Date/Time: Tue, 07 May 2024 06:24:08 +0000
Avast software blocking download
View Count: 3736
[2013-05-31 16:41:44] |
moonmist - Posts: 127 |
Hi, I installed Avast Internet Security ( paid version ) on my old computer, and Avast Anti-vrius software ( free version ) on my new computer. I was able to download version 982 on both computers today without any problems. Date Time Of Last Edit: 2013-05-31 16:43:08
[2013-05-31 17:00:37] |
Sierra Chart - Max - Posts: 5607 |
Hello, we ran a test the release is as always clean. Please see: https://www.virustotal.com/en/file/254ab57894053da092493c69155084d4415d4c1b1d87ba053807b9e215bdf287/analysis/1370019491/ Make sure to either remove or fully update the AV software. Sierra Chart Support Date Time Of Last Edit: 2013-05-31 17:00:48
[2013-05-31 17:30:52] |
Disable the Anti-malware/antivirus software at the time Sierra Chart is being installed and also make sure its malware definition file is up-to-date.
[2013-05-31 18:45:56] |
I have been using Avast Internet Security since October 2011. It has never interfered with the download and installation of Sierra Chart. ( My old computer is running Windows 7 32-bit operating system. ) However, this software did cause far more serious problems before. I was forced to un-install it, and then re-install it several times. It can work perfectly for months, and then suddenly mess up due to a minor/regular update of virus definition. If you don't like surprises and/or un-install/re-install software, you may like to choose another internet security program. To be fair, it has been working perfectly for the past few months. Date Time Of Last Edit: 2013-05-31 23:29:20
[2013-05-31 20:24:17] |
M5amhan - Posts: 468 |
ive also had this problem but it was a bit different. i run sierra with transact, sierra opens automatically with transact trading software (its the only way it opens). avast kept blocking it as the highest level threat and i had to delete avast, uninstall sierra, and reinstall it into a new folder. i never touched avast again
