Date/Time: Wed, 25 Nov 2026 23:19:58 +0000
Data not loading
View Count: 1873
| [2015-04-27 07:33:25] |
| TradingSignalsSoftware - Posts: 35 |
I switched over from IQ feed to Barchart feed, but my charts are not updating they are stuck on the 23rd April 2015. The feed connection is showing green so its connected. I have already tried logging out and logging back in, that didn't work. Date Time Of Last Edit: 2015-04-27 07:50:10
| [2015-04-27 07:53:05] |
Make sure the charts are using the correct symbols. For more information, refer to this section here: https://www.sierrachart.com/index.php?page=doc/helpdetails1.html#h1.3 With the Barchart Data Service you will not get a symbol error, but you may be using a symbol which is not supported on the Barchart Data Service. You will see the supported symbols in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-27 08:18:58] |
I am using the correct symbols as I am finding the symbols in the symbol find box. For example for YM futures the symbol with barcharts is YMM15 but the data loads up to certain time and then gets stuck and doesn't update. |
| [2015-04-27 08:43:21] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-27 08:49:13] |
Software version: 1246 | 2015-04-27 02:54:41 Uses New Spreadsheets | 2015-04-27 02:54:41 Usage end date: 2015-04-30 | 2015-04-27 02:54:41 Enabled for: Advanced Features. | 2015-04-27 02:54:41 Enabled for: Advanced Features 2. | 2015-04-27 02:54:41 Enabled for: Sierra Chart Historical Data Service. | 2015-04-27 02:54:41 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-04-27 02:54:41 Active service: Barchart | 2015-04-27 02:54:41 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-04-27 02:54:41 2015-04-27 02:54:41 Local computer clock time | 2015-04-27 02:54:41 2015-04-27 06:54:41 GMT time | 2015-04-27 02:54:41 2015-04-27 02:54:41 Time zone adjusted time | 2015-04-27 02:54:41 Time difference to server time: 1 seconds. | 2015-04-27 02:54:41 Program path: C:\SierraChart\ | 2015-04-27 02:54:41 Data Files path: C:\SierraChart\Data\ | 2015-04-27 02:54:41 OS Version Number: 6.1 | 2015-04-27 02:54:41 Locale Information: C | 2015-04-27 02:54:41 Checking for new symbol settings for ddf | 2015-04-27 02:54:41 Notice: 3 days of full use remaining. To continue full use the software and services, | 2015-04-27 02:54:42 purchase more usage time by selecting 'Help >> Add Usage Credit' on the menu. | 2015-04-27 02:54:42 * HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-04-27 02:54:42 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-04-27 02:54:42 Symbol settings are up-to-date for ddf | 2015-04-27 02:54:42 Downloading user file: Kalyani.dll | 2015-04-27 02:54:43 File has been written to: C:\SierraChart\Data\Kalyani.dll. File Size: 342528 bytes. | 2015-04-27 02:54:44 Barchart | Verifying status of username. | 2015-04-27 02:54:47 Barchart | Requesting user settings from http://www.ddfplus.com for SCMSATHWAL | 2015-04-27 02:54:47 Barchart | User settings received. | 2015-04-27 02:54:47 Barchart | Authorized exchanges: CME,IOM,IMM,GBLX,EUREX,FOREX,INDEX-CFE,INDEX-CBOE,INDEX-DOW,NYMEX,NYMI | 2015-04-27 02:54:47 Barchart | Connecting to server qs-us-e-01.aws.barchart.com:7500 | 2015-04-27 02:54:47 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-04-27 02:54:48 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-04-27 02:54:48 Socket (0) | Resolved address qs-us-e-01.aws.barchart.com to IP 50.16.236.240 | 2015-04-27 02:54:48 Socket (2) | Connected. | 2015-04-27 02:54:48 Barchart | Sending the LOGIN command. | 2015-04-27 02:54:48 Barchart | Sending the VERSION command. | 2015-04-27 02:54:48 Barchart | Connected. | 2015-04-27 02:54:48 Barchart | Info Message: + Version set to 3. | 2015-04-27 02:54:48 Chart #3 has tagged chart #2 for full recalculation. Chartbook: Sierra Signal Box Alerts = FTSE.cht | 2015-04-27 02:55:03 Chart #3 has tagged chart #2 for full recalculation. Chartbook: Sierra Signal Box Alerts = FTSE.cht | 2015-04-27 02:55:03 Barchart | Starting real-time market data updates for: XM15. ID: 1 | 2015-04-27 02:55:03 Barchart - Subscribe to symbol XM15. Barchart Symbol: XM5 | 2015-04-27 02:55:03 Removed historical data download ID 12 | 2015-04-27 03:50:02 Real-time Intraday chart data file updates started for @ES# | 2015-04-27 03:50:02 Chart #9 has tagged chart #16 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #1 has tagged chart #15 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #3 has tagged chart #16 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #16 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Barchart | Starting real-time market data updates for: @YM#. ID: 10 | 2015-04-27 03:50:02 Barchart - Subscribe to symbol @YM#. Barchart