Date/Time: Sun, 05 May 2024 04:08:42 +0000
[User Discussion] - Is there an easy way to measure pips?
View Count: 1907
[2015-01-23 08:49:47] |
User93464 - Posts: 52 |
Is there a tool in SC which enables you to measure pips from one level to another on a bar chart as you can in MT4?
[2015-01-23 14:09:08] |
mkata - Posts: 103 |
Try using the Chart Calculator. http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartCalculator |
[2018-10-18 21:27:13] |
AE16 - Posts: 31 |
I am also looking into this. I understand you can have it set to PD in the config which for example gives 4 pips as 0.00040. Is there a way to customize this so it is simply displayed as 4?
[2018-10-19 16:33:42] |
John - SC Support - Posts: 31362 |
Turn on the label for Tick Difference. Refer to the documentation here: Chart Drawing Tools: Chart Calculator Configuration
[2018-10-19 21:57:18] |
AE16 - Posts: 31 |
Thanks for the reply John, however, a tick is not the same as a pip? I will try and add a quick screen-shot of the my problem. As you can see it is 50 ticks, PD of 0.00250 / 25 pips. Possible to get this displayed just as a 25? http://www.sierrachart.com/image.php?Image=1539986198215.png |
