Date/Time: Tue, 24 May 2022 06:38:16 +0000
Cannot make trade, frozen button
View Count: 1338
[2013-05-29 17:37:19] |
User69888 - Posts: 7 |
When I open sierra, login screen comes up and goes away, logged in, charts up. When I press on button (looks like 8 sideways), the trading platform comes up ++++ then in red at the very bottom says failed login error 74 its cut off so can barely see
[2013-05-29 19:46:45] |
We need to see the Message Log. Provide it by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log If you cannot completely see the Message Log, select Window >> Reset Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-29 19:47:02
[2013-05-30 06:12:05] |
Software version: 981 | 2013-05-30 06:04:28 Current Service Package: 3 | 2013-05-30 06:04:28 Usage end date: 2013-06-22 | 2013-05-30 06:04:28 Sierra Chart Historical Data Service is included. | 2013-05-30 06:04:28 Active service: SC Forex Data (FXCM) | 2013-05-30 06:04:28 Time Zone: +00:00:00 (UTC+00) | 2013-05-30 06:04:28 2013-05-30 00:04:28 Local computer clock time | 2013-05-30 06:04:28 2013-05-30 06:04:28 GMT time | 2013-05-30 06:04:28 2013-05-30 06:04:28 Time zone adjusted time | 2013-05-30 06:04:28 Time difference to server time: 38 seconds. | 2013-05-30 06:04:28 WARNING: Your computer's clock is off by 38 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2013-05-30 06:04:28 Program path: C:\SierraChart2\ | 2013-05-30 06:04:28 Data Files path: C:\SierraChart2\Data\ | 2013-05-30 06:04:28 OS Version Number: 6.1 | 2013-05-30 06:04:28 Requesting symbol settings for scfxcm. Overwrite = on. | 2013-05-30 06:04:29 Request for symbol settings completed. | 2013-05-30 06:04:30 Processed received symbol settings | 2013-05-30 06:04:30 SC Forex Data (FXCM): Connecting to the market data server. | 2013-05-30 06:04:34 Using server: ds3.sierracharts.com, port 443 | 2013-05-30 06:04:34 SC Forex Data (FXCM) - Local market data port: 0 | 2013-05-30 06:04:34 The network socket is connected. | 2013-05-30 06:04:34 SC Forex Data (FXCM): Connected to market data server. Now authorizing. | 2013-05-30 06:04:34 SC Forex Data (FXCM): Connected. | 2013-05-30 06:04:34 Active service: Barchart | 2013-05-30 06:05:27 Disconnecting from data feed due to service change. | 2013-05-30 06:05:27 SC Forex Data (FXCM): Disconnected from the market data server. | 2013-05-30 06:05:27 SC Forex Data (FXCM): Disconnected from the market data server. | 2013-05-30 06:05:27 Barchart service: Connecting to server... | 2013-05-30 06:05:27 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:05:27 Barchart service: User settings received. | 2013-05-30 06:05:27 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:05:27 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:05:27 Requesting symbol settings for ddf. Overwrite = on. | 2013-05-30 06:05:28 The network socket is connected. | 2013-05-30 06:05:28 Barchart service: Sending the LOGIN command. | 2013-05-30 06:05:28 Barchart service: Sending the VERSION command. | 2013-05-30 06:05:28 Barchart service: Connected. | 2013-05-30 06:05:28 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:05:28 Request for symbol settings completed. | 2013-05-30 06:05:32 Processed received symbol settings | 2013-05-30 06:05:33 Barchart service: IP Lockout. 107.2.177.218:60549 | 2013-05-30 06:05:33 Connection to the service has been lost or not completed. | 2013-05-30 06:05:33 Socket closed. No error. | 2013-05-30 06:05:33 Barchart service: Reset socket. | 2013-05-30 06:05:33 Barchart service: Disconnected. | 2013-05-30 06:05:33 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:05:33 Barchart service: Connecting to server... | 2013-05-30 06:05:38 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:05:38 Barchart service: User settings received. | 2013-05-30 06:05:38 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:05:38 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:05:38 The network socket is connected. | 2013-05-30 06:05:38 Barchart service: Sending the LOGIN command. | 2013-05-30 06:05:38 Barchart service: Sending the VERSION command. | 2013-05-30 06:05:38 Barchart service: Connected. | 2013-05-30 06:05:39 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:05:39 Barchart service: IP Lockout. 107.2.177.218:60551 | 2013-05-30 06:05:44 Connection to the service has been lost or not completed. | 2013-05-30 06:05:44 Socket closed. No error. | 2013-05-30 06:05:44 Barchart service: Reset socket. | 2013-05-30 06:05:44 Barchart service: Disconnected. | 2013-05-30 06:05:44 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:05:44 Barchart service: Connecting to server... | 2013-05-30 06:05:49 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:05:49 Barchart service: User settings received. | 2013-05-30 06:05:49 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:05:49 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:05:49 The network socket is connected. | 2013-05-30 06:05:49 Barchart service: Sending the LOGIN command. | 2013-05-30 06:05:49 Barchart service: Sending the VERSION command. | 2013-05-30 06:05:49 Barchart service: Connected. | 2013-05-30 06:05:49 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:05:49 Barchart service: IP Lockout. 