Date/Time: Fri, 10 May 2024 08:20:15 +0000
millisecond question
View Count: 797
[2015-04-17 16:55:09] |
onnb - Posts: 661 |
I had a chart where the ms portion for each bar was always 0 even though the bars were the same second. I was not connected to the data feed at this time. I then connected to the data feed and did a full reload/recalculate and the ms portion started to appear. Any idea why this is? Are there any special conditions that need to be met in order for the ms numbering to appear? |
[2015-04-17 17:33:56] |
We really have insufficient information. We would have to have the chart data file and actually test this. In general, what you describe does not make sense. Connecting to the data feed is not going to affect existing data already in the chart. And performing a Reload will not matter either.