Symbol: @YM# | 2015-04-27 03:50:02 Intraday data recording state for symbol @YM# is set to download pending. | 2015-04-27 03:50:02 HD Request # 18 | Downloading Intraday chart data for @YM# to the file @YM#.scid. Service: ddf | 2015-04-27 03:50:02 HD Request # 18 | Download start Date-Time: 2015-04-24 15:55:01.0 | 2015-04-27 03:50:02 HD Request # 18 | Using user Barchart Historical data account. | 2015-04-27 03:50:02 HD Request # 18 | Error downloading historical Intraday data for @YM#. Continuous contract symbols not supported for Intraday data | 2015-04-27 03:50:02 * HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @YM# | 2015-04-27 03:50:02 HD Request # 18 | Intraday download COMPLETE for @YM#. Completion time: 0s. Unique request ID: 13 | 2015-04-27 03:50:02 Removed historical data download ID 13 | 2015-04-27 03:50:02 Real-time Intraday chart data file updates started for @YM# | 2015-04-27 03:50:02 Chart #5 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #8 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #10 has tagged chart #15 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #11 has tagged chart #16 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #16 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #4 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:50:02 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:50:03 Chart #4 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:51:35 Chart #4 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:51:35 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:51:35 Chart #4 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:51:36 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:51:36 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMM15.scid | 2015-04-27 03:52:38 Barchart | Starting real-time market data updates for: YMM15. ID: 11 | 2015-04-27 03:52:38 Barchart - Subscribe to symbol YMM15. Barchart Symbol: YMM5 | 2015-04-27 03:52:38 Intraday data recording state for symbol YMM15 is set to download pending. | 2015-04-27 03:52:38 HD Request # 19 | Downloading Intraday chart data for YMM15 to the file YMM15.scid. Service: ddf | 2015-04-27 03:52:38 Compressing file: C:\SierraChart\Data\YMM15.scid. This may take a while. | 2015-04-27 03:52:38 HD Request # 19 | Performing multistage download. Downloading Minute data first. | 2015-04-27 03:52:38 HD Request # 19 | Download start Date-Time: 2014-10-23 03:52:38.0 | 2015-04-27 03:52:38 HD Request # 19 | Disabling Intraday chart updating for symbol during historical data download. | 2015-04-27 03:52:38 HD Request # 19 | Using user Barchart Historical data account. | 2015-04-27 03:52:38 HD Request # 19 | Requesting historical Intraday Minute data for YMM15 starting at 2014-10-23 02:52:38 (Exchange time). | 2015-04-27 03:52:38 Notice: The Barchart Data service has indicated real-time data is not available for the symbol: YMM15 | 2015-04-27 03:52:39 HD Request # 19 | Receiving Intraday data for YMM15 starting at 2014-10-28 06:51:00 | 2015-04-27 03:52:39 HD Request # 19 | Timestamp of first Intraday data file record written: 2014-10-28 06:51:00 | 2015-04-27 03:52:39 HD Request # 19 | Received 42524 records from 2014-10-28 06:51:00 to 2015-04-27 03:42:00 (180.9 days) and wrote 42524 records for YMM15 | 2015-04-27 03:52:42 HD Request # 19 | Intraday download COMPLETE for YMM15. Completion time: 4s. Unique request ID: 14 | 2015-04-27 03:52:42 HD Request # 20 | Downloading Intraday chart data for YMM15 to the file YMM15.scid. Service: ddf | 2015-04-27 03:52:42 HD Request # 20 | Rounding start Date-Time down to the minute: 2014-10-23 03:52:00.0 | 2015-04-27 03:52:42 HD Request # 20 | Download start Date-Time: 2014-10-23 03:52:00.0 | 2015-04-27 03:52:42 HD Request # 20 | Using user Barchart Historical data account. | 2015-04-27 03:52:42 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-03-27 02:52:38 (Exchange time). | 2015-04-27 03:52:42 HD Request # 20 | Receiving Intraday data for YMM15 starting at 2015-03-27 03:52:38 | 2015-04-27 03:52:43 HD Request # 20 | Truncating Intraday data file at 2015-03-27 03:52:38 while receiving initial tick data during multistage download. | 2015-04-27 03:52:43 HD Request # 20 | Date-time after truncate 2015-03-27 03:52:00 | 2015-04-27 03:52:43 HD Request # 20 | Timestamp of first Intraday data file record written: 2015-03-27 03:52:38 | 2015-04-27 03:52:43 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-03-28 00:00:00 (Exchange time). | 2015-04-27 03:52:47 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-03-29 00:00:00 (Exchange time). | 2015-04-27 03:52:47 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-03-30 00:00:00 (Exchange time). | 2015-04-27 03:52:48 