107.2.177.218:60553 | 2013-05-30 06:05:54 Connection to the service has been lost or not completed. | 2013-05-30 06:05:54 Socket closed. No error. | 2013-05-30 06:05:54 Barchart service: Reset socket. | 2013-05-30 06:05:54 Barchart service: Disconnected. | 2013-05-30 06:05:54 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:05:54 Barchart service: Connecting to server... | 2013-05-30 06:05:59 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:05:59 Barchart service: User settings received. | 2013-05-30 06:05:59 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:05:59 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:05:59 The network socket is connected. | 2013-05-30 06:06:00 Barchart service: Sending the LOGIN command. | 2013-05-30 06:06:00 Barchart service: Sending the VERSION command. | 2013-05-30 06:06:00 Barchart service: Connected. | 2013-05-30 06:06:00 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:06:00 Barchart service: IP Lockout. 107.2.177.218:60556 | 2013-05-30 06:06:05 Connection to the service has been lost or not completed. | 2013-05-30 06:06:05 Socket closed. No error. | 2013-05-30 06:06:05 Barchart service: Reset socket. | 2013-05-30 06:06:05 Barchart service: Disconnected. | 2013-05-30 06:06:05 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:06:05 Barchart service: Connecting to server... | 2013-05-30 06:06:10 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:06:10 Barchart service: User settings received. | 2013-05-30 06:06:10 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:06:10 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:06:10 The network socket is connected. | 2013-05-30 06:06:10 Barchart service: Sending the LOGIN command. | 2013-05-30 06:06:10 Barchart service: Sending the VERSION command. | 2013-05-30 06:06:10 Barchart service: Connected. | 2013-05-30 06:06:10 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:06:10 Barchart service: IP Lockout. 107.2.177.218:60558 | 2013-05-30 06:06:16 Connection to the service has been lost or not completed. | 2013-05-30 06:06:16 Socket closed. No error. | 2013-05-30 06:06:16 Barchart service: Reset socket. | 2013-05-30 06:06:16 Barchart service: Disconnected. | 2013-05-30 06:06:16 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:06:16 Barchart service: Connecting to server... | 2013-05-30 06:06:21 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:06:21 Barchart service: User settings received. | 2013-05-30 06:06:21 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:06:21 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:06:21 The network socket is connected. | 2013-05-30 06:06:21 Barchart service: Sending the LOGIN command. | 2013-05-30 06:06:21 Barchart service: Sending the VERSION command. | 2013-05-30 06:06:21 Barchart service: Connected. | 2013-05-30 06:06:21 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:06:21 Barchart service: IP Lockout. 107.2.177.218:60560 | 2013-05-30 06:06:26 Connection to the service has been lost or not completed. | 2013-05-30 06:06:26 Socket closed. No error. | 2013-05-30 06:06:26 Barchart service: Reset socket. | 2013-05-30 06:06:26 Barchart service: Disconnected. | 2013-05-30 06:06:26 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:06:26 Barchart service: Connecting to server... | 2013-05-30 06:06:31 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:06:31 Barchart service: User settings received. | 2013-05-30 06:06:31 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:06:31 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:06:31 The network socket is connected. | 2013-05-30 06:06:31 Barchart service: Sending the LOGIN command. | 2013-05-30 06:06:31 Barchart service: Sending the VERSION command. | 2013-05-30 06:06:31 Barchart service: Connected. | 2013-05-30 06:06:31 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:06:32 Barchart service: IP Lockout. 107.2.177.218:60562 | 2013-05-30 06:06:37 Connection to the service has been lost or not completed. | 2013-05-30 06:06:37 Socket closed. No error. | 2013-05-30 06:06:37 Barchart service: Reset socket. | 2013-05-30 06:06:37 Barchart service: Disconnected. | 2013-05-30 06:06:37 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:06:37 Barchart service: Connecting to server... | 2013-05-30 06:06:42 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:06:42 Barchart service: User settings received. | 2013-05-30 06:06:42 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:06:42 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:06:42 The network socket is connected. | 2013-05-30 06:06:42 Barchart service: Sending the LOGIN command. | 2013-05-30 06:06:42 Barchart service: Sending the VERSION command. | 2013-05-30 06:06:42 Barchart service: Connected. | 2013-05-30 06:06:42 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:06:42 Barchart service: IP Lockout. 107.2.177.218:60564 | 2013-05-30 06:06:47 Connection to the service has been lost or not completed. | 2013-05-30 06:06:47 Socket closed. No error. | 2013-05-30 06:06:47 Barchart service: Reset socket. | 2013-05-30 06:06:47 Barchart service: Disconnected. | 2013-05-30 06:06:47 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:06:47 Barchart service: Connecting to server... | 2013-05-30 06:06:52 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:06:52 Barchart service: User settings received. | 2013-05-30 06:06:52 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:06:52 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:06:52 The network socket is connected. | 2013-05-30 06:06:52 Barchart service: Sending the LOGIN command. | 2013-05-30 06:06:52 Barchart service: Sending the VERSION command. | 2013-05-30 06:06:52 Barchart service: Connected. | 2013-05-30 06:06:52 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:06:53 Barchart service: IP Lockout. 