnected. | 2015-05-05 10:36:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:36:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:36:59 CTS FIX: DisconnectFIX called. | 2015-05-05 10:36:59 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:36:59 CTS FIX: Disconnected. | 2015-05-05 10:36:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:36:59 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:02 CTS FIX - Firm: CTS | 2015-05-05 10:37:02 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:37:02 CTS FIX socket (26) | Connected. | 2015-05-05 10:37:03 CTS FIX socket (26) | Starting SSL connection. | 2015-05-05 10:37:03 CTS FIX socket (26) | SSL connection established. | 2015-05-05 10:37:03 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:03 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:03 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:03 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:03 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:03 CTS FIX socket (26) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:03 CTS FIX socket (26) | SSL has been shut down. | 2015-05-05 10:37:03 CTS FIX socket (26) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:03 CTS FIX socket (26) | Shutdown and closed. | 2015-05-05 10:37:03 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:03 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:03 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:03 CTS FIX: Disconnected. | 2015-05-05 10:37:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:03 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:06 CTS FIX - Firm: CTS | 2015-05-05 10:37:06 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:37:06 CTS FIX socket (27) | Connected. | 2015-05-05 10:37:06 CTS FIX socket (27) | Starting SSL connection. | 2015-05-05 10:37:06 CTS FIX socket (27) | SSL connection established. | 2015-05-05 10:37:06 The above has been sent to support. | 2015-05-05 10:37:06 * CTS FIX: Sending the Logon message. | 2015-05-05 10:37:07 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:07 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:07 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:07 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:07 CTS FIX socket (27) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:07 CTS FIX socket (27) | SSL has been shut down. | 2015-05-05 10:37:07 CTS FIX socket (27) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:07 CTS FIX socket (27) | Shutdown and closed. | 2015-05-05 10:37:07 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:07 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:07 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:07 CTS FIX: Disconnected. | 2015-05-05 10:37:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:07 Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2015-05-05 10:37:08 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:10 CTS FIX - Firm: CTS | 2015-05-05 10:37:10 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:10 CTS FIX socket (28) | Connected. | 2015-05-05 10:37:10 CTS FIX socket (28) | Starting SSL connection. | 2015-05-05 10:37:10 CTS FIX socket (28) | SSL connection established. | 2015-05-05 10:37:10 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:10 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:10 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:10 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:10 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:10 CTS FIX socket (28) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:10 CTS FIX socket (28) | SSL has been shut down. | 2015-05-05 10:37:10 CTS FIX socket (28) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:10 CTS FIX socket (28) | Shutdown and closed. | 2015-05-05 10:37:10 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:10 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:10 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:10 CTS FIX: Disconnected. | 2015-05-05 10:37:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:10 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:13 CTS FIX - Firm: CTS | 2015-05-05 10:37:13 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:13 CTS FIX socket (29) | Connected. | 2015-05-05 10:37:14 CTS FIX socket (29) | Starting SSL connection. | 2015-05-05 10:37:14 CTS FIX socket (29) | SSL connection established. | 2015-05-05 10:37:14 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:14 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:14 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:14 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:14 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:14 CTS FIX socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:14 CTS FIX socket (29) | SSL has been shut down. | 2015-05-05 10:37:14 CTS FIX socket (29) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:14 CTS FIX socket (29) | Shutdown and closed. | 2015-05-05 10:37:14 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:14 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:14 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:14 CTS FIX: Disconnected. | 2015-05-05 10:37:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:14 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:17 CTS FIX - Firm: CTS | 2015-05-05 10:37:17 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:17 CTS FIX socket (30) | Connected. | 2015-05-05 10:37:17 CTS FIX socket (30) | Starting SSL connection. | 2015-05-05 10:37:17 CTS FIX socket (30) | SSL connection established. | 2015-05-05 10:37:17 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:18 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:18 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:18 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:18 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:18 CTS FIX socket (30) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:18 CTS FIX socket (30) | SSL has been shut down. | 2015-05-05 10:37:18 CTS FIX socket (30) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:18 CTS FIX socket (30) | Shutdown and closed. | 2015-05-05 10:37:18 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:18 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:18 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:18 CTS FIX: Disconnected. | 2015-05-05 10:37:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:18 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:21 CTS FIX - Firm: CTS | 2015-05-05 10:37:21 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:21 CTS FIX socket (31) | Connected. | 2015-05-05 10:37:21 CTS FIX socket (31) | Starting SSL connection. | 2015-05-05 10:37:21 CTS FIX socket (31) | SSL connection established. | 2015-05-05 10:37:21 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:21 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:22 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:22 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:22 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:22 CTS FIX socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:22 CTS FIX socket (31) | SSL has been shut down. | 2015-05-05 10:37:22 CTS FIX socket (31) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:22 CTS FIX socket (31) | Shutdown and closed. | 2015-05-05 10:37:22 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:22 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:22 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:22 CTS FIX: Disconnected. | 2015-05-05 10:37:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:22 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:25 CTS FIX - Firm: CTS | 2015-05-05 10:37:25 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:25 CTS FIX socket (32) | Connected. | 2015-05-05 10:37:25 CTS FIX socket (32) | Starting SSL connection. | 2015-05-05 10:37:25 CTS FIX socket (32) | SSL connection established. | 2015-05-05 10:37:25 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:25 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:25 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:25 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:25 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:25 CTS FIX socket (32) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:25 CTS FIX socket (32) | SSL has been shut down. | 2015-05-05 10:37:25 CTS FIX socket (32) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:25 CTS FIX socket (32) | Shutdown and closed. | 2015-05-05 10:37:25 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:25 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:25 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:25 CTS FIX: Disconnected. | 2015-05-05 10:37:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:25 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:28 CTS FIX - Firm: CTS | 2015-05-05 10:37:28 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:28 CTS FIX socket (33) | Connected. | 2015-05-05 10:37:28 CTS FIX socket (33) | Starting SSL connection. | 2015-05-05 10:37:28 CTS FIX socket (33) | SSL connection established. | 2015-05-05 10:37:29 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:29 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:29 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:29 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:29 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:29 CTS FIX socket (33) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:29 CTS FIX socket (33) | SSL has been shut down. | 2015-05-05 10:37:29 CTS FIX socket (33) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:29 CTS FIX socket (33) | Shutdown and closed. | 2015-05-05 10:37:29 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:29 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:29 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:29 CTS FIX: Disconnected. | 2015-05-05 10:37:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:29 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:32 CTS FIX - Firm: CTS | 2015-05-05 10:37:32 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:32 CTS FIX socket (34) | Connected. | 2015-05-05 10:37:32 CTS FIX socket (34) | Starting SSL connection. | 2015-05-05 10:37:32 CTS FIX socket (34) | SSL connection established. | 2015-05-05 10:37:32 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:32 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:32 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:32 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:32 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:32 CTS FIX socket (34) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:32 CTS FIX socket (34) | SSL has been shut down. | 2015-05-05 10:37:32 CTS FIX socket (34) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:32 CTS FIX socket (34) | Shutdown and closed. | 2015-05-05 10:37:32 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:32 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:32 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:32 CTS FIX: Disconnected. | 2015-05-05 10:37:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:32 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:36 CTS FIX - Firm: CTS | 2015-05-05 10:37:36 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:37:36 CTS FIX socket (35) | Connected. | 2015-05-05 10:37:36 CTS FIX socket (35) | Starting SSL connection. | 2015-05-05 10:37:36 CTS FIX socket (35) | SSL connection established. | 2015-05-05 10:37:36 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:36 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:37 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:37 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:37 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:37 CTS FIX socket (35) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:37 CTS FIX socket (35) | SSL has been shut down. | 2015-05-05 10:37:37 CTS FIX socket (35) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:37 CTS FIX socket (35) | Shutdown and closed. | 2015-05-05 10:37:37 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:37 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:37 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:37 CTS FIX: Disconnected. | 2015-05-05 10:37:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:37 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:40 CTS FIX - Firm: CTS | 2015-05-05 10:37:40 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:37:40 CTS FIX socket (36) | Connected. | 2015-05-05 10:37:40 CTS FIX socket (36) | Starting SSL connection. | 2015-05-05 10:37:40 CTS FIX socket (36) | SSL connection established. | 2015-05-05 10:37:41 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:41 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:41 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:41 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:41 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:41 CTS FIX socket (36) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:41 CTS FIX socket (36) | SSL has been shut down. | 2015-05-05 10:37:41 CTS FIX socket (36) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:41 CTS FIX socket (36) | Shutdown and closed. | 2015-05-05 10:37:41 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:41 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:41 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:41 CTS FIX: Disconnected. | 2015-05-05 10:37:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:41 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:44 CTS FIX - Firm: CTS | 2015-05-05 10:37:44 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-05 10:37:44 CTS FIX socket (37) | Connected. | 2015-05-05 10:37:44 CTS FIX socket (37) | Starting SSL connection. | 2015-05-05 10:37:44 CTS FIX socket (37) | SSL connection established. | 2015-05-05 10:37:44 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:44 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:44 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:44 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:44 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:44 CTS