Date/Time: Sat, 18 May 2024 01:10:30 +0000
SC CQG random interruption
View Count: 2330
[2015-01-22 20:26:39] |
crazybears - Posts: 314 |
Hi i noticed since some days sc lost connection and start to reconnect from 2pm . while sc data feed works fine again ,data from CQG doesn't work. there is a delay between time of rerstart of sc datafeed and cqg datafeed ,cqg starts later. |
[2015-01-22 20:27:26] |
Websocket | Received opcode Close. Received status code: 1000 | 2015-01-22 15:18:28 CQG FIX Trading | Websocket closed. | 2015-01-22 15:18:28 Connection to the external service has been lost. | 2015-01-22 15:18:28 Socket (64) | SSL connection closed by remote side. | 2015-01-22 15:18:28 Socket (64) | SSL object has been freed. SSL state is now disconnected. | 2015-01-22 15:18:28 Socket (64) | Shutdown and closed. | 2015-01-22 15:18:28 Network socket for websocket has been closed by remote side. | 2015-01-22 15:18:28 CQG FIX Trading | Websocket closed. | 2015-01-22 15:18:28 CQG FIX Trading FIX: DisconnectFIX called. | 2015-01-22 15:18:28 CQG FIX Trading FIX: Sending a Logout message. | 2015-01-22 15:18:28 CQG FIX Trading | Disconnected. | 2015-01-22 15:18:28 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-22 15:18:28 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-01-22 15:18:29 socket (63) | Shutdown and closed. | 2015-01-22 15:18:29 CQG FIX Trading FIX: Logged out and disconnected. | 2015-01-22 15:18:29 CQG FIX Trading FIX: Disconnected. | 2015-01-22 15:18:29 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-01-22 15:18:33 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-01-22 15:18:33 socket (79) | Connected. | 2015-01-22 15:18:34 CQG FIX Trading FIX: Sending the Logon message. | 2015-01-22 15:18:34 CQG FIX Trading | Connected to trading server. | 2015-01-22 15:18:34 CQG FIX Trading | Connecting to market data server. | 2015-01-22 15:18:34 Connecting to websocket server. | 2015-01-22 15:18:34 CQG FIX Trading FIX - FCM name: AMP | 2015-01-22 15:18:34 Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-01-22 15:18:35 Socket (80) | Connected. | 2015-01-22 15:18:35 Socket (80) | Starting SSL connection. | 2015-01-22 15:18:35 Socket (80) | SSL connection established. | 2015-01-22 15:18:37 Opening websocket. | 2015-01-22 15:18:37 Sending websocket handshake. | 2015-01-22 15:18:37 Received websocket handshake acknowledgment. | 2015-01-22 15:18:37 TRANSPORT OPEN | 2015-01-22 15:18:37 CQG FIX Trading | Websocket connected. | 2015-01-22 15:18:37 CQG FIX Trading | Sending market data logon message. | 2015-01-22 15:18:37 CQG FIX Trading | Logon successful. | 2015-01-22 15:18:37 CQG FIX Trading | Market data session connected. | 2015-01-22 15:18:37 Socket (66) | Shutdown and closed. | 2015-01-22 15:18:37 SC Exchange Data | Disconnected from the server. | 2015-01-22 15:18:37 |
[2015-01-22 20:28:41] |
it's just happened again Socket (95) | Closed. No error. | 2015-01-22 15:27:05 Websocket | Received opcode Close. Received status code: 1000 | 2015-01-22 15:27:05 CQG FIX Trading | Websocket closed. | 2015-01-22 15:27:05 Connection to the external service has been lost. | 2015-01-22 15:27:05 Socket (95) | SSL has been shut down. | 2015-01-22 15:27:05 Socket (95) | SSL object has been freed. SSL state is now disconnected. | 2015-01-22 15:27:05 Socket (95) | Shutdown and closed. | 2015-01-22 15:27:05 Network socket for websocket has been closed by remote side. | 2015-01-22 15:27:05 CQG FIX Trading | Websocket closed. | 2015-01-22 15:27:05 CQG FIX Trading FIX: DisconnectFIX called. | 2015-01-22 15:27:05 CQG FIX Trading FIX: Sending a Logout message. | 2015-01-22 15:27:05 CQG FIX Trading | Disconnected. | 2015-01-22 15:27:05 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-22 15:27:05 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-01-22 15:27:05 socket (94) | Shutdown and closed. | 2015-01-22 15:27:05 CQG FIX Trading FIX: Logged out and disconnected. | 2015-01-22 15:27:05 CQG FIX Trading FIX: Disconnected. | 2015-01-22 15:27:05 |
[2015-01-22 20:51:39] |
Websocket | Received opcode Close. Received status code: 1000 | 2015-01-22 15:50:01 CQG FIX Trading | Websocket closed. | 2015-01-22 15:50:01 Connection to the external service has been lost. | 2015-01-22 15:50:01 CQG FIX Trading FIX: DisconnectFIX called. | 2015-01-22 15:50:02 CQG FIX Trading FIX: Sending a Logout message. | 2015-01-22 15:50:02 Sending logoff message. | 2015-01-22 15:50:02 Socket (110) | SSL shutdown indicates not able to send 'close notify'. | 2015-01-22 15:50:02 Socket (110) | SSL has been shut down. | 2015-01-22 15:50:02 Socket (110) | SSL object has been freed. SSL state is now disconnected. | 2015-01-22 15:50:02 Socket (110) | Shutdown and closed. | 2015-01-22 15:50:02 CQG FIX Trading | Websocket closed. | 2015-01-22 15:50:02 CQG FIX Trading | Disconnected. | 2015-01-22 15:50:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-22 15:50:02 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-01-22 15:50:02 socket (109) | Shutdown and closed. | 2015-01-22 15:50:02 CQG FIX Trading FIX: Logged out and disconnected. | 2015-01-22 15:50:02 CQG FIX Trading FIX: Disconnected. | 2015-01-22 15:50:02 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-01-22 15:50:07 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-01-22 15:50:07 socket (125) | Connected. | 2015-01-22 15:50:07 CQG FIX Trading FIX: Sending the Logon message. | 2015-01-22 15:50:07 CQG FIX Trading | Connected to trading server. | 2015-01-22 15:50:16 CQG FIX Trading | Connecting to market data server. | 2015-01-22 15:50:16 Connecting to websocket server. | 2015-01-22 15:50:16 CQG FIX Trading FIX - FCM name: AMP | 2015-01-22 15:50:17 Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-01-22 15:50:17 Socket (126) | Connected. | 2015-01-22 15:50:17 Socket (126) | Starting SSL connection. | 2015-01-22 15:50:17 Socket (126) | SSL connection established. | 2015-01-22 15:50:17 Opening websocket. | 2015-01-22 15:50:17 Sending websocket handshake. | 2015-01-22 15:50:17 Received websocket handshake acknowledgment. | 2015-01-22 15:50:18 TRANSPORT OPEN | 2015-01-22 15:50:18 CQG FIX Trading | Websocket connected. | 2015-01-22 15:50:18 CQG FIX Trading | Sending market data logon message. | 2015-01-22 15:50:18 CQG FIX Trading | Logon successful. | 2015-01-22 15:50:19 CQG FIX Trading | Market data session connected. | 2015-01-22 15:50:19 Socket (111) | Shutdown and closed. | 2015-01-22 15:50:19 SC Exchange Data | Disconnected from the server. | 2015-01-22 15:50:19 |
[2015-01-25 09:46:17] |
Hello :) |
[2015-01-26 08:01:14] |
This indicates CQG is closing the connection: Websocket | Received opcode Close. Received status code: 1000 | 2015-01-22 15:18:28 Try setting Global Settings >> Data/Trade Service Settings >> Allow Server to Drop Data to True. We have asked CQG what the status code of 1000 means. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-26 17:05:24] |
So this problem randomly occurs roughly around a particular time? If it happens around a particular time, what time and the time zone. It is always critical to specify the time zone, otherwise any time specification is useless to us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-26 17:10:39] |
Hi Disconnection starts around 2 pm EST I'm going to report it if will happen today thanks |
[2015-01-26 20:47:04] |
Hi Websocket | Received opcode Close. Received status code: 1000 | 2015-01-26 15:44:07 CQG FIX Trading | Websocket closed. | 2015-01-26 15:44:07 Connection to the external service has been lost. | 2015-01-26 15:44:07 CQG FIX Trading FIX: DisconnectFIX called. | 2015-01-26 15:44:07 CQG FIX Trading FIX: Sending a Logout message. | 2015-01-26 15:44:07 Sending logoff message. | 2015-01-26 15:44:07 Socket (3) | SSL shutdown indicates not able to send 'close notify'. | 2015-01-26 15:44:07 Socket (3) | SSL has been shut down. | 2015-01-26 15:44:07 Socket (3) | SSL object has been freed. SSL state is now disconnected. | 2015-01-26 15:44:07 Socket (3) | Shutdown and closed. | 2015-01-26 15:44:07 CQG FIX Trading | Websocket closed. | 2015-01-26 15:44:07 CQG FIX Trading | Disconnected. | 2015-01-26 15:44:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-26 15:44:07 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-01-26 15:44:07 socket (2) | Shutdown and closed. | 2015-01-26 15:44:07 CQG FIX Trading FIX: Logged out and disconnected. | 2015-01-26 15:44:07 CQG FIX Trading FIX: Disconnected. | 2015-01-26 15:44:07 |
[2015-01-26 20:48:43] |
now SC datafeed is working again data from from CQG no, i see CME emini moving, TF no. |
[2015-01-26 21:04:51] |
Is your CQG account authorized for ICE US? Refer to help topic 3.4: http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-26 21:10:06] |
yes , i have issues only in the afternoon suddenly SC starts to download data like i have lost connection , few second , after data from your services works fine , only data from CQG doesn't start |
[2015-01-26 21:46:11] |
Restart Sierra Chart and open a chart for only the symbol that is not updating and post a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-27 20:26:23] |