107.2.177.218:60565 | 2013-05-30 06:06:58 Connection to the service has been lost or not completed. | 2013-05-30 06:06:58 Socket closed. No error. | 2013-05-30 06:06:58 Barchart service: Reset socket. | 2013-05-30 06:06:58 Barchart service: Disconnected. | 2013-05-30 06:06:58 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:06:58 Barchart service: Connecting to server... | 2013-05-30 06:07:03 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:07:03 Barchart service: User settings received. | 2013-05-30 06:07:03 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:07:03 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:07:03 The network socket is connected. | 2013-05-30 06:07:03 Barchart service: Sending the LOGIN command. | 2013-05-30 06:07:03 Barchart service: Sending the VERSION command. | 2013-05-30 06:07:03 Barchart service: Connected. | 2013-05-30 06:07:03 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:07:04 Barchart service: IP Lockout. 107.2.177.218:60566 | 2013-05-30 06:07:09 Connection to the service has been lost or not completed. | 2013-05-30 06:07:09 Socket closed. No error. | 2013-05-30 06:07:09 Barchart service: Reset socket. | 2013-05-30 06:07:09 Barchart service: Disconnected. | 2013-05-30 06:07:09 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:07:09 Barchart service: Connecting to server... | 2013-05-30 06:07:14 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:07:14 Barchart service: User settings received. | 2013-05-30 06:07:14 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:07:14 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:07:14 The network socket is connected. | 2013-05-30 06:07:14 Barchart service: Sending the LOGIN command. | 2013-05-30 06:07:14 Barchart service: Sending the VERSION command. | 2013-05-30 06:07:14 Barchart service: Connected. | 2013-05-30 06:07:14 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:07:14 Barchart service: IP Lockout. 107.2.177.218:60568 | 2013-05-30 06:07:19 Connection to the service has been lost or not completed. | 2013-05-30 06:07:19 Socket closed. No error. | 2013-05-30 06:07:19 Barchart service: Reset socket. | 2013-05-30 06:07:19 Barchart service: Disconnected. | 2013-05-30 06:07:19 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:07:19 Barchart service: Connecting to server... | 2013-05-30 06:07:24 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:07:24 Barchart service: User settings received. | 2013-05-30 06:07:24 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:07:24 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:07:24 The network socket is connected. | 2013-05-30 06:07:24 Barchart service: Sending the LOGIN command. | 2013-05-30 06:07:25 Barchart service: Sending the VERSION command. | 2013-05-30 06:07:25 Barchart service: Connected. | 2013-05-30 06:07:25 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:07:25 Barchart service: IP Lockout. 107.2.177.218:60570 | 2013-05-30 06:07:30 Connection to the service has been lost or not completed. | 2013-05-30 06:07:30 Socket closed. No error. | 2013-05-30 06:07:30 Barchart service: Reset socket. | 2013-05-30 06:07:30 Barchart service: Disconnected. | 2013-05-30 06:07:30 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:07:30 Barchart service: Connecting to server... | 2013-05-30 06:07:35 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:07:35 Barchart service: User settings received. | 2013-05-30 06:07:35 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:07:35 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:07:35 The network socket is connected. | 2013-05-30 06:07:35 Barchart service: Sending the LOGIN command. | 2013-05-30 06:07:35 Barchart service: Sending the VERSION command. | 2013-05-30 06:07:35 Barchart service: Connected. | 2013-05-30 06:07:35 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:07:35 Barchart service: IP Lockout. 107.2.177.218:60571 | 2013-05-30 06:07:41 Connection to the service has been lost or not completed. | 2013-05-30 06:07:41 Socket closed. No error. | 2013-05-30 06:07:41 Barchart service: Reset socket. | 2013-05-30 06:07:41 Barchart service: Disconnected. | 2013-05-30 06:07:41 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:07:41 Barchart service: Connecting to server... | 2013-05-30 06:07:46 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:07:46 Barchart service: User settings received. | 2013-05-30 06:07:46 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:07:46 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:07:46 The network socket is connected. | 2013-05-30 06:07:46 Barchart service: Sending the LOGIN command. | 2013-05-30 06:07:46 Barchart service: Sending the VERSION command. | 2013-05-30 06:07:46 Barchart service: Connected. | 2013-05-30 06:07:46 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:07:46 Barchart service: IP Lockout. 107.2.177.218:60573 | 2013-05-30 06:07:51 Connection to the service has been lost or not completed. | 2013-05-30 06:07:51 Socket closed. No error. | 2013-05-30 06:07:51 Barchart service: Reset socket. | 2013-05-30 06:07:51 Barchart service: Disconnected. | 2013-05-30 06:07:51 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:07:51 A request for the latest software update has been made. | 2013-05-30 06:07:55 Downloading... You can continue to work during the download. | 2013-05-30 06:07:55 There is no new version available. Thank you. | 2013-05-30 06:07:55 Barchart service: Connecting to server... | 2013-05-30 06:07:56 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:07:56 Barchart service: User settings received. | 2013-05-30 06:07:56 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:07:56 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:07:56 The network socket is connected. | 2013-05-30 06:07:56 Barchart service: Sending the LOGIN command. | 2013-05-30 06:07:56 Barchart service: Sending the VERSION command. | 2013-05-30 06:07:56 Barchart service: Connected. | 2013-05-30 06:07:56 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:07:57 Barchart service: IP Lockout. 