Date/Time: Fri, 03 May 2024 18:47:01 +0000
Calculating Studies...
View Count: 1274
[2015-02-18 03:09:03] |
jivetrader - Posts: 387 |
is there any way to troubleshoot why my chart is suddenly taking 5x longer to recalc? is there a log of how long each study is taking to process, or something else helpful?
[2018-06-05 17:32:33] |
Steve - Posts: 16 |
I have the same issue, after adding a third Volume py Price study and with some custom settings, "recalculation of charts" (on any param change of any study..) takes now like 100 times longer as before (approx 2 minutes on i3 7100 25% CPU load). I guess I did change some parameter that causes this. First it appeared when I changed the tick resolution for the third VbP study to 1.
[2018-06-05 20:33:05] |
Refer to this particular section here about this: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