Hi Socket (3) | Closed. No error. | 2015-01-27 15:24:02 Websocket | Received opcode Close. Received status code: 1000 | 2015-01-27 15:24:02 CQG FIX Trading | Websocket closed. | 2015-01-27 15:24:02 Connection to the external service has been lost. | 2015-01-27 15:24:02 Socket (3) | SSL has been shut down. | 2015-01-27 15:24:02 Socket (3) | SSL object has been freed. SSL state is now disconnected. | 2015-01-27 15:24:02 Socket (3) | Shutdown and closed. | 2015-01-27 15:24:02 Network socket for websocket has been closed by remote side. | 2015-01-27 15:24:02 CQG FIX Trading | Websocket closed. | 2015-01-27 15:24:02 CQG FIX Trading FIX: DisconnectFIX called. | 2015-01-27 15:24:02 CQG FIX Trading FIX: Sending a Logout message. | 2015-01-27 15:24:02 CQG FIX Trading | Disconnected. | 2015-01-27 15:24:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-27 15:24:02 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-01-27 15:24:02 socket (2) | Shutdown and closed. | 2015-01-27 15:24:02 CQG FIX Trading FIX: Logged out and disconnected. | 2015-01-27 15:24:02 CQG FIX Trading FIX: Disconnected. | 2015-01-27 15:24:02 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-01-27 15:24:07 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-01-27 15:24:07 socket (17) | Connected. | 2015-01-27 15:24:07 CQG FIX Trading FIX: Sending the Logon message. | 2015-01-27 15:24:07 CQG FIX Trading | Connected to trading server. | 2015-01-27 15:24:08 CQG FIX Trading | Connecting to market data server. | 2015-01-27 15:24:08 Connecting to websocket server. | 2015-01-27 15:24:08 CQG FIX Trading FIX - FCM name: AMP | 2015-01-27 15:24:08 Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-01-27 15:24:09 Socket (18) | Connected. | 2015-01-27 15:24:09 Socket (18) | Starting SSL connection. | 2015-01-27 15:24:09 Socket (18) | SSL connection established. | 2015-01-27 15:24:10 Opening websocket. | 2015-01-27 15:24:10 Sending websocket handshake. | 2015-01-27 15:24:10 Received websocket handshake acknowledgment. | 2015-01-27 15:24:10 Web socket state is now open. | 2015-01-27 15:24:10 CQG FIX Trading | Websocket connected. | 2015-01-27 15:24:10 CQG FIX Trading | Sending market data logon message. | 2015-01-27 15:24:10 CQG FIX Trading | Logon successful. | 2015-01-27 15:24:10 CQG FIX Trading | Market data session connected. | 2015-01-27 15:24:10 Socket (5) | Shutdown and closed. | 2015-01-27 15:24:10 SC Exchange Data | Disconnected from the server. | 2015-01-27 15:24:10 |
[2015-01-27 20:30:32] |
If the problem is the charts for one of the symbols are not updating, we need to see the entire Message Log because these log portions do not show any market data requests or rejects.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-27 20:36:36
[2015-01-27 20:46:10] |
Websocket | Received opcode Close. Received status code: 1000 | 2015-01-27 15:45:15 CQG FIX Trading | Websocket closed. | 2015-01-27 15:45:15 Connection to the external service has been lost. | 2015-01-27 15:45:15 Socket (33) | SSL connection closed by remote side. | 2015-01-27 15:45:15 Socket (33) | SSL object has been freed. SSL state is now disconnected. | 2015-01-27 15:45:15 Socket (33) | Shutdown and closed. | 2015-01-27 15:45:15 Network socket for websocket has been closed by remote side. | 2015-01-27 15:45:15 CQG FIX Trading | Websocket closed. | 2015-01-27 15:45:15 CQG FIX Trading FIX: DisconnectFIX called. | 2015-01-27 15:45:15 CQG FIX Trading FIX: Sending a Logout message. | 2015-01-27 15:45:15 CQG FIX Trading | Disconnected. | 2015-01-27 15:45:15 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-27 15:45:15 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-01-27 15:45:16 socket (32) | Shutdown and closed. | 2015-01-27 15:45:16 CQG FIX Trading FIX: Logged out and disconnected. | 2015-01-27 15:45:16 CQG FIX Trading FIX: Disconnected. | 2015-01-27 15:45:16 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-01-27 15:45:20 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-01-27 15:45:21 socket (47) | Connected. | 2015-01-27 15:45:21 CQG FIX Trading FIX: Sending the Logon message. | 2015-01-27 15:45:21 CQG FIX Trading | Connected to trading server. | 2015-01-27 15:45:21 CQG FIX Trading | Connecting to market data server. | 2015-01-27 15:45:21 Connecting to websocket server. | 2015-01-27 15:45:21 CQG FIX Trading FIX - FCM name: AMP | 2015-01-27 15:45:21 Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-01-27 15:45:22 Socket (48) | Connected. | 2015-01-27 15:45:22 Socket (48) | Starting SSL connection. | 2015-01-27 15:45:22 Socket (48) | SSL connection established. | 2015-01-27 15:45:24 Opening websocket. | 2015-01-27 15:45:24 Sending websocket handshake. | 2015-01-27 15:45:24 Received websocket handshake acknowledgment. | 2015-01-27 15:45:24 Web socket state is now open. | 2015-01-27 15:45:24 CQG FIX Trading | Websocket connected. | 2015-01-27 15:45:24 CQG FIX Trading | Sending market data logon message. | 2015-01-27 15:45:24 CQG FIX Trading | Logon successful. | 2015-01-27 15:45:25 CQG FIX Trading | Market data session connected. | 2015-01-27 15:45:25 Socket (34) | Shutdown and closed. | 2015-01-27 15:45:25 SC Exchange Data | Disconnected from the server. | 2015-01-27 15:45:25 Mapping F.US.JY6H15 to 6JH5. Service code: cme | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: 6JH5. ID: 1 | 2015-01-27 15:45:25 Using username 0 | 2015-01-27 15:45:25 SC Exchange Data | Connecting to the server scdf1.sierracharts.com. Port 443 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.JY6H15 is set to download pending. | 2015-01-27 15:45:25 HD Request # 47 | Downloading Intraday chart data for F.US.JY6H15 to the file F.US.JY6H15.scid. Service: cme | 2015-01-27 15:45:25 HD Request # 47 | Download start Date-Time: 2015-01-27 15:45:23.0 | 2015-01-27 15:45:25 HD Request # 47 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-27 15:45:25 Mapping F.US.YMH15 to YMH5. Service code: cbot | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: YMH5. ID: 2 | 2015-01-27 15:45:25 CQG FIX Trading | Starting real-time market data updates for: F.US.DXEH15. ID: 3 | 2015-01-27 15:45:25 CQG FIX Trading | Sending symbol resolution request for F.US.DXEH15 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.DXEH15 is set to download pending. | 2015-01-27 15:45:25 Mapping F.US.EPH15 to ESH5. Service code: cme | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: ESH5. ID: 4 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.EPH15 is set to download pending. | 2015-01-27 15:45:25 Mapping F.US.GCEG15 to GCG5. Service code: comex | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: GCG5. ID: 5 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.GCEG15 is set to download pending. | 2015-01-27 15:45:25 CQG FIX Trading | Starting real-time market data updates for: F.US.TFEH15. ID: 6 | 2015-01-27 15:45:25 CQG FIX Trading | Sending symbol resolution request for F.US.TFEH15 | 2015-01-27 15:45:25 Mapping F.US.CLEH15 to CLH5. Service code: nymex | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: CLH5. ID: 7 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.CLEH15 is set to download pending. | 2015-01-27 15:45:25 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-27 15:45:25 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.YMH15 is set to download pending. | 2015-01-27 15:45:25 Mapping F.US.ZSEH15 to ZSH5. Service code: cbot | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: ZSH5. ID: 8 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.ZSEH15 is set to download pending. | 2015-01-27 15:45:25 Mapping F.US.ENQH15 to NQH5. Service code: cme | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: NQH5. ID: 9 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.ENQH15 is set to download pending. | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.TFEH15 is set to download pending. | 2015-01-27 15:45:25 Mapping F.US.EU6H15 to 6EH5. Service code: cme | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: 6EH5. ID: 10 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.EU6H15 is set to download pending. | 2015-01-27 15:45:25 Mapping F.US.NGEH15 to NGH5. Service code: nymex | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: NGH5. ID: 11 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.NGEH15 is set to download pending. | 2015-01-27 15:45:25 Mapping F.US.TYAH15 to ZNH5. Service code: cbot | 2015-01-27 15:45:25 SC Exchange Data | Starting real-time market data updates for: ZNH5. ID: 12 | 2015-01-27 15:45:25 Intraday data recording state for symbol F.US.TYAH15 is set to download pending. | 2015-01-27 15:45:25 Socket (49) | Connected. | 2015-01-27 15:45:25 HD Request # 47 | Sending historical data logon request message. | 2015-01-27 15:45:25 Socket (50) | Connected. | 2015-01-27 15:45:25 SC Exchange Data | Connected to server. | 2015-01-27 15:45:25 SC Exchange Data | Sending logon request message. | 2015-01-27 15:45:25 CQG FIX Trading | Requesting market data for F.US.DXEH15 | 2015-01-27 15:45:25 HD Request # 47 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:23. Record interval: 0. Symbol: 6JH5 | 2015-01-27 15:45:25 CQG FIX Trading | Requesting market data for F.US.TFEH15 | 2015-01-27 15:45:25 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-01-27 15:45:25 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-27 15:45:25 SC Exchange Data | Successfully connected. | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.CLEH15 -> CLH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.ENQH15 -> NQH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.EPH15 -> ESH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.EU6H15 -> 6EH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.GCEG15 -> GCG5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.JY6H15 -> 6JH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.NGEH15 -> NGH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.TYAH15 -> ZNH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.YMH15 -> YMH5 | 2015-01-27 15:45:25 SC Exchange Data | Restarting real-time data updates for symbol: F.US.ZSEH15 -> ZSH5 | 2015-01-27 15:45:25 HD Request # 47 | Decompressing data. | 2015-01-27 15:45:25 HD Request # 47 | Receiving Intraday data for F.US.JY6H15 starting at 2015-01-27 15:45:23 | 2015-01-27 15:45:25 Socket (49) | Shutdown and closed. | 2015-01-27 15:45:25 The network socket for historical data has been closed. | 2015-01-27 15:45:25 HD Request # 47 | Received 1 record from 2015-01-27 15:45:23 to 2015-01-27 15:45:23 (0.0 seconds) and wrote 0 records for F.US.JY6H15 | 2015-01-27 15:45:25 HD Request # 47 | Intraday download COMPLETE for F.US.JY6H15. Completion time: 0s. Unique request ID: 46 | 2015-01-27 15:45:25 Removed historical data download ID 46 | 2015-01-27 15:45:25 Real-time Intraday chart data file updates started for F.US.JY6H15 | 2015-01-27 15:45:25 HD Request # 48 | Downloading Intraday chart data for F.US.DXEH15 to the file F.US.DXEH15.scid. Service: cqg | 2015-01-27 15:45:25 HD Request # 48 | Download start Date-Time: 2015-01-27 15:41:05.0 | 2015-01-27 15:45:25 HD Request # 48 | Using server: ds4.sierracharts.com port 10149 | 2015-01-27 15:45:25 Chart #5 has tagged chart #8 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:25 Chart #7 has tagged chart #8 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:25 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:25 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-27 15:45:25 Socket (51) | Connected. | 2015-01-27 15:45:25 HD Request # 48 | Sending historical data logon request message. | 2015-01-27 15:45:25 Date rule based rollover from RJZ06 to next contract occurs at 2006-12-07. | 2015-01-27 15:45:26 Date rule based rollover from RJH07 to next contract occurs at 2007-03-08. | 2015-01-27 15:45:26 HD Request # 48 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:41:05. Record interval: 0. Symbol: F.US.DXEH15 | 2015-01-27 15:45:26 Date rule based rollover from RJM07 to next contract occurs at 2007-06-07. | 2015-01-27 15:45:26 Date rule based rollover from RJU07 to next contract occurs at 2007-09-13. | 2015-01-27 15:45:26 Date rule based rollover from RJZ07 to next contract occurs at 2007-12-13. | 2015-01-27 15:45:26 Date rule based rollover from RJH08 to next contract occurs at 2008-03-13. | 2015-01-27 15:45:26 Date rule based rollover from RJM08 to next contract occurs at 2008-06-12. | 2015-01-27 15:45:26 Date rule based rollover from RJU08 to next contract occurs at 2008-09-11. | 2015-01-27 15:45:26 Date rule based rollover from RJZ08 to next contract occurs at 2008-12-11. | 2015-01-27 15:45:26 Date rule based rollover from RJH09 to next contract occurs at 2009-03-12. | 2015-01-27 15:45:26 Date rule based rollover from RJM09 to next contract occurs at 2009-06-11. | 2015-01-27 15:45:26 Date rule based rollover from RJU09 to next contract occurs at 2009-09-10. | 2015-01-27 15:45:26 Date rule based rollover from RJZ09 to next contract occurs at 2009-12-10. | 2015-01-27 15:45:26 Date rule based rollover from RJH10 to next contract occurs at 2010-03-11. | 2015-01-27 15:45:26 Date rule based rollover from RJM10 to next contract occurs at 2010-06-10. | 2015-01-27 15:45:26 Date rule based rollover from RJU10 to next contract occurs at 2010-09-09. | 2015-01-27 15:45:26 Date rule based rollover from RJZ10 to next contract occurs at 2010-12-09. | 2015-01-27 15:45:26 Date rule based rollover from RJH11 to next contract occurs at 2011-03-10. | 2015-01-27 15:45:26 Date rule based rollover from RJM11 to next contract occurs at 2011-06-09. | 2015-01-27 15:45:26 Date rule based rollover from RJU11 to next contract occurs at 2011-09-08. | 2015-01-27 15:45:26 Date rule based rollover from RJZ11 to next contract occurs at 2011-12-08. | 2015-01-27 15:45:26 Date rule based rollover from RJH12 to next contract occurs at 2012-03-08. | 2015-01-27 15:45:26 Date rule based rollover from RJM12 to next contract occurs at 2012-06-07. | 2015-01-27 15:45:26 Date rule based rollover from RJU12 to next contract occurs at 2012-09-13. | 2015-01-27 15:45:26 Date rule based rollover from RJZ12 to next contract occurs at 2012-12-13. | 2015-01-27 15:45:26 Date rule based rollover from RJH13 to next contract occurs at 2013-03-07. | 2015-01-27 15:45:26 Date rule based rollover from RJM13 to next contract occurs at 2013-06-13. | 2015-01-27 15:45:26 Date rule based rollover from RJU13 to next contract occurs at 2013-09-12. | 2015-01-27 15:45:26 Date rule based rollover from RJZ13 to next contract occurs at 2013-12-12. | 2015-01-27 15:45:26 Date rule based rollover from RJH14 to next contract occurs at 2014-03-13. | 2015-01-27 15:45:26 Date rule based rollover from RJM14 to next contract occurs at 2014-06-12. | 2015-01-27 15:45:26 Date rule based rollover from RJU14 to next contract occurs at 2014-09-11. | 2015-01-27 15:45:26 Date rule based rollover from RJZ14 to next contract occurs at 2014-12-11. | 2015-01-27 15:45:26 Date rule based rollover from RJH15 to next contract occurs at 2015-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol RJH15 for the date range from 2014-12-11 to 2015-01-27. | 2015-01-27 15:45:26 RJH15/F.US.TFEH15 [C] Daily #22 | Symbols used for continuous contract chart: | 2015-01-27 15:45:26 RJZ06 | 2015-01-27 15:45:26 RJH07 | 2015-01-27 15:45:26 RJM07 | 2015-01-27 15:45:26 RJU07 | 2015-01-27 15:45:26 RJZ07 | 2015-01-27 15:45:26 RJH08 | 2015-01-27 15:45:26 RJM08 | 2015-01-27 15:45:26 RJU08 | 2015-01-27 15:45:26 RJZ08 | 2015-01-27 15:45:26 RJH09 | 2015-01-27 15:45:26 RJM09 | 2015-01-27 15:45:26 RJU09 | 2015-01-27 15:45:26 RJZ09 | 2015-01-27 15:45:26 RJH10 | 2015-01-27 15:45:26 RJM10 | 2015-01-27 15:45:26 RJU10 | 2015-01-27 15:45:26 RJZ10 | 2015-01-27 15:45:26 RJH11 | 2015-01-27 15:45:26 RJM11 | 2015-01-27 15:45:26 RJU11 | 2015-01-27 15:45:26 RJZ11 | 2015-01-27 15:45:26 RJH12 | 2015-01-27 15:45:26 RJM12 | 2015-01-27 15:45:26 RJU12 | 2015-01-27 15:45:26 RJZ12 | 2015-01-27 15:45:26 RJH13 | 2015-01-27 15:45:26 RJM13 | 2015-01-27 15:45:26 RJU13 | 2015-01-27 15:45:26 RJZ13 | 2015-01-27 15:45:26 RJH14 | 2015-01-27 15:45:26 RJM14 | 2015-01-27 15:45:26 RJU14 | 2015-01-27 15:45:26 RJZ14 | 2015-01-27 15:45:26 RJH15 | 2015-01-27 15:45:26 HD Request # 48 | Decompressing data. | 2015-01-27 15:45:26 HD Request # 48 | Receiving Intraday data for F.US.DXEH15 starting at 2015-01-27 15:41:05 | 2015-01-27 15:45:26 HD Request # 48 | Timestamp of first Intraday data file record written: 2015-01-27 15:44:52 | 2015-01-27 15:45:26 Socket (51) | Shutdown and closed. | 2015-01-27 15:45:26 The network socket for historical data has been closed. | 2015-01-27 15:45:26 HD Request # 48 | Received 7 records from 2015-01-27 15:41:05 to 2015-01-27 15:45:19 (4.2 minutes) and wrote 6 records for F.US.DXEH15 | 2015-01-27 15:45:26 HD Request # 48 | Intraday download COMPLETE for F.US.DXEH15. Completion time: 1s. Unique request ID: 47 | 2015-01-27 15:45:26 Removed historical data download ID 47 | 2015-01-27 15:45:26 Real-time Intraday chart data file updates started for F.US.DXEH15 | 2015-01-27 15:45:26 HD Request # 49 | Downloading Intraday chart data for F.US.EPH15 to the file F.US.EPH15.scid. Service: cme | 2015-01-27 15:45:26 HD Request # 49 | Download start Date-Time: 2015-01-27 15:45:24.0 | 2015-01-27 15:45:26 HD Request # 49 | Using server: scdf1.sierracharts.com port 10149 | 2015-01-27 15:45:26 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-27 15:45:26 Date rule based rollover from ESZ06 to next contract occurs at 2006-12-07. | 2015-01-27 15:45:26 Date rule based rollover from ESH07 to next contract occurs at 2007-03-08. | 2015-01-27 15:45:26 Date rule based rollover from ESM07 to next contract occurs at 2007-06-07. | 2015-01-27 15:45:26 Date rule based rollover from ESU07 to next contract occurs at 2007-09-13. | 2015-01-27 15:45:26 Date rule based rollover from ESZ07 to next contract occurs at 2007-12-13. | 2015-01-27 15:45:26 Date rule based rollover from ESH08 to next contract occurs at 2008-03-13. | 2015-01-27 15:45:26 Date rule based rollover from ESM08 to next contract occurs at 2008-06-12. | 2015-01-27 15:45:26 Date rule based rollover from ESU08 to next contract occurs at 2008-09-11. | 2015-01-27 15:45:26 Date rule based rollover from ESZ08 to next contract occurs at 2008-12-11. | 2015-01-27 15:45:26 Date rule based rollover from ESH09 to next contract occurs at 2009-03-12. | 2015-01-27 15:45:26 Date rule based rollover from ESM09 to next contract occurs at 2009-06-11. | 2015-01-27 15:45:26 Date rule based rollover from ESU09 to next contract occurs at 2009-09-10. | 2015-01-27 15:45:26 Date rule based rollover from ESZ09 to next contract occurs at 2009-12-10. | 2015-01-27 15:45:26 Date rule based rollover from ESH10 to next contract occurs at 2010-03-11. | 2015-01-27 15:45:26 Date rule based rollover from ESM10 to next contract occurs at 2010-06-10. | 2015-01-27 15:45:26 Date rule based rollover from ESU10 to next contract occurs at 2010-09-09. | 2015-01-27 15:45:26 Date rule based rollover from ESZ10 to next contract occurs at 2010-12-09. | 2015-01-27 15:45:26 Date rule based rollover from ESH11 to next contract occurs at 2011-03-10. | 2015-01-27 15:45:26 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09. | 2015-01-27 15:45:26 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08. | 2015-01-27 15:45:26 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2015-01-27 15:45:26 