107.2.177.218:60574 | 2013-05-30 06:08:02 Connection to the service has been lost or not completed. | 2013-05-30 06:08:02 Socket closed. No error. | 2013-05-30 06:08:02 Barchart service: Reset socket. | 2013-05-30 06:08:02 Barchart service: Disconnected. | 2013-05-30 06:08:02 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:08:02 Barchart service: Connecting to server... | 2013-05-30 06:08:07 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:08:07 Barchart service: User settings received. | 2013-05-30 06:08:07 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:08:07 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:08:07 The network socket is connected. | 2013-05-30 06:08:07 Barchart service: Sending the LOGIN command. | 2013-05-30 06:08:07 Barchart service: Sending the VERSION command. | 2013-05-30 06:08:07 Barchart service: Connected. | 2013-05-30 06:08:07 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:08:07 Barchart service: IP Lockout. 107.2.177.218:60576 | 2013-05-30 06:08:12 Connection to the service has been lost or not completed. | 2013-05-30 06:08:12 Socket closed. No error. | 2013-05-30 06:08:12 Barchart service: Reset socket. | 2013-05-30 06:08:12 Barchart service: Disconnected. | 2013-05-30 06:08:12 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:08:12 Barchart service: Connecting to server... | 2013-05-30 06:08:17 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:08:17 Barchart service: User settings received. | 2013-05-30 06:08:17 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:08:17 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:08:17 The network socket is connected. | 2013-05-30 06:08:17 Barchart service: Sending the LOGIN command. | 2013-05-30 06:08:17 Barchart service: Sending the VERSION command. | 2013-05-30 06:08:17 Barchart service: Connected. | 2013-05-30 06:08:18 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:08:18 Barchart service: IP Lockout. 107.2.177.218:60578 | 2013-05-30 06:08:23 Connection to the service has been lost or not completed. | 2013-05-30 06:08:23 Barchart service: Sending the LOGOFF command. | 2013-05-30 06:08:23 Barchart service: Reset socket. | 2013-05-30 06:08:23 Barchart service: Disconnected. | 2013-05-30 06:08:23 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:08:23 Barchart service: Connecting to server... | 2013-05-30 06:08:28 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:08:28 Barchart service: User settings received. | 2013-05-30 06:08:28 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:08:28 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:08:28 The network socket is connected. | 2013-05-30 06:08:29 Barchart service: Sending the LOGIN command. | 2013-05-30 06:08:29 Barchart service: Sending the VERSION command. | 2013-05-30 06:08:29 Barchart service: Connected. | 2013-05-30 06:08:29 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:08:29 Barchart service: IP Lockout. 107.2.177.218:60580 | 2013-05-30 06:08:34 Connection to the service has been lost or not completed. | 2013-05-30 06:08:34 Socket closed. No error. | 2013-05-30 06:08:34 Barchart service: Reset socket. | 2013-05-30 06:08:34 Barchart service: Disconnected. | 2013-05-30 06:08:34 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:08:34 Barchart service: Connecting to server... | 2013-05-30 06:08:39 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:08:39 Barchart service: User settings received. | 2013-05-30 06:08:39 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:08:39 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:08:39 The network socket is connected. | 2013-05-30 06:08:39 Barchart service: Sending the LOGIN command. | 2013-05-30 06:08:39 Barchart service: Sending the VERSION command. | 2013-05-30 06:08:39 Barchart service: Connected. | 2013-05-30 06:08:39 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:08:40 Barchart service: IP Lockout. 107.2.177.218:60582 | 2013-05-30 06:08:45 Connection to the service has been lost or not completed. | 2013-05-30 06:08:45 Socket closed. No error. | 2013-05-30 06:08:45 Barchart service: Reset socket. | 2013-05-30 06:08:45 Barchart service: Disconnected. | 2013-05-30 06:08:45 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:08:45 Barchart service: Connecting to server... | 2013-05-30 06:08:50 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:08:50 Barchart service: User settings received. | 2013-05-30 06:08:50 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:08:50 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:08:50 The network socket is connected. | 2013-05-30 06:08:50 Barchart service: Sending the LOGIN command. | 2013-05-30 06:08:50 Barchart service: Sending the VERSION command. | 2013-05-30 06:08:50 Barchart service: Connected. | 2013-05-30 06:08:50 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:08:50 Barchart service: IP Lockout. 107.2.177.218:60583 | 2013-05-30 06:08:55 Connection to the service has been lost or not completed. | 2013-05-30 06:08:55 Socket closed. No error. | 2013-05-30 06:08:55 Barchart service: Reset socket. | 2013-05-30 06:08:55 Barchart service: Disconnected. | 2013-05-30 06:08:55 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:08:55 Barchart service: Connecting to server... | 2013-05-30 06:09:00 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:09:00 Barchart service: User settings received. | 2013-05-30 06:09:00 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:09:00 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:09:00 The network socket is connected. | 2013-05-30 06:09:00 Barchart service: Sending the LOGIN command. | 2013-05-30 06:09:00 Barchart service: Sending the VERSION command. | 2013-05-30 06:09:00 Barchart service: Connected. | 2013-05-30 06:09:01 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:09:01 Barchart service: IP Lockout. 