Date/Time: Wed, 08 May 2024 20:02:57 +0000
Volume area lines and vol profile
View Count: 896
[2015-02-20 02:02:53] |
User27109 - Posts: 21 |
Hello, I am wondering if it is possible to draw the VPOC,VAH & VAL automatically? Right now, I have to draw a horizontal line for each VPOC,VAH,VAL manually. I want to draw all the above automatically for a year and have it plotted fully across the screen, with price labels? I would also like to do the same with the IB's, Open and closes. In addition is there a way to make the t&s window alawys on top, now when I move a chart or DOM it minimizes the window. Is there a way to plot the opening swing? I know that's a ton of questions, I appreciate the help. |
[2015-02-20 02:06:11] |
Also is there a way to link charts together of the ES so I don't have to draw the same lines on each chart. Right now I have all charts linked by symbol and assigned to 1 but it doesn't appear that the drawing I make link to the other time frame charts.
[2015-02-20 03:54:23] |
Refer to the Technical Studies Reference documentation for the following studies: Volume Value Area Lines High/Low for Time Period In addition is there a way to make the t&s window alawys on top, now when I move a chart or DOM it minimizes the window. This is a system issue on your side. It cannot possibly be with Sierra Chart itself if you are merely moving the window.Not really sure what an opening swing is, but we would think the chart itself gives you what you need. In any case, we cannot provide further help for this. Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