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-27 15:45:26 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-27 15:45:26 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-27 15:45:26 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-27 15:45:26 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-27 15:45:26 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-27 15:45:26 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-27 15:45:26 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-27 15:45:26 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-27 15:45:26 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-27 15:45:26 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-27 15:45:26 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-27 15:45:26 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-27. | 2015-01-27 15:45:26 ESH15/F.US.EPH15 [C] [M] Daily #11 | Symbols used for continuous contract chart: | 2015-01-27 15:45:26 ESZ06 | 2015-01-27 15:45:26 ESH07 | 2015-01-27 15:45:26 ESM07 | 2015-01-27 15:45:26 ESU07 | 2015-01-27 15:45:26 ESZ07 | 2015-01-27 15:45:26 ESH08 | 2015-01-27 15:45:26 ESM08 | 2015-01-27 15:45:26 ESU08 | 2015-01-27 15:45:26 ESZ08 | 2015-01-27 15:45:26 ESH09 | 2015-01-27 15:45:26 ESM09 | 2015-01-27 15:45:26 ESU09 | 2015-01-27 15:45:26 ESZ09 | 2015-01-27 15:45:26 ESH10 | 2015-01-27 15:45:26 ESM10 | 2015-01-27 15:45:26 ESU10 | 2015-01-27 15:45:26 ESZ10 | 2015-01-27 15:45:26 ESH11 | 2015-01-27 15:45:26 ESM11 | 2015-01-27 15:45:26 ESU11 | 2015-01-27 15:45:26 ESZ11 | 2015-01-27 15:45:26 ESH12 | 2015-01-27 15:45:26 ESM12 | 2015-01-27 15:45:26 ESU12 | 2015-01-27 15:45:26 ESZ12 | 2015-01-27 15:45:26 ESH13 | 2015-01-27 15:45:26 ESM13 | 2015-01-27 15:45:26 ESU13 | 2015-01-27 15:45:26 ESZ13 | 2015-01-27 15:45:26 ESH14 | 2015-01-27 15:45:26 ESM14 | 2015-01-27 15:45:26 ESU14 | 2015-01-27 15:45:26 ESZ14 | 2015-01-27 15:45:26 ESH15 | 2015-01-27 15:45:26 Socket (52) | Connected. | 2015-01-27 15:45:26 HD Request # 49 | Sending historical data logon request message. | 2015-01-27 15:45:26 Date rule based rollover from YMZ06 to next contract occurs at 2006-12-07. | 2015-01-27 15:45:26 Date rule based rollover from YMH07 to next contract occurs at 2007-03-08. | 2015-01-27 15:45:26 Date rule based rollover from YMM07 to next contract occurs at 2007-06-07. | 2015-01-27 15:45:26 Date rule based rollover from YMU07 to next contract occurs at 2007-09-13. | 2015-01-27 15:45:26 Date rule based rollover from YMZ07 to next contract occurs at 2007-12-13. | 2015-01-27 15:45:26 Date rule based rollover from YMH08 to next contract occurs at 2008-03-13. | 2015-01-27 15:45:26 Date rule based rollover from YMM08 to next contract occurs at 2008-06-12. | 2015-01-27 15:45:26 Date rule based rollover from YMU08 to next contract occurs at 2008-09-11. | 2015-01-27 15:45:26 Date rule based rollover from YMZ08 to next contract occurs at 2008-12-11. | 2015-01-27 15:45:26 Date rule based rollover from YMH09 to next contract occurs at 2009-03-12. | 2015-01-27 15:45:26 Date rule based rollover from YMM09 to next contract occurs at 2009-06-11. | 2015-01-27 15:45:26 Date rule based rollover from YMU09 to next contract occurs at 2009-09-10. | 2015-01-27 15:45:26 Date rule based rollover from YMZ09 to next contract occurs at 2009-12-10. | 2015-01-27 15:45:26 Date rule based rollover from YMH10 to next contract occurs at 2010-03-11. | 2015-01-27 15:45:26 Date rule based rollover from YMM10 to next contract occurs at 2010-06-10. | 2015-01-27 15:45:26 Date rule based rollover from YMU10 to next contract occurs at 2010-09-09. | 2015-01-27 15:45:26 Date rule based rollover from YMZ10 to next contract occurs at 2010-12-09. | 2015-01-27 15:45:26 Date rule based rollover from YMH11 to next contract occurs at 2011-03-10. | 2015-01-27 15:45:26 Date rule based rollover from YMM11 to next contract occurs at 2011-06-09. | 2015-01-27 15:45:26 Date rule based rollover from YMU11 to next contract occurs at 2011-09-08. | 2015-01-27 15:45:26 Date rule based rollover from YMZ11 to next contract occurs at 2011-12-08. | 2015-01-27 15:45:26 Date rule based rollover from YMH12 to next contract occurs at 2012-03-08. | 2015-01-27 15:45:26 Date rule based rollover from YMM12 to next contract occurs at 2012-06-07. | 2015-01-27 15:45:26 Date rule based rollover from YMU12 to next contract occurs at 2012-09-13. | 2015-01-27 15:45:26 Date rule based rollover from YMZ12 to next contract occurs at 2012-12-13. | 2015-01-27 15:45:26 Date rule based rollover from YMH13 to next contract occurs at 2013-03-07. | 2015-01-27 15:45:26 Date rule based rollover from YMM13 to next contract occurs at 2013-06-13. | 2015-01-27 15:45:26 Date rule based rollover from YMU13 to next contract occurs at 2013-09-12. | 2015-01-27 15:45:26 Date rule based rollover from YMZ13 to next contract occurs at 2013-12-12. | 2015-01-27 15:45:26 Date rule based rollover from YMH14 to next contract occurs at 2014-03-13. | 2015-01-27 15:45:26 Date rule based rollover from YMM14 to next contract occurs at 2014-06-12. | 2015-01-27 15:45:26 Date rule based rollover from YMU14 to next contract occurs at 2014-09-11. | 2015-01-27 15:45:26 Date rule based rollover from YMZ14 to next contract occurs at 2014-12-11. | 2015-01-27 15:45:26 Date rule based rollover from YMH15 to next contract occurs at 2015-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol YMH15 for the date range from 2014-12-11 to 2015-01-27. | 2015-01-27 15:45:26 YMH15/F.US.YMH15 [C] [M] Daily #21 | Symbols used for continuous contract chart: | 2015-01-27 15:45:26 YMZ06 | 2015-01-27 15:45:26 YMH07 | 2015-01-27 15:45:26 YMM07 | 2015-01-27 15:45:26 YMU07 | 2015-01-27 15:45:26 YMZ07 | 2015-01-27 15:45:26 YMH08 | 2015-01-27 15:45:26 YMM08 | 2015-01-27 15:45:26 YMU08 | 2015-01-27 15:45:26 YMZ08 | 2015-01-27 15:45:26 YMH09 | 2015-01-27 15:45:26 YMM09 | 2015-01-27 15:45:26 YMU09 | 2015-01-27 15:45:26 YMZ09 | 2015-01-27 15:45:26 YMH10 | 2015-01-27 15:45:26 YMM10 | 2015-01-27 15:45:26 YMU10 | 2015-01-27 15:45:26 YMZ10 | 2015-01-27 15:45:26 YMH11 | 2015-01-27 15:45:26 YMM11 | 2015-01-27 15:45:26 YMU11 | 2015-01-27 15:45:26 YMZ11 | 2015-01-27 15:45:26 YMH12 | 2015-01-27 15:45:26 YMM12 | 2015-01-27 15:45:26 YMU12 | 2015-01-27 15:45:26 YMZ12 | 2015-01-27 15:45:26 YMH13 | 2015-01-27 15:45:26 YMM13 | 2015-01-27 15:45:26 YMU13 | 2015-01-27 15:45:26 YMZ13 | 2015-01-27 15:45:26 YMH14 | 2015-01-27 15:45:26 YMM14 | 2015-01-27 15:45:26 YMU14 | 2015-01-27 15:45:26 YMZ14 | 2015-01-27 15:45:26 YMH15 | 2015-01-27 15:45:26 Date rule based rollover from NQZ06 to next contract occurs at 2006-12-07. | 2015-01-27 15:45:26 Date rule based rollover from NQH07 to next contract occurs at 2007-03-08. | 2015-01-27 15:45:26 Date rule based rollover from NQM07 to next contract occurs at 2007-06-07. | 2015-01-27 15:45:26 Date rule based rollover from NQU07 to next contract occurs at 2007-09-13. | 2015-01-27 15:45:26 Date rule based rollover from NQZ07 to next contract occurs at 2007-12-13. | 2015-01-27 15:45:26 Date rule based rollover from NQH08 to next contract occurs at 2008-03-13. | 2015-01-27 15:45:26 Date rule based rollover from NQM08 to next contract occurs at 2008-06-12. | 2015-01-27 15:45:26 Date rule based rollover from NQU08 to next contract occurs at 2008-09-11. | 2015-01-27 15:45:26 Date rule based rollover from NQZ08 to next contract occurs at 2008-12-11. | 2015-01-27 15:45:26 Date rule based rollover from NQH09 to next contract occurs at 2009-03-12. | 2015-01-27 15:45:26 Date rule based rollover from NQM09 to next contract occurs at 2009-06-11. | 2015-01-27 15:45:26 Date rule based rollover from NQU09 to next contract occurs at 2009-09-10. | 2015-01-27 15:45:26 Date rule based rollover from NQZ09 to next contract occurs at 2009-12-10. | 2015-01-27 15:45:26 Date rule based rollover from NQH10 to next contract occurs at 2010-03-11. | 2015-01-27 15:45:26 Date rule based rollover from NQM10 to next contract occurs at 2010-06-10. | 2015-01-27 15:45:26 Date rule based rollover from NQU10 to next contract occurs at 2010-09-09. | 2015-01-27 15:45:26 Date rule based rollover from NQZ10 to next contract occurs at 2010-12-09. | 2015-01-27 15:45:26 Date rule based rollover from NQH11 to next contract occurs at 2011-03-10. | 2015-01-27 15:45:26 Date rule based rollover from NQM11 to next contract occurs at 2011-06-09. | 2015-01-27 15:45:26 Date rule based rollover from NQU11 to next contract occurs at 2011-09-08. | 2015-01-27 15:45:26 Date rule based rollover from NQZ11 to next contract occurs at 2011-12-08. | 2015-01-27 15:45:26 Date rule based rollover from NQH12 to next contract occurs at 2012-03-08. | 2015-01-27 15:45:26 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2015-01-27 15:45:26 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2015-01-27 15:45:26 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2015-01-27 15:45:26 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2015-01-27 15:45:26 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2015-01-27 15:45:26 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2015-01-27 15:45:26 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2015-01-27 15:45:26 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2015-01-27 15:45:26 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2015-01-27 15:45:26 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2015-01-27 15:45:26 Date rule based rollover from NQZ14 to next contract occurs at 2014-12-11. | 2015-01-27 15:45:26 Date rule based rollover from NQH15 to next contract