107.2.177.218:60586 | 2013-05-30 06:09:06 Connection to the service has been lost or not completed. | 2013-05-30 06:09:06 Socket closed. No error. | 2013-05-30 06:09:06 Barchart service: Reset socket. | 2013-05-30 06:09:06 Barchart service: Disconnected. | 2013-05-30 06:09:06 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:09:06 Barchart service: Connecting to server... | 2013-05-30 06:09:11 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:09:11 Barchart service: User settings received. | 2013-05-30 06:09:11 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:09:11 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:09:11 The network socket is connected. | 2013-05-30 06:09:11 Barchart service: Sending the LOGIN command. | 2013-05-30 06:09:11 Barchart service: Sending the VERSION command. | 2013-05-30 06:09:11 Barchart service: Connected. | 2013-05-30 06:09:11 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:09:11 Barchart service: IP Lockout. 107.2.177.218:60588 | 2013-05-30 06:09:16 Connection to the service has been lost or not completed. | 2013-05-30 06:09:16 Socket closed. No error. | 2013-05-30 06:09:16 Barchart service: Reset socket. | 2013-05-30 06:09:16 Barchart service: Disconnected. | 2013-05-30 06:09:16 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:09:16 Barchart service: Connecting to server... | 2013-05-30 06:09:21 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:09:21 Barchart service: User settings received. | 2013-05-30 06:09:21 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:09:21 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:09:21 The network socket is connected. | 2013-05-30 06:09:21 Barchart service: Sending the LOGIN command. | 2013-05-30 06:09:22 Barchart service: Sending the VERSION command. | 2013-05-30 06:09:22 Barchart service: Connected. | 2013-05-30 06:09:22 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:09:22 Barchart service: IP Lockout. 107.2.177.218:60590 | 2013-05-30 06:09:28 Connection to the service has been lost or not completed. | 2013-05-30 06:09:28 Socket closed. No error. | 2013-05-30 06:09:28 Barchart service: Reset socket. | 2013-05-30 06:09:28 Barchart service: Disconnected. | 2013-05-30 06:09:28 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:09:28 Barchart service: Connecting to server... | 2013-05-30 06:09:33 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:09:33 Barchart service: User settings received. | 2013-05-30 06:09:33 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:09:33 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:09:33 The network socket is connected. | 2013-05-30 06:09:33 Barchart service: Sending the LOGIN command. | 2013-05-30 06:09:33 Barchart service: Sending the VERSION command. | 2013-05-30 06:09:33 Barchart service: Connected. | 2013-05-30 06:09:33 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:09:33 Barchart service: IP Lockout. 107.2.177.218:60592 | 2013-05-30 06:09:38 Connection to the service has been lost or not completed. | 2013-05-30 06:09:38 Socket closed. No error. | 2013-05-30 06:09:38 Barchart service: Reset socket. | 2013-05-30 06:09:38 Barchart service: Disconnected. | 2013-05-30 06:09:38 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:09:38 Barchart service: Connecting to server... | 2013-05-30 06:09:43 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:09:43 Barchart service: User settings received. | 2013-05-30 06:09:43 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:09:43 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:09:43 The network socket is connected. | 2013-05-30 06:09:43 Barchart service: Sending the LOGIN command. | 2013-05-30 06:09:43 Barchart service: Sending the VERSION command. | 2013-05-30 06:09:43 Barchart service: Connected. | 2013-05-30 06:09:43 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:09:44 Barchart service: IP Lockout. 107.2.177.218:60593 | 2013-05-30 06:09:49 Connection to the service has been lost or not completed. | 2013-05-30 06:09:49 Socket closed. No error. | 2013-05-30 06:09:49 Barchart service: Reset socket. | 2013-05-30 06:09:49 Barchart service: Disconnected. | 2013-05-30 06:09:49 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:09:49 Barchart service: Connecting to server... | 2013-05-30 06:09:54 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:09:54 Barchart service: User settings received. | 2013-05-30 06:09:54 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:09:54 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:09:54 The network socket is connected. | 2013-05-30 06:09:54 Barchart service: Sending the LOGIN command. | 2013-05-30 06:09:54 Barchart service: Sending the VERSION command. | 2013-05-30 06:09:54 Barchart service: Connected. | 2013-05-30 06:09:54 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:09:54 Barchart service: IP Lockout. 