FIX socket (37) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:44 CTS FIX socket (37) | SSL has been shut down. | 2015-05-05 10:37:44 CTS FIX socket (37) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:44 CTS FIX socket (37) | Shutdown and closed. | 2015-05-05 10:37:44 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:44 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:44 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:44 CTS FIX: Disconnected. | 2015-05-05 10:37:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:44 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:47 CTS FIX - Firm: CTS | 2015-05-05 10:37:47 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:48 CTS FIX socket (38) | Connected. | 2015-05-05 10:37:48 CTS FIX socket (38) | Starting SSL connection. | 2015-05-05 10:37:48 CTS FIX socket (38) | SSL connection established. | 2015-05-05 10:37:48 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:48 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:48 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:48 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:48 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:48 CTS FIX socket (38) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:48 CTS FIX socket (38) | SSL has been shut down. | 2015-05-05 10:37:48 CTS FIX socket (38) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:48 CTS FIX socket (38) | Shutdown and closed. | 2015-05-05 10:37:48 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:48 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:48 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:48 CTS FIX: Disconnected. | 2015-05-05 10:37:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:48 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:51 CTS FIX - Firm: CTS | 2015-05-05 10:37:51 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:51 CTS FIX socket (39) | Connected. | 2015-05-05 10:37:51 CTS FIX socket (39) | Starting SSL connection. | 2015-05-05 10:37:51 CTS FIX socket (39) | SSL connection established. | 2015-05-05 10:37:52 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:52 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:52 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:52 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:52 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:52 CTS FIX socket (39) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:52 CTS FIX socket (39) | SSL has been shut down. | 2015-05-05 10:37:52 CTS FIX socket (39) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:52 CTS FIX socket (39) | Shutdown and closed. | 2015-05-05 10:37:52 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:52 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:52 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:52 CTS FIX: Disconnected. | 2015-05-05 10:37:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:52 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:55 CTS FIX - Firm: CTS | 2015-05-05 10:37:55 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:55 CTS FIX socket (40) | Connected. | 2015-05-05 10:37:55 CTS FIX socket (40) | Starting SSL connection. | 2015-05-05 10:37:55 CTS FIX socket (40) | SSL connection established. | 2015-05-05 10:37:55 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:55 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:56 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:56 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:56 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:56 CTS FIX socket (40) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:56 CTS FIX socket (40) | SSL has been shut down. | 2015-05-05 10:37:56 CTS FIX socket (40) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:56 CTS FIX socket (40) | Shutdown and closed. | 2015-05-05 10:37:56 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:56 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:56 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:56 CTS FIX: Disconnected. | 2015-05-05 10:37:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:56 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:37:59 CTS FIX - Firm: CTS | 2015-05-05 10:37:59 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:37:59 CTS FIX socket (41) | Connected. | 2015-05-05 10:37:59 CTS FIX socket (41) | Starting SSL connection. | 2015-05-05 10:37:59 CTS FIX socket (41) | SSL connection established. | 2015-05-05 10:37:59 CTS FIX: Sending the Logon message. | 2015-05-05 10:37:59 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:37:59 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:37:59 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:37:59 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:37:59 CTS FIX socket (41) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:37:59 CTS FIX socket (41) | SSL has been shut down. | 2015-05-05 10:37:59 CTS FIX socket (41) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:37:59 CTS FIX socket (41) | Shutdown and closed. | 2015-05-05 10:37:59 CTS FIX: Logged out and disconnected. | 2015-05-05 10:37:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:37:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:37:59 CTS FIX: DisconnectFIX called. | 2015-05-05 10:37:59 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:37:59 CTS FIX: Disconnected. | 2015-05-05 10:37:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:37:59 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-05 10:38:02 CTS FIX - Firm: CTS | 2015-05-05 10:38:02 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-05 10:38:02 CTS FIX socket (42) | Connected. | 2015-05-05 10:38:02 CTS FIX socket (42) | Starting SSL connection. | 2015-05-05 10:38:02 CTS FIX socket (42) | SSL connection established. | 2015-05-05 10:38:03 CTS FIX: Sending the Logon message. | 2015-05-05 10:38:03 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:38:03 CTS FIX: Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2015-05-05 10:38:03 * CTS FIX: One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2015-05-05 10:38:03 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2015-05-05 10:38:03 CTS FIX socket (42) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-05 10:38:03 CTS FIX socket (42) | SSL has been shut down. | 2015-05-05 10:38:03 CTS FIX socket (42) | SSL object has been freed. SSL state is now disconnected. | 2015-05-05 10:38:03 CTS FIX socket (42) | Shutdown and closed. | 2015-05-05 10:38:03 CTS FIX: Logged out and disconnected. | 2015-05-05 10:38:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-05-05 10:38:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-05-05 10:38:03 CTS FIX: DisconnectFIX called. | 2015-05-05 10:38:03 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-05 10:38:03 CTS FIX: Disconnected. | 2015-05-05 10:38:03 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-05-05 10:38:03 |
[2015-05-05 16:37:46] |
This is the relevant error message: CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2015-05-05 10:38:03
Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