occurs at 2015-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-27 15:45:26 Checking Daily data file for symbol NQH15 for the date range from 2014-12-11 to 2015-01-27. | 2015-01-27 15:45:26 NQH15/F.US.ENQH15 [C] [M] Daily #20 | Symbols used for continuous contract chart: | 2015-01-27 15:45:26 NQZ06 | 2015-01-27 15:45:26 NQH07 | 2015-01-27 15:45:26 NQM07 | 2015-01-27 15:45:26 NQU07 | 2015-01-27 15:45:26 NQZ07 | 2015-01-27 15:45:26 NQH08 | 2015-01-27 15:45:26 NQM08 | 2015-01-27 15:45:26 NQU08 | 2015-01-27 15:45:26 NQZ08 | 2015-01-27 15:45:26 NQH09 | 2015-01-27 15:45:26 NQM09 | 2015-01-27 15:45:26 NQU09 | 2015-01-27 15:45:26 NQZ09 | 2015-01-27 15:45:26 NQH10 | 2015-01-27 15:45:26 NQM10 | 2015-01-27 15:45:26 NQU10 | 2015-01-27 15:45:26 NQZ10 | 2015-01-27 15:45:26 NQH11 | 2015-01-27 15:45:26 NQM11 | 2015-01-27 15:45:26 NQU11 | 2015-01-27 15:45:26 NQZ11 | 2015-01-27 15:45:26 NQH12 | 2015-01-27 15:45:26 NQM12 | 2015-01-27 15:45:26 NQU12 | 2015-01-27 15:45:26 NQZ12 | 2015-01-27 15:45:26 NQH13 | 2015-01-27 15:45:26 NQM13 | 2015-01-27 15:45:26 NQU13 | 2015-01-27 15:45:26 NQZ13 | 2015-01-27 15:45:26 NQH14 | 2015-01-27 15:45:26 NQM14 | 2015-01-27 15:45:26 NQU14 | 2015-01-27 15:45:26 NQZ14 | 2015-01-27 15:45:26 NQH15 | 2015-01-27 15:45:26 HD Request # 49 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:24. Record interval: 0. Symbol: ESH5 | 2015-01-27 15:45:26 HD Request # 49 | Decompressing data. | 2015-01-27 15:45:26 HD Request # 49 | Receiving Intraday data for F.US.EPH15 starting at 2015-01-27 15:45:24 | 2015-01-27 15:45:26 HD Request # 49 | Timestamp of first Intraday data file record written: 2015-01-27 15:45:25 | 2015-01-27 15:45:26 Socket (52) | Shutdown and closed. | 2015-01-27 15:45:26 The network socket for historical data has been closed. | 2015-01-27 15:45:26 HD Request # 49 | Received 8 records from 2015-01-27 15:45:24 to 2015-01-27 15:45:25 (1.0 seconds) and wrote 7 records for F.US.EPH15 | 2015-01-27 15:45:26 Added 85 Time and Sales records to Intraday data file for F.US.EPH15 after download. | 2015-01-27 15:45:26 HD Request # 49 | Intraday download COMPLETE for F.US.EPH15. Completion time: 0s. Unique request ID: 48 | 2015-01-27 15:45:26 Removed historical data download ID 48 | 2015-01-27 15:45:26 Real-time Intraday chart data file updates started for F.US.EPH15 | 2015-01-27 15:45:26 HD Request # 50 | Downloading Intraday chart data for F.US.GCEG15 to the file F.US.GCEG15.scid. Service: comex | 2015-01-27 15:45:26 HD Request # 50 | Download start Date-Time: 2015-01-27 15:45:17.0 | 2015-01-27 15:45:26 HD Request # 50 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-27 15:45:26 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-27 15:45:26 Chart #1 has tagged chart #24 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:26 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:26 Chart #34 has tagged chart #1 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:26 Chart #34 has tagged chart #24 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:26 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:26 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:26 Chart #1 has tagged chart #24 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:26 Socket (53) | Connected. | 2015-01-27 15:45:26 HD Request # 50 | Sending historical data logon request message. | 2015-01-27 15:45:26 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:26 HD Request # 50 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:17. Record interval: 0. Symbol: GCG5 | 2015-01-27 15:45:27 HD Request # 50 | Decompressing data. | 2015-01-27 15:45:27 HD Request # 50 | Receiving Intraday data for F.US.GCEG15 starting at 2015-01-27 15:45:17 | 2015-01-27 15:45:27 HD Request # 50 | Timestamp of first Intraday data file record written: 2015-01-27 15:45:25 | 2015-01-27 15:45:27 Socket (53) | Shutdown and closed. | 2015-01-27 15:45:27 The network socket for historical data has been closed. | 2015-01-27 15:45:27 HD Request # 50 | Received 8 records from 2015-01-27 15:45:17 to 2015-01-27 15:45:25 (8.0 seconds) and wrote 7 records for F.US.GCEG15 | 2015-01-27 15:45:27 Added 2 Time and Sales records to Intraday data file for F.US.GCEG15 after download. | 2015-01-27 15:45:27 HD Request # 50 | Intraday download COMPLETE for F.US.GCEG15. Completion time: 1s. Unique request ID: 49 | 2015-01-27 15:45:27 Removed historical data download ID 49 | 2015-01-27 15:45:27 Real-time Intraday chart data file updates started for F.US.GCEG15 | 2015-01-27 15:45:27 HD Request # 51 | Downloading Intraday chart data for F.US.CLEH15 to the file F.US.CLEH15.scid. Service: nymex | 2015-01-27 15:45:27 HD Request # 51 | Download start Date-Time: 2015-01-27 15:45:24.0 | 2015-01-27 15:45:27 HD Request # 51 | Using server: scdf1.sierracharts.com port 10149 | 2015-01-27 15:45:27 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-27 15:45:27 Chart #25 has tagged chart #12 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:27 Chart #25 has tagged chart #26 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:27 Chart #26 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:27 Socket (54) | Connected. | 2015-01-27 15:45:27 HD Request # 51 | Sending historical data logon request message. | 2015-01-27 15:45:27 HD Request # 51 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:24. Record interval: 0. Symbol: CLH5 | 2015-01-27 15:45:27 HD Request # 51 | Decompressing data. | 2015-01-27 15:45:27 HD Request # 51 | Receiving Intraday data for F.US.CLEH15 starting at 2015-01-27 15:45:24 | 2015-01-27 15:45:27 HD Request # 51 | Timestamp of first Intraday data file record written: 2015-01-27 15:45:25 | 2015-01-27 15:45:27 Socket (54) | Shutdown and closed. | 2015-01-27 15:45:27 The network socket for historical data has been closed. | 2015-01-27 15:45:27 HD Request # 51 | Received 4 records from 2015-01-27 15:45:24 to 2015-01-27 15:45:25 (1.0 seconds) and wrote 1 record for F.US.CLEH15 | 2015-01-27 15:45:28 HD Request # 51 | Intraday download COMPLETE for F.US.CLEH15. Completion time: 0s. Unique request ID: 50 | 2015-01-27 15:45:28 Removed historical data download ID 50 | 2015-01-27 15:45:28 Real-time Intraday chart data file updates started for F.US.CLEH15 | 2015-01-27 15:45:28 HD Request # 52 | Downloading Intraday chart data for F.US.YMH15 to the file F.US.YMH15.scid. Service: cbot | 2015-01-27 15:45:28 HD Request # 52 | Download start Date-Time: 2015-01-27 15:45:24.0 | 2015-01-27 15:45:28 HD Request # 52 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-27 15:45:28 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-27 15:45:28 Chart #29 has tagged chart #23 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #30 has tagged chart #23 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #30 has tagged chart #29 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #12 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #23 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #29 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #29 has tagged chart #23 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Socket (55) | Connected. | 2015-01-27 15:45:28 HD Request # 52 | Sending historical data logon request message. | 2015-01-27 15:45:28 Chart #23 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:28 HD Request # 52 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:24. Record interval: 0. Symbol: YMH5 | 2015-01-27 15:45:28 HD Request # 52 | Decompressing data. | 2015-01-27 15:45:28 HD Request # 52 | Receiving Intraday data for F.US.YMH15 starting at 2015-01-27 15:45:24 | 2015-01-27 15:45:28 HD Request # 52 | Timestamp of first Intraday data file record written: 2015-01-27 15:45:26 | 2015-01-27 15:45:28 Socket (55) | Shutdown and closed. | 2015-01-27 15:45:28 The network socket for historical data has been closed. | 2015-01-27 15:45:28 HD Request # 52 | Received 28 records from 2015-01-27 15:45:24 to 2015-01-27 15:45:27 (3.0 seconds) and wrote 26 records for F.US.YMH15 | 2015-01-27 15:45:28 HD Request # 52 | Intraday download COMPLETE for F.US.YMH15. Completion time: 0s. Unique request ID: 51 | 2015-01-27 15:45:28 Removed historical data download ID 51 | 2015-01-27 15:45:28 Real-time Intraday chart data file updates started for F.US.YMH15 | 2015-01-27 15:45:28 HD Request # 53 | Downloading Intraday chart data for F.US.ZSEH15 to the file F.US.ZSEH15.scid. Service: cbot | 2015-01-27 15:45:28 HD Request # 53 | Download start Date-Time: 2015-01-27 14:14:59.0 | 2015-01-27 15:45:28 HD Request # 53 | Using server: scdf1.sierracharts.com port 10149 | 2015-01-27 15:45:28 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-27 15:45:28 Chart #33 has tagged chart #3 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Socket (56) | Connected. | 2015-01-27 15:45:28 HD Request # 53 | Sending historical data logon request message. | 2015-01-27 15:45:28 Chart #3 has tagged chart #15 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #3 has tagged chart #15 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:28 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:28 HD Request # 53 | Requesting Intraday data. Start Date-Time: 2015-01-27 14:14:59. Record interval: 0. Symbol: ZSH5 | 2015-01-27 15:45:28 HD Request # 53 | Decompressing data. | 2015-01-27 15:45:29 HD Request # 53 | Receiving Intraday data for F.US.ZSEH15 starting at 2015-01-27 14:14:59 | 2015-01-27 15:45:29 Socket (56) | Shutdown and closed. | 2015-01-27 15:45:29 The network socket for historical data has been closed. | 