107.2.177.218:60594 | 2013-05-30 06:09:59 Connection to the service has been lost or not completed. | 2013-05-30 06:09:59 Socket closed. No error. | 2013-05-30 06:09:59 Barchart service: Reset socket. | 2013-05-30 06:09:59 Barchart service: Disconnected. | 2013-05-30 06:09:59 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:09:59 Barchart service: Connecting to server... | 2013-05-30 06:10:04 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:10:04 Barchart service: User settings received. | 2013-05-30 06:10:04 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:10:04 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:10:04 The network socket is connected. | 2013-05-30 06:10:04 Barchart service: Sending the LOGIN command. | 2013-05-30 06:10:04 Barchart service: Sending the VERSION command. | 2013-05-30 06:10:04 Barchart service: Connected. | 2013-05-30 06:10:04 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:10:05 Barchart service: IP Lockout. 107.2.177.218:60596 | 2013-05-30 06:10:10 Connection to the service has been lost or not completed. | 2013-05-30 06:10:10 Socket closed. No error. | 2013-05-30 06:10:10 Barchart service: Reset socket. | 2013-05-30 06:10:10 Barchart service: Disconnected. | 2013-05-30 06:10:10 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:10:10 Barchart service: Connecting to server... | 2013-05-30 06:10:15 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:10:15 Barchart service: User settings received. | 2013-05-30 06:10:15 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:10:15 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:10:15 The network socket is connected. | 2013-05-30 06:10:15 Barchart service: Sending the LOGIN command. | 2013-05-30 06:10:15 Barchart service: Sending the VERSION command. | 2013-05-30 06:10:15 Barchart service: Connected. | 2013-05-30 06:10:15 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:10:15 Barchart service: IP Lockout. 107.2.177.218:60597 | 2013-05-30 06:10:20 Connection to the service has been lost or not completed. | 2013-05-30 06:10:20 Socket closed. No error. | 2013-05-30 06:10:20 Barchart service: Reset socket. | 2013-05-30 06:10:20 Barchart service: Disconnected. | 2013-05-30 06:10:20 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:10:20 Barchart service: Connecting to server... | 2013-05-30 06:10:25 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:10:25 Barchart service: User settings received. | 2013-05-30 06:10:25 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:10:25 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:10:25 The network socket is connected. | 2013-05-30 06:10:25 Barchart service: Sending the LOGIN command. | 2013-05-30 06:10:25 Barchart service: Sending the VERSION command. | 2013-05-30 06:10:25 Barchart service: Connected. | 2013-05-30 06:10:26 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:10:26 Barchart service: IP Lockout. 107.2.177.218:60601 | 2013-05-30 06:10:31 Connection to the service has been lost or not completed. | 2013-05-30 06:10:31 Socket closed. No error. | 2013-05-30 06:10:31 Barchart service: Reset socket. | 2013-05-30 06:10:31 Barchart service: Disconnected. | 2013-05-30 06:10:31 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:10:31 Barchart service: Connecting to server... | 2013-05-30 06:10:36 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:10:36 Barchart service: User settings received. | 2013-05-30 06:10:36 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:10:36 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:10:36 The network socket is connected. | 2013-05-30 06:10:36 Barchart service: Sending the LOGIN command. | 2013-05-30 06:10:36 Barchart service: Sending the VERSION command. | 2013-05-30 06:10:36 Barchart service: Connected. | 2013-05-30 06:10:36 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:10:36 Barchart service: IP Lockout. 107.2.177.218:60602 | 2013-05-30 06:10:41 Connection to the service has been lost or not completed. | 2013-05-30 06:10:41 Socket closed. No error. | 2013-05-30 06:10:41 Barchart service: Reset socket. | 2013-05-30 06:10:41 Barchart service: Disconnected. | 2013-05-30 06:10:41 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:10:41 Barchart service: Connecting to server... | 2013-05-30 06:10:46 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:10:46 Barchart service: User settings received. | 2013-05-30 06:10:46 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:10:46 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:10:46 The network socket is connected. | 2013-05-30 06:10:46 Barchart service: Sending the LOGIN command. | 2013-05-30 06:10:47 Barchart service: Sending the VERSION command. | 2013-05-30 06:10:47 Barchart service: Connected. | 2013-05-30 06:10:47 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:10:47 Barchart service: IP Lockout. 107.2.177.218:60603 | 2013-05-30 06:10:52 Connection to the service has been lost or not completed. | 2013-05-30 06:10:52 Socket closed. No error. | 2013-05-30 06:10:52 Barchart service: Reset socket. | 2013-05-30 06:10:52 Barchart service: Disconnected. | 2013-05-30 06:10:52 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:10:52 Barchart service: Connecting to server... | 2013-05-30 06:10:57 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:10:57 Barchart service: User settings received. | 2013-05-30 06:10:57 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:10:57 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:10:57 The network socket is connected. | 2013-05-30 06:10:57 Barchart service: Sending the LOGIN command. | 2013-05-30 06:10:57 Barchart service: Sending the VERSION command. | 2013-05-30 06:10:57 Barchart service: Connected. | 2013-05-30 06:10:57 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:10:57 Barchart service: IP Lockout. 