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-03-31 00:00:00 (Exchange time). | 2015-04-27 03:52:54 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-01 00:00:00 (Exchange time). | 2015-04-27 03:52:59 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-02 00:00:00 (Exchange time). | 2015-04-27 03:53:05 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-03 00:00:00 (Exchange time). | 2015-04-27 03:53:08 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-04 00:00:00 (Exchange time). | 2015-04-27 03:53:08 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-05 00:00:00 (Exchange time). | 2015-04-27 03:53:08 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-06 00:00:00 (Exchange time). | 2015-04-27 03:53:09 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-07 00:00:00 (Exchange time). | 2015-04-27 03:53:12 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-08 00:00:00 (Exchange time). | 2015-04-27 03:53:15 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-09 00:00:00 (Exchange time). | 2015-04-27 03:53:19 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-10 00:00:00 (Exchange time). | 2015-04-27 03:53:23 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-11 00:00:00 (Exchange time). | 2015-04-27 03:53:25 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-12 00:00:00 (Exchange time). | 2015-04-27 03:53:26 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-13 00:00:00 (Exchange time). | 2015-04-27 03:53:26 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-14 00:00:00 (Exchange time). | 2015-04-27 03:53:33 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-15 00:00:00 (Exchange time). | 2015-04-27 03:53:37 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-16 00:00:00 (Exchange time). | 2015-04-27 03:53:41 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-17 00:00:00 (Exchange time). | 2015-04-27 03:53:44 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-18 00:00:00 (Exchange time). | 2015-04-27 03:53:50 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-19 00:00:00 (Exchange time). | 2015-04-27 03:53:50 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-20 00:00:00 (Exchange time). | 2015-04-27 03:53:50 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-21 00:00:00 (Exchange time). | 2015-04-27 03:53:59 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-22 00:00:00 (Exchange time). | 2015-04-27 03:54:04 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-23 00:00:00 (Exchange time). | 2015-04-27 03:54:08 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-24 00:00:00 (Exchange time). | 2015-04-27 03:54:13 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-25 00:00:00 (Exchange time). | 2015-04-27 03:54:15 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-26 00:00:00 (Exchange time). | 2015-04-27 03:54:15 HD Request # 20 | Requesting historical Intraday Tick data for YMM15 starting at 2015-04-27 00:00:00 (Exchange time). | 2015-04-27 03:54:16 HD Request # 20 | Received 1853601 records from 2015-03-27 03:52:38 to 2015-04-27 03:44:02 (31.0 days) and wrote 1853601 records for YMM15 | 2015-04-27 03:54:16 HD Request # 20 | Intraday download COMPLETE for YMM15. Completion time: 1m 34s. Unique request ID: 14 | 2015-04-27 03:54:16 Removed historical data download ID 14 | 2015-04-27 03:54:16 Real-time Intraday chart data file updates started for YMM15 | 2015-04-27 03:54:16 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2015-04-27 03:54:16 HD Request # 20 | Reloading Intraday charts for symbol. | 2015-04-27 03:54:16 Reloading all charts with filename: YMM15.scid | 2015-04-27 03:54:16 Chart #4 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:54:17 Chart #4 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:54:17 Chart #4 has tagged chart #6 for full recalculation. Chartbook: futures signal box.cht | 2015-04-27 03:54:17 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: futures signal box.cht | 2015-04-27 03:54:17 Current selected Data/Trading service: Barchart | 2015-04-27 04:22:14 Date Time Of Last Edit: 2015-04-27 09:45:48
| [2015-04-27 09:47:04] |
The problem is not completely clear to us. Could you contact Barchart and see if among these authorized exchanges you can get real-time data for the YM futures Barchart | Authorized exchanges: CME,IOM,IMM,GBLX,EUREX,FOREX,INDEX-CFE,INDEX-CBOE,INDEX-DOW,NYMEX,NYMI | If so, then refer to help topic 3 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-27 10:21:47] |
they have told me the YM feed is through the CM exchange and everything is good on their end. The issue is with sierra
| [2015-04-27 10:30:38] |