2015-01-27 15:45:29 HD Request # 53 | Received 25 records from 2015-01-27 14:14:59 to 2015-01-27 14:14:59 (0.0 seconds) and wrote 0 records for F.US.ZSEH15 | 2015-01-27 15:45:29 HD Request # 53 | Intraday download COMPLETE for F.US.ZSEH15. Completion time: 1s. Unique request ID: 52 | 2015-01-27 15:45:29 Removed historical data download ID 52 | 2015-01-27 15:45:29 Real-time Intraday chart data file updates started for F.US.ZSEH15 | 2015-01-27 15:45:29 HD Request # 54 | Downloading Intraday chart data for F.US.ENQH15 to the file F.US.ENQH15.scid. Service: cme | 2015-01-27 15:45:29 HD Request # 54 | Download start Date-Time: 2015-01-27 15:45:23.0 | 2015-01-27 15:45:29 HD Request # 54 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-27 15:45:29 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-27 15:45:29 Chart #28 has tagged chart #17 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:29 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:29 Socket (57) | Connected. | 2015-01-27 15:45:29 HD Request # 54 | Sending historical data logon request message. | 2015-01-27 15:45:29 HD Request # 54 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:23. Record interval: 0. Symbol: NQH5 | 2015-01-27 15:45:29 HD Request # 54 | Decompressing data. | 2015-01-27 15:45:29 HD Request # 54 | Receiving Intraday data for F.US.ENQH15 starting at 2015-01-27 15:45:23 | 2015-01-27 15:45:29 HD Request # 54 | Timestamp of first Intraday data file record written: 2015-01-27 15:45:26 | 2015-01-27 15:45:29 Socket (57) | Shutdown and closed. | 2015-01-27 15:45:29 The network socket for historical data has been closed. | 2015-01-27 15:45:29 HD Request # 54 | Received 54 records from 2015-01-27 15:45:23 to 2015-01-27 15:45:28 (5.0 seconds) and wrote 53 records for F.US.ENQH15 | 2015-01-27 15:45:29 Added 4 Time and Sales records to Intraday data file for F.US.ENQH15 after download. | 2015-01-27 15:45:29 HD Request # 54 | Intraday download COMPLETE for F.US.ENQH15. Completion time: 0s. Unique request ID: 53 | 2015-01-27 15:45:29 Removed historical data download ID 53 | 2015-01-27 15:45:29 Real-time Intraday chart data file updates started for F.US.ENQH15 | 2015-01-27 15:45:29 HD Request # 55 | Downloading Intraday chart data for F.US.TFEH15 to the file F.US.TFEH15.scid. Service: cqg | 2015-01-27 15:45:29 HD Request # 55 | Download start Date-Time: 2015-01-27 15:44:34.0 | 2015-01-27 15:45:29 HD Request # 55 | Using server: ds3.sierracharts.com port 10149 | 2015-01-27 15:45:29 Chart #31 has tagged chart #2 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:29 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-27 15:45:29 Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:29 Chart #2 has tagged chart #16 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:29 Chart #2 has tagged chart #16 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:29 Chart #16 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:29 Socket (58) | Connected. | 2015-01-27 15:45:29 HD Request # 55 | Sending historical data logon request message. | 2015-01-27 15:45:29 HD Request # 55 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:44:34. Record interval: 0. Symbol: F.US.TFEH15 | 2015-01-27 15:45:29 Requesting market depth updates for: F.US.ZSEH15 if supported. | 2015-01-27 15:45:30 HD Request # 55 | Decompressing data. | 2015-01-27 15:45:30 HD Request # 55 | Receiving Intraday data for F.US.TFEH15 starting at 2015-01-27 15:44:34 | 2015-01-27 15:45:30 HD Request # 55 | Timestamp of first Intraday data file record written: 2015-01-27 15:44:36 | 2015-01-27 15:45:30 Socket (58) | Shutdown and closed. | 2015-01-27 15:45:30 The network socket for historical data has been closed. | 2015-01-27 15:45:30 HD Request # 55 | Received 168 records from 2015-01-27 15:44:34 to 2015-01-27 15:45:29 (55.0 seconds) and wrote 157 records for F.US.TFEH15 | 2015-01-27 15:45:30 HD Request # 55 | Intraday download COMPLETE for F.US.TFEH15. Completion time: 1s. Unique request ID: 54 | 2015-01-27 15:45:30 Removed historical data download ID 54 | 2015-01-27 15:45:30 Real-time Intraday chart data file updates started for F.US.TFEH15 | 2015-01-27 15:45:30 HD Request # 56 | Downloading Intraday chart data for F.US.EU6H15 to the file F.US.EU6H15.scid. Service: cme | 2015-01-27 15:45:30 HD Request # 56 | Download start Date-Time: 2015-01-27 15:45:16.0 | 2015-01-27 15:45:30 HD Request # 56 | Using server: scdf1.sierracharts.com port 10149 | 2015-01-27 15:45:30 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-27 15:45:30 Chart #13 has tagged chart #4 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:30 Chart #4 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:30 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:30 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:30 Chart #32 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:30 Market Depth data has been rejected for symbol: F.US.ZSEH15. Not authorized for market depth. | 2015-01-27 15:45:30 Socket (59) | Connected. | 2015-01-27 15:45:30 HD Request # 56 | Sending historical data logon request message. | 2015-01-27 15:45:30 HD Request # 56 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:16. Record interval: 0. Symbol: 6EH5 | 2015-01-27 15:45:30 HD Request # 56 | Decompressing data. | 2015-01-27 15:45:30 HD Request # 56 | Receiving Intraday data for F.US.EU6H15 starting at 2015-01-27 15:45:16 | 2015-01-27 15:45:30 Socket (59) | Shutdown and closed. | 2015-01-27 15:45:30 The network socket for historical data has been closed. | 2015-01-27 15:45:30 HD Request # 56 | Received 7 records from 2015-01-27 15:45:16 to 2015-01-27 15:45:16 (0.0 seconds) and wrote 0 records for F.US.EU6H15 | 2015-01-27 15:45:30 HD Request # 56 | Intraday download COMPLETE for F.US.EU6H15. Completion time: 0s. Unique request ID: 55 | 2015-01-27 15:45:30 Removed historical data download ID 55 | 2015-01-27 15:45:30 Real-time Intraday chart data file updates started for F.US.EU6H15 | 2015-01-27 15:45:30 HD Request # 57 | Downloading Intraday chart data for F.US.NGEH15 to the file F.US.NGEH15.scid. Service: nymex | 2015-01-27 15:45:30 HD Request # 57 | Download start Date-Time: 2015-01-27 15:45:24.0 | 2015-01-27 15:45:30 HD Request # 57 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-27 15:45:30 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-27 15:45:30 Date rule based rollover from CLX06 to next contract occurs at 2006-10-19. | 2015-01-27 15:45:30 Date rule based rollover from CLZ06 to next contract occurs at 2006-11-20. | 2015-01-27 15:45:30 Date rule based rollover from CLF07 to next contract occurs at 2006-12-19. | 2015-01-27 15:45:30 Date rule based rollover from CLG07 to next contract occurs at 2007-01-19. | 2015-01-27 15:45:30 Date rule based rollover from CLH07 to next contract occurs at 2007-02-19. | 2015-01-27 15:45:30 Date rule based rollover from CLJ07 to next contract occurs at 2007-03-19. | 2015-01-27 15:45:30 Date rule based rollover from CLK07 to next contract occurs at 2007-04-19. | 2015-01-27 15:45:30 Date rule based rollover from CLM07 to next contract occurs at 2007-05-21. | 2015-01-27 15:45:30 Date rule based rollover from CLN07 to next contract occurs at 2007-06-19. | 2015-01-27 15:45:30 Date rule based rollover from CLQ07 to next contract occurs at 2007-07-19. | 2015-01-27 15:45:30 Date rule based rollover from CLU07 to next contract occurs at 2007-08-20. | 2015-01-27 15:45:30 Date rule based rollover from CLV07 to next contract occurs at 2007-09-19. | 2015-01-27 15:45:30 Date rule based rollover from CLX07 to next contract occurs at 2007-10-19. | 2015-01-27 15:45:30 Date rule based rollover from CLZ07 to next contract occurs at 2007-11-19. | 2015-01-27 15:45:30 Date rule based rollover from CLF08 to next contract occurs at 2007-12-19. | 2015-01-27 15:45:30 Date rule based rollover from CLG08 to next contract occurs at 2008-01-21. | 2015-01-27 15:45:30 Date rule based rollover from CLH08 to next contract occurs at 2008-02-19. | 2015-01-27 15:45:30 Date rule based rollover from CLJ08 to next contract occurs at 2008-03-19. | 2015-01-27 15:45:30 Date rule based rollover from CLK08 to next contract occurs at 2008-04-21. | 2015-01-27 15:45:30 Date rule based rollover from CLM08 to next contract occurs at 2008-05-19. | 2015-01-27 15:45:30 Date rule based rollover from CLN08 to next contract occurs at 2008-06-19. | 2015-01-27 15:45:30 Date rule based rollover from CLQ08 to next contract occurs at 2008-07-21. | 2015-01-27 15:45:30 Date rule based rollover from CLU08 to next contract occurs at 2008-08-19. | 2015-01-27 15:45:30 Date rule based rollover from CLV08 to next contract occurs at 2008-09-19. | 2015-01-27 15:45:30 Date rule based rollover from CLX08 to next contract occurs at 2008-10-20. | 2015-01-27 15:45:30 Date rule based rollover from CLZ08 to next contract occurs at 2008-11-19. | 2015-01-27 15:45:30 Date rule based rollover from CLF09 to next contract occurs at 2008-12-19. | 2015-01-27 15:45:30 Date rule based rollover from CLG09 to next contract occurs at 2009-01-19. | 2015-01-27 15:45:30 Date rule based rollover from CLH09 to next contract occurs at 2009-02-19. | 2015-01-27 15:45:30 Date rule based rollover from CLJ09 to next contract occurs at 2009-03-19. | 2015-01-27 15:45:30 Date rule based rollover from CLK09 to next contract occurs at 2009-04-20. | 2015-01-27 15:45:30 Date rule based rollover from CLM09 to next contract occurs at 2009-05-19. | 2015-01-27 15:45:30 Date rule based rollover from CLN09 to next contract