107.2.177.218:60605 | 2013-05-30 06:11:02 Connection to the service has been lost or not completed. | 2013-05-30 06:11:02 Socket closed. No error. | 2013-05-30 06:11:02 Barchart service: Reset socket. | 2013-05-30 06:11:02 Barchart service: Disconnected. | 2013-05-30 06:11:02 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:11:02 Barchart service: Connecting to server... | 2013-05-30 06:11:07 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:11:07 Barchart service: User settings received. | 2013-05-30 06:11:07 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:11:07 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:11:07 The network socket is connected. | 2013-05-30 06:11:08 Barchart service: Sending the LOGIN command. | 2013-05-30 06:11:08 Barchart service: Sending the VERSION command. | 2013-05-30 06:11:08 Barchart service: Connected. | 2013-05-30 06:11:08 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:11:08 Barchart service: IP Lockout. 107.2.177.218:60606 | 2013-05-30 06:11:13 Connection to the service has been lost or not completed. | 2013-05-30 06:11:13 Socket closed. No error. | 2013-05-30 06:11:13 Barchart service: Reset socket. | 2013-05-30 06:11:13 Barchart service: Disconnected. | 2013-05-30 06:11:13 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:11:13 Barchart service: Connecting to server... | 2013-05-30 06:11:18 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:11:18 Barchart service: User settings received. | 2013-05-30 06:11:18 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:11:18 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:11:18 The network socket is connected. | 2013-05-30 06:11:18 Barchart service: Sending the LOGIN command. | 2013-05-30 06:11:18 Barchart service: Sending the VERSION command. | 2013-05-30 06:11:18 Barchart service: Connected. | 2013-05-30 06:11:18 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:11:18 Barchart service: IP Lockout. 107.2.177.218:60607 | 2013-05-30 06:11:24 Connection to the service has been lost or not completed. | 2013-05-30 06:11:24 Socket closed. No error. | 2013-05-30 06:11:24 Barchart service: Reset socket. | 2013-05-30 06:11:24 Barchart service: Disconnected. | 2013-05-30 06:11:24 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:11:24 Barchart service: Connecting to server... | 2013-05-30 06:11:29 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:11:29 Barchart service: User settings received. | 2013-05-30 06:11:29 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:11:29 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:11:29 The network socket is connected. | 2013-05-30 06:11:29 Barchart service: Sending the LOGIN command. | 2013-05-30 06:11:29 Barchart service: Sending the VERSION command. | 2013-05-30 06:11:29 Barchart service: Connected. | 2013-05-30 06:11:29 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:11:29 Barchart service: IP Lockout. 107.2.177.218:60610 | 2013-05-30 06:11:34 Connection to the service has been lost or not completed. | 2013-05-30 06:11:34 Socket closed. No error. | 2013-05-30 06:11:34 Barchart service: Reset socket. | 2013-05-30 06:11:34 Barchart service: Disconnected. | 2013-05-30 06:11:34 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:11:34 Barchart service: Connecting to server... | 2013-05-30 06:11:39 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:11:39 Barchart service: User settings received. | 2013-05-30 06:11:39 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:11:39 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:11:39 The network socket is connected. | 2013-05-30 06:11:39 Barchart service: Sending the LOGIN command. | 2013-05-30 06:11:39 Barchart service: Sending the VERSION command. | 2013-05-30 06:11:39 Barchart service: Connected. | 2013-05-30 06:11:39 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:11:40 Barchart service: IP Lockout. 107.2.177.218:60611 | 2013-05-30 06:11:45 Connection to the service has been lost or not completed. | 2013-05-30 06:11:45 Socket closed. No error. | 2013-05-30 06:11:45 Barchart service: Reset socket. | 2013-05-30 06:11:45 Barchart service: Disconnected. | 2013-05-30 06:11:45 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:11:45 Barchart service: Connecting to server... | 2013-05-30 06:11:50 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:11:50 Barchart service: User settings received. | 2013-05-30 06:11:50 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:11:50 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:11:50 The network socket is connected. | 2013-05-30 06:11:50 Barchart service: Sending the LOGIN command. | 2013-05-30 06:11:50 Barchart service: Sending the VERSION command. | 2013-05-30 06:11:50 Barchart service: Connected. | 2013-05-30 06:11:50 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:11:50 Barchart service: IP Lockout. 107.2.177.218:60613 | 2013-05-30 06:11:55 Connection to the service has been lost or not completed. | 2013-05-30 06:11:55 Socket closed. No error. | 2013-05-30 06:11:55 Barchart service: Reset socket. | 2013-05-30 06:11:55 Barchart service: Disconnected. | 2013-05-30 06:11:55 Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-05-30 06:11:55 Barchart service: Connecting to server... | 2013-05-30 06:12:00 Barchart service: Requesting user settings for SCBarry1 | 2013-05-30 06:12:00 Barchart service: User settings received. | 2013-05-30 06:12:00 Barchart service: Your account is authorized for these exchanges: AMEX,BATS,INDEX,INDEX-DOW,INDEX-NQ,INDEX-NY,INDEX-SP,NTDS,OTCBB,FUND,NYSE,INDEX | 2013-05-30 06:12:00 Barchart service: Connecting using server qs02.aws.ddfplus.com:443 | 2013-05-30 06:12:00 The network socket is connected. | 2013-05-30 06:12:00 Barchart service: Sending the LOGIN command. | 2013-05-30 06:12:00 Barchart service: Sending the VERSION command. | 2013-05-30 06:12:00 Barchart service: Connected. | 2013-05-30 06:12:00 Barchart service - Info Message: + Version set to 3. | 2013-05-30 06:12:01 |
[2013-05-30 06:20:08] |
You are getting disconnected from the Barchart Data Service because this message is indicating you already have a connection to that service: Barchart service: IP Lockout. 107.2.177.218:60613 | 2013-05-30 06:11:55
Barchart only allows one single connection at a time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-30 06:20:29
[2013-05-30 06:53:52] |
Hello . . . I did not finish my initial question . . . my apologies, the above log was for barcharts, my 2nd sierra download, I get equities with it . . . . . now the log I am posting now is from transact, works great on desktop, trying to get laptop to work, see charts, everything is fine, but when trading box comes up, I usually click on box D just to the right of position and a trading dom comes up (ladder), but when I click on that now, nothing happens Software version: 976 | 2013-05-30 00:48:50 Current Service Package: 3 | 2013-05-30 00:48:50 Sierra Chart Historical Data Service is included. | 2013-05-30 00:48:50 Active service: TransAct | 2013-05-30 00:48:50 Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-05-30 00:48:50 2013-05-30 00:48:50 Local computer clock time | 2013-05-30 00:48:50 2013-05-30 06:48:50 GMT time | 2013-05-30 00:48:50 2013-05-30 00:48:50 Time zone adjusted time | 2013-05-30 00:48:50 Time difference to server time: 37 seconds. | 2013-05-30 00:48:50 WARNING: Your computer's clock is off by 37 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2013-05-30 00:48:50 Program path: C:\SierraChart\SierraChartTransActMA\ | 2013-05-30 00:48:50 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2013-05-30 00:48:50 OS Version Number: 5.1 | 2013-05-30 00:48:50 HD Request # 1 - Downloading Intraday chart data for ESM3 to the file ESM3.scid. Service: scsrv | 2013-05-30 00:48:55 HD Request # 1 - Starting date and time: 2013-05-29 23:52:58 | 2013-05-30 00:48:55 HD Request # 1 - Using server: ds5.sierracharts.com port 10049 | 2013-05-30 00:48:55 The network socket is connected. | 2013-05-30 00:48:55 HD Request # 1 - Requesting up to 60 days of Intraday data. | 2013-05-30 00:48:55 HD Request # 1 - Decompressing data. | 2013-05-30 00:48:56 Socket closed. No error. | 2013-05-30 00:48:56 HD Request # 1 - Historical data for ESM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-05-30 00:48:56 HD Request # 1 - Received 0 records and wrote 0 records for ESM3 | 2013-05-30 00:48:56 HD Request # 1 - Intraday download COMPLETE for ESM3 | 2013-05-30 00:48:56 Connecting to TransAct... | 2013-05-30 00:48:57 TransAct Service - Account: 28918 | 2013-05-30 00:49:01 TransAct Service: Connected to market data feed. | 2013-05-30 00:49:01 TransAct Service: Connected to TransAct Trade server. | 2013-05-30 00:49:03 TransAct Service: Fully connected. | 2013-05-30 00:49:03 TransAct Service: Checking for missing order fills. | 2013-05-30 00:49:03 Starting updates for: ESM3 | 2013-05-30 00:49:03 HD Request # 3 - Downloading Intraday chart data for ESM3 to the file ESM3.scid. Service: scsrv | 2013-05-30 00:49:03 HD Request # 3 - Starting date and time: 2013-05-29 23:52:58 | 2013-05-30 00:49:03 HD Request # 3 - Using server: ds4.sierracharts.com port 10049 | 2013-05-30 00:49:03 The network socket is connected. | 2013-05-30 00:49:03 HD Request # 3 - Requesting up to 60 days of Intraday data. | 2013-05-30 00:49:03 HD Request # 3 - Decompressing data. | 2013-05-30 00:49:03 HD Request # 3 - Receiving Intraday data for ESM3 starting at 2013-05-29 23:52:58 | 2013-05-30 00:49:03 HD Request # 3 - Timestamp of first Intraday data file record written: 2013-05-29 23:52:58 | 2013-05-30 00:49:03 Socket closed. No error. | 2013-05-30 00:49:03 HD Request # 3 - Received 978 records from 2013-05-29 23:52:58 to 2013-05-30 00:48:11 (55.2 minutes) and wrote 978 records for ESM3 | 2013-05-30 00:49:03 HD Request # 3 - Intraday download COMPLETE for ESM3 | 2013-05-30 00:49:03 Real-time intraday chart data file updates started for ESM3 | 2013-05-30 00:49:03 Starting updates for: YMM3 | 2013-05-30 00:49:12 HD Request # 5 - Downloading Intraday chart data for YMM3 to the file YMM3.scid. Service: scsrv | 2013-05-30 00:49:12 HD Request # 5 - Starting date and time: 2013-05-29 23:52:58 | 2013-05-30 00:49:12 HD Request # 5 - Using server: ds3.sierracharts.com port 10049 | 2013-05-30 00:49:13 The network socket is connected. | 2013-05-30 00:49:13 HD Request # 5 - Requesting up to 60 days of Intraday data. | 2013-05-30 00:49:13 HD Request # 5 - Decompressing data. | 2013-05-30 00:49:13 HD Request # 5 - Receiving Intraday data for YMM3 starting at 2013-05-29 23:52:58 | 2013-05-30 00:49:13 HD Request # 5 - Timestamp of first Intraday data file record written: 2013-05-29 23:52:58 | 2013-05-30 00:49:13 Socket closed. No error. | 2013-05-30 00:49:13 HD Request # 5 - Received 473 records from 2013-05-29 23:52:58 to 2013-05-30 00:48:29 (55.5 minutes) and wrote 473 records for YMM3 | 2013-05-30 00:49:13 HD Request # 5 - Intraday download COMPLETE for YMM3 | 2013-05-30 00:49:13 Real-time intraday chart data file updates started for YMM3 | 2013-05-30 00:49:14 |
[2013-05-30 20:12:06] |
but when trading box comes up, I usually click on box D just to the right of position and a trading dom comes up (ladder), but when I click on that now, nothing happens If you are referring to the TransAct/Infinity AT software, please consult with them about this.In Sierra Chart you can open a trading DOM through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-30 20:13:15