We want to know if you are receiving real-time data from the data feed for that symbol. Follow the instructions in help topic 3.4 to determine this and let us know what you determine: http://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-27 10:35:13] |
Yes they have advised me I am on realtime feed. Here is everything I have subscribed to and paying for Service Fee 100 Symbol Limit $49.00 Exchange Fees CBOE Indices Streaming $3.00 CME Streaming $90.00 Dow Jones Indices Streaming $3.00 U.S. Equities Streaming (Non-Professional) $10.00 LIFFE Streaming $95.00 Eurex Streaming (Non-professional) $15.00 Forex Streaming $20.00 Russell Indices Streaming (Non-Professional) $3.00 NYSE Indices Streaming $3.00 NYMEX Streaming $90.00 Nasdaq Indices Streaming $3.00 S&P Indices Streaming $3.00 Total Monthly Fees: $387.00 |
| [2015-04-27 10:43:59] |
Now its not connecting at all |
| [2015-04-27 10:44:08] |
Software version: 1246 | 2015-04-27 02:54:41 Uses New Spreadsheets | 2015-04-27 02:54:41 Usage end date: 2015-04-30 | 2015-04-27 02:54:41 Enabled for: Advanced Features. | 2015-04-27 02:54:41 Enabled for: Advanced Features 2. | 2015-04-27 02:54:41 Enabled for: Sierra Chart Historical Data Service. | 2015-04-27 02:54:41 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-04-27 02:54:41 Active service: Barchart | 2015-04-27 02:54:41 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-04-27 02:54:41 2015-04-27 02:54:41 Local computer clock time | 2015-04-27 02:54:41 2015-04-27 06:54:41 GMT time | 2015-04-27 02:54:41 2015-04-27 02:54:41 Time zone adjusted time | 2015-04-27 02:54:41 Time difference to server time: 1 seconds. | 2015-04-27 02:54:41 Program path: C:\SierraChart\ | 2015-04-27 02:54:41 Data Files path: C:\SierraChart\Data\ | 2015-04-27 02:54:41 OS Version Number: 6.1 | 2015-04-27 02:54:41 Locale Information: C | 2015-04-27 02:54:41 Barchart | Verifying status of username. | 2015-04-27 06:42:34 Barchart | Requesting user settings from http://www.ddfplus.com for SCMSATHWAL | 2015-04-27 06:42:34 Barchart | User settings received. | 2015-04-27 06:42:34 c_SimpleXMLDocument::ReadFromMemory error: invalid closing tag name | 2015-04-27 06:42:34 * Barchart- Login status: | 2015-04-27 06:42:34 Barchart | Username or Password is not set correctly or are not currently active. Check these in 'Global Settings >> Data/Trade Service Settings'. | 2015-04-27 06:42:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-27 06:42:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-27 06:42:34 Barchart | Reset socket. | 2015-04-27 06:42:34 Barchart | Disconnected. | 2015-04-27 06:42:34 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-27 06:42:34 Barchart | Verifying status of username. | 2015-04-27 06:42:39 Barchart | Requesting user settings from http://www.ddfplus.com for SCMSATHWAL | 2015-04-27 06:42:39 Barchart | User settings received. | 2015-04-27 06:42:39 c_SimpleXMLDocument::ReadFromMemory error: invalid closing tag name | 2015-04-27 06:42:39 * Barchart- Login status: | 2015-04-27 06:42:39 Barchart | Username or Password is not set correctly or are not currently active. Check these in 'Global Settings >> Data/Trade Service Settings'. | 2015-04-27 06:42:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-27 06:42:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-27 06:42:39 Barchart | Reset socket. | 2015-04-27 06:42:39 Barchart | Disconnected. | 2015-04-27 06:42:39 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-27 06:42:39 Current selected Data/Trading service: Barchart | 2015-04-27 06:43:05 Date Time Of Last Edit: 2015-04-27 11:28:37
| [2015-04-27 11:01:28] |
| ehlaban - Posts: 50 |
Is this the problem? Barchart- Login status: | 2015-04-27 06:42:39 Barchart | Username or Password is not set correctly or are not currently active. Check these in 'Global Settings >> Data/Trade Service Settings'. | 2015-04-27 06:42:39 |
| [2015-04-27 11:31:40] |
Based upon post #9, you do not have the CBOT exchange activated and that is the problem of why you cannot get the YM data. Yes, the problem is the Username and Password are not set correctly in Global Settings >> Data/Trade Service Settings. Also for your information you can get the same data through the Sierra Chart Exchange Data Feed and have faster access to the historical data and more simplified access to the data. For more information, refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php You might want to consider this next month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-27 12:17:00] |
I have not suscribed to CBOT too. Which exchange do I need to activate to get S&P500 index data? And any idea where I can find the symbols for barcharts?
| [2015-04-27 16:49:47] |
The supported symbols are in File >> Find Symbol. The S&P 500 index is $INX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