occurs at 2009-06-19. | 2015-01-27 15:45:30 Date rule based rollover from CLQ09 to next contract occurs at 2009-07-20. | 2015-01-27 15:45:30 Date rule based rollover from CLU09 to next contract occurs at 2009-08-19. | 2015-01-27 15:45:30 Date rule based rollover from CLV09 to next contract occurs at 2009-09-21. | 2015-01-27 15:45:30 Date rule based rollover from CLX09 to next contract occurs at 2009-10-19. | 2015-01-27 15:45:30 Date rule based rollover from CLZ09 to next contract occurs at 2009-11-19. | 2015-01-27 15:45:30 Date rule based rollover from CLF10 to next contract occurs at 2009-12-21. | 2015-01-27 15:45:30 Date rule based rollover from CLG10 to next contract occurs at 2010-01-19. | 2015-01-27 15:45:30 Date rule based rollover from CLH10 to next contract occurs at 2010-02-19. | 2015-01-27 15:45:30 Date rule based rollover from CLJ10 to next contract occurs at 2010-03-19. | 2015-01-27 15:45:30 Date rule based rollover from CLK10 to next contract occurs at 2010-04-19. | 2015-01-27 15:45:30 Date rule based rollover from CLM10 to next contract occurs at 2010-05-19. | 2015-01-27 15:45:30 Date rule based rollover from CLN10 to next contract occurs at 2010-06-21. | 2015-01-27 15:45:30 Date rule based rollover from CLQ10 to next contract occurs at 2010-07-19. | 2015-01-27 15:45:30 Date rule based rollover from CLU10 to next contract occurs at 2010-08-19. | 2015-01-27 15:45:30 Date rule based rollover from CLV10 to next contract occurs at 2010-09-20. | 2015-01-27 15:45:30 Date rule based rollover from CLX10 to next contract occurs at 2010-10-19. | 2015-01-27 15:45:30 Date rule based rollover from CLZ10 to next contract occurs at 2010-11-19. | 2015-01-27 15:45:30 Date rule based rollover from CLF11 to next contract occurs at 2010-12-20. | 2015-01-27 15:45:30 Date rule based rollover from CLG11 to next contract occurs at 2011-01-19. | 2015-01-27 15:45:30 Date rule based rollover from CLH11 to next contract occurs at 2011-02-21. | 2015-01-27 15:45:30 Date rule based rollover from CLJ11 to next contract occurs at 2011-03-21. | 2015-01-27 15:45:30 Date rule based rollover from CLK11 to next contract occurs at 2011-04-19. | 2015-01-27 15:45:30 Date rule based rollover from CLM11 to next contract occurs at 2011-05-19. | 2015-01-27 15:45:30 Date rule based rollover from CLN11 to next contract occurs at 2011-06-20. | 2015-01-27 15:45:30 Date rule based rollover from CLQ11 to next contract occurs at 2011-07-19. | 2015-01-27 15:45:30 Date rule based rollover from CLU11 to next contract occurs at 2011-08-19. | 2015-01-27 15:45:30 Date rule based rollover from CLV11 to next contract occurs at 2011-09-19. | 2015-01-27 15:45:30 Date rule based rollover from CLX11 to next contract occurs at 2011-10-19. | 2015-01-27 15:45:30 Date rule based rollover from CLZ11 to next contract occurs at 2011-11-21. | 2015-01-27 15:45:30 Date rule based rollover from CLF12 to next contract occurs at 2011-12-19. | 2015-01-27 15:45:30 Date rule based rollover from CLG12 to next contract occurs at 2012-01-19. | 2015-01-27 15:45:30 Date rule based rollover from CLH12 to next contract occurs at 2012-02-20. | 2015-01-27 15:45:30 Date rule based rollover from CLJ12 to next contract occurs at 2012-03-19. | 2015-01-27 15:45:30 Date rule based rollover from CLK12 to next contract occurs at 2012-04-19. | 2015-01-27 15:45:30 Date rule based rollover from CLM12 to next contract occurs at 2012-05-21. | 2015-01-27 15:45:30 Date rule based rollover from CLN12 to next contract occurs at 2012-06-19. | 2015-01-27 15:45:30 Date rule based rollover from CLQ12 to next contract occurs at 2012-07-19. | 2015-01-27 15:45:30 Date rule based rollover from CLU12 to next contract occurs at 2012-08-20. | 2015-01-27 15:45:30 Date rule based rollover from CLV12 to next contract occurs at 2012-09-19. | 2015-01-27 15:45:30 Date rule based rollover from CLX12 to next contract occurs at 2012-10-19. | 2015-01-27 15:45:30 Date rule based rollover from CLZ12 to next contract occurs at 2012-11-19. | 2015-01-27 15:45:30 Date rule based rollover from CLF13 to next contract occurs at 2012-12-19. | 2015-01-27 15:45:30 Date rule based rollover from CLG13 to next contract occurs at 2013-01-21. | 2015-01-27 15:45:30 Date rule based rollover from CLH13 to next contract occurs at 2013-02-19. | 2015-01-27 15:45:30 Date rule based rollover from CLJ13 to next contract occurs at 2013-03-19. | 2015-01-27 15:45:30 Date rule based rollover from CLK13 to next contract occurs at 2013-04-19. | 2015-01-27 15:45:30 Date rule based rollover from CLM13 to next contract occurs at 2013-05-20. | 2015-01-27 15:45:30 Date rule based rollover from CLN13 to next contract occurs at 2013-06-19. | 2015-01-27 15:45:30 Date rule based rollover from CLQ13 to next contract occurs at 2013-07-19. | 2015-01-27 15:45:30 Date rule based rollover from CLU13 to next contract occurs at 2013-08-19. | 2015-01-27 15:45:30 Date rule based rollover from CLV13 to next contract occurs at 2013-09-19. | 2015-01-27 15:45:30 Date rule based rollover from CLX13 to next contract occurs at 2013-10-21. | 2015-01-27 15:45:30 Date rule based rollover from CLZ13 to next contract occurs at 2013-11-19. | 2015-01-27 15:45:30 Date rule based rollover from CLF14 to next contract occurs at 2013-12-19. | 2015-01-27 15:45:30 Date rule based rollover from CLG14 to next contract occurs at 2014-01-20. | 2015-01-27 15:45:30 Date rule based rollover from CLH14 to next contract occurs at 2014-02-19. | 2015-01-27 15:45:30 Date rule based rollover from CLJ14 to next contract occurs at 2014-03-19. | 2015-01-27 15:45:30 Date rule based rollover from CLK14 to next contract occurs at 2014-04-21. | 2015-01-27 15:45:30 Date rule based rollover from CLM14 to next contract occurs at 2014-05-19. | 2015-01-27 15:45:30 Date rule based rollover from CLN14 to next contract occurs at 2014-06-19. | 2015-01-27 15:45:30 Date rule based rollover from CLQ14 to next contract occurs at 2014-07-21. | 2015-01-27 15:45:30 Date rule based rollover from CLU14 to next contract occurs at 2014-08-19. | 2015-01-27 15:45:30 Date rule based rollover from CLV14 to next contract occurs at 2014-09-19. | 2015-01-27 15:45:30 Date rule based rollover from CLX14 to next contract occurs at 2014-10-20. | 2015-01-27 15:45:30 Date rule based rollover from CLZ14 to next contract occurs at 2014-11-19. | 2015-01-27 15:45:30 Date rule based rollover from CLF15 to next contract occurs at 2014-12-19. | 2015-01-27 15:45:30 Date rule based rollover from CLG15 to next contract occurs at 2015-01-19. | 2015-01-27 15:45:30 Date rule based rollover from CLH15 to next contract occurs at 2015-02-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX06 for the date range from 2006-09-19 to 2006-10-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ06 for the date range from 2006-10-19 to 2006-11-20. | 2015-01-27 15:45:30 Skipping Daily data download for symbol CLZ06 since download was already done in last 24 hours. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF07 for the date range from 2006-11-20 to 2006-12-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG07 for the date range from 2006-12-19 to 2007-01-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH07 for the date range from 2007-01-19 to 2007-02-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ07 for the date range from 2007-02-19 to 2007-03-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK07 for the date range from 2007-03-19 to 2007-04-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM07 for the date range from 2007-04-19 to 2007-05-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN07 for the date range from 2007-05-21 to 2007-06-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ07 for the date range from 2007-06-19 to 2007-07-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU07 for the date range from 2007-07-19 to 2007-08-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV07 for the date range from 2007-08-20 to 2007-09-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX07 for the date range from 2007-09-19 to 2007-10-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ07 for the date range from 2007-10-19 to 2007-11-19. | 2015-01-27 15:45:30 Skipping Daily data download for symbol CLZ07 since download was already done in last 24 hours. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF08 for the date range from 2007-11-19 to 2007-12-19. | 2015-01-27 15:45:30 Skipping Daily data download for symbol CLF08 since download was already done in last 24 hours. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG08 for the date range from 2007-12-19 to 2008-01-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH08 for the date range from 2008-01-21 to 2008-02-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ08 for the date range from 2008-02-19 to 2008-03-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK08 for the date range from 2008-03-19 to 2008-04-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM08 for the date range from 2008-04-21 to 2008-05-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN08 for the date range from 2008-05-19 to 2008-06-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ08 for the date range from 2008-06-19 to 2008-07-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU08 for the date range from 2008-07-21 to 2008-08-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV08 for the date range from 2008-08-19 to 2008-09-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX08 for the date range from 2008-09-19 to 2008-10-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ08 for the date range from 2008-10-20 to 2008-11-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF09 for the date range from 2008-11-19 to 2008-12-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG09 for the date range from 2008-12-19 to 2009-01-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH09 for the date range from 2009-01-19 to 2009-02-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ09 for the date range from 2009-02-19 to 2009-03-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK09 for the date range from 2009-03-19 to 2009-04-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM09 for the date range from 2009-04-20 to 2009-05-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN09 for the date range from 2009-05-19 to 2009-06-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ09 for the date range from 2009-06-19 to 2009-07-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU09 for the date range from 2009-07-20 to 2009-08-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV09 for the date range from 2009-08-19 to 2009-09-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX09 for the date range from 2009-09-21 to 2009-10-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ09 for the date range from 2009-10-19 to 2009-11-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF10 for the date range from 2009-11-19 to 2009-12-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG10 for the date range from 2009-12-21 to 2010-01-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH10 for the date range from 2010-01-19 to 2010-02-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ10 for the date range from 2010-02-19 to 2010-03-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK10 for the date range from 2010-03-19 to 2010-04-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM10 for the date range from 2010-04-19 to 2010-05-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN10 for the date range from 2010-05-19 to 2010-06-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ10 for the date range from 2010-06-21 to 2010-07-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU10 for the date range from 2010-07-19 to 2010-08-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV10 for the date range from 2010-08-19 to 2010-09-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX10 for the date range from 2010-09-20 to 2010-10-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ10 for the date range from 2010-10-19 to 2010-11-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF11 for the date range from 2010-11-19 to 2010-12-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG11 for the date range from 2010-12-20 to 2011-01-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH11 for the date range from 2011-01-19 to 2011-02-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ11 for the date range from 2011-02-21 to 2011-03-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK11 for the date range from 2011-03-21 to 2011-04-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM11 for the date range from 2011-04-19 to 2011-05-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN11 for the date range from 2011-05-19 to 2011-06-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ11 for the date range from 2011-06-20 to 2011-07-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU11 for the date range from 2011-07-19 to 2011-08-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV11 for the date range from 2011-08-19 to 2011-09-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX11 for the date range from 2011-09-19 to 2011-10-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ11 for the date range from 2011-10-19 to 2011-11-21. | 2015-01-27 15:45:30 Skipping Daily data download for symbol CLZ11 since download was already done in last 24 hours. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF12 for the date range from 2011-11-21 to 2011-12-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG12 for the date range from 2011-12-19 to 2012-01-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH12 for the date range from 2012-01-19 to 2012-02-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ12 for the date range from 2012-02-20 to 2012-03-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK12 for the date range from 2012-03-19 to 2012-04-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM12 for the date range from 2012-04-19 to 2012-05-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-20. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLZ14 for the date range from 2014-10-20 to 2014-11-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLF15 for the date range from 2014-11-19 to 2014-12-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLG15 for the date range from 2014-12-19 to 2015-01-19. | 2015-01-27 15:45:30 Checking Daily data file for symbol CLH15 for the date range from 2015-01-19 to 2015-01-27. | 2015-01-27 15:45:30 CLH15/F.US.CLEH15 [C] [M] Daily #14 | Symbols used for continuous contract chart: | 2015-01-27 15:45:30 CLX06 | 2015-01-27 15:45:30 CLZ06 | 2015-01-27 15:45:30 CLF07 | 2015-01-27 15:45:30 CLG07 | 2015-01-27 15:45:30 CLH07 | 2015-01-27 15:45:30 CLJ07 | 2015-01-27 15:45:30 CLK07 | 2015-01-27 15:45:30 CLM07 | 2015-01-27 15:45:30 CLN07 | 2015-01-27 15:45:30 CLQ07 | 2015-01-27 15:45:30 CLU07 | 2015-01-27 15:45:30 CLV07 | 2015-01-27 15:45:30 CLX07 | 2015-01-27 15:45:30 CLZ07 | 2015-01-27 15:45:30 CLF08 | 2015-01-27 15:45:30 CLG08 | 2015-01-27 15:45:30 CLH08 | 2015-01-27 15:45:30 CLJ08 | 2015-01-27 15:45:30 CLK08 | 2015-01-27 15:45:30 CLM08 | 2015-01-27 15:45:30 CLN08 | 2015-01-27 15:45:30 CLQ08 | 2015-01-27 15:45:30 CLU08 | 2015-01-27 15:45:30 CLV08 | 2015-01-27 15:45:30 CLX08 | 2015-01-27 15:45:30 CLZ08 | 2015-01-27 15:45:30 CLF09 | 2015-01-27 15:45:30 CLG09 | 2015-01-27 15:45:30 CLH09 | 2015-01-27 15:45:30 CLJ09 | 2015-01-27 15:45:30 CLK09 | 2015-01-27 15:45:30 CLM09 | 2015-01-27 15:45:30 CLN09 | 2015-01-27 15:45:30 CLQ09 | 2015-01-27 15:45:30 CLU09 | 2015-01-27 15:45:30 CLV09 | 2015-01-27 15:45:30 CLX09 | 2015-01-27 15:45:30 CLZ09 | 2015-01-27 15:45:30 CLF10 | 2015-01-27 15:45:30 CLG10 | 2015-01-27 15:45:30 CLH10 | 2015-01-27 15:45:30 CLJ10 | 2015-01-27 15:45:30 CLK10 | 2015-01-27 15:45:30 CLM10 | 2015-01-27 15:45:30 CLN10 | 2015-01-27 15:45:30 CLQ10 | 2015-01-27 15:45:30 CLU10 | 2015-01-27 15:45:30 CLV10 | 2015-01-27 15:45:30 CLX10 | 2015-01-27 15:45:30 CLZ10 | 2015-01-27 15:45:30 CLF11 | 2015-01-27 15:45:30 CLG11 | 2015-01-27 15:45:30 CLH11 | 2015-01-27 15:45:30 CLJ11 | 2015-01-27 15:45:30 CLK11 | 2015-01-27 15:45:30 CLM11 | 2015-01-27 15:45:30 CLN11 | 2015-01-27 15:45:30 CLQ11 | 2015-01-27 15:45:30 CLU11 | 2015-01-27 15:45:30 CLV11 | 2015-01-27 15:45:30 CLX11 | 2015-01-27 15:45:30 CLZ11 | 2015-01-27 15:45:30 CLF12 | 2015-01-27 15:45:30 CLG12 | 2015-01-27 15:45:30 CLH12 | 2015-01-27 15:45:30 CLJ12 | 2015-01-27 15:45:30 CLK12 | 2015-01-27 15:45:30 CLM12 | 2015-01-27 15:45:30 CLN12 | 2015-01-27 15:45:30 CLQ12 | 2015-01-27 15:45:30 CLU12 | 2015-01-27 15:45:30 CLV12 | 2015-01-27 15:45:30 CLX12 | 2015-01-27 15:45:30 CLZ12 | 2015-01-27 15:45:30 CLF13 | 2015-01-27 15:45:30 CLG13 | 2015-01-27 15:45:30 CLH13 | 2015-01-27 15:45:30 CLJ13 | 2015-01-27 15:45:30 CLK13 | 2015-01-27 15:45:30 CLM13 | 2015-01-27 15:45:30 CLN13 | 2015-01-27 15:45:30 CLQ13 | 2015-01-27 15:45:30 CLU13 | 2015-01-27 15:45:30 CLV13 | 2015-01-27 15:45:30 CLX13 | 2015-01-27 15:45:30 CLZ13 | 2015-01-27 15:45:30 CLF14 | 2015-01-27 15:45:30 CLG14 | 2015-01-27 15:45:30 CLH14 | 2015-01-27 15:45:30 CLJ14 | 2015-01-27 15:45:30 CLK14 | 2015-01-27 15:45:30 CLM14 | 2015-01-27 15:45:30 CLN14 | 2015-01-27 15:45:30 CLQ14 | 2015-01-27 15:45:30 CLU14 | 2015-01-27 15:45:30 CLV14 | 2015-01-27 15:45:30 CLX14 | 2015-01-27 15:45:30 CLZ14 | 2015-01-27 15:45:30 CLF15 | 2015-01-27 15:45:30 CLG15 | 2015-01-27 15:45:30 CLH15 | 2015-01-27 15:45:30 Socket (60) | Connected. | 2015-01-27 15:45:30 HD Request # 57 | Sending historical data logon request message. | 2015-01-27 15:45:30 HD Request # 57 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:24. Record interval: 0. Symbol: NGH5 | 2015-01-27 15:45:31 HD Request # 57 | Decompressing data. | 2015-01-27 15:45:31 HD Request # 57 | Receiving Intraday data for F.US.NGEH15 starting at 2015-01-27 15:45:24 | 2015-01-27 15:45:31 HD Request # 57 | Timestamp of first Intraday data file record written: 2015-01-27 15:45:27 | 2015-01-27 15:45:31 Socket (60) | Shutdown and closed. | 2015-01-27 15:45:31 The network socket for historical data has been closed. | 2015-01-27 15:45:31 HD Request # 57 | Received 7 records from 2015-01-27 15:45:24 to 2015-01-27 15:45:29 (5.0 seconds) and wrote 6 records for F.US.NGEH15 | 2015-01-27 15:45:31 HD Request # 57 | Intraday download COMPLETE for F.US.NGEH15. Completion time: 0s. Unique request ID: 56 | 2015-01-27 15:45:31 Removed historical data download ID 56 | 2015-01-27 15:45:31 Real-time Intraday chart data file updates started for F.US.NGEH15 | 2015-01-27 15:45:31 HD Request # 58 | Downloading Intraday chart data for F.US.TYAH15 to the file F.US.TYAH15.scid. Service: cbot | 2015-01-27 15:45:31 HD Request # 58 | Download start Date-Time: 2015-01-27 15:45:12.0 | 2015-01-27 15:45:31 HD Request # 58 | Using server: scdf1.sierracharts.com port 10149 | 2015-01-27 15:45:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-27 15:45:31 Chart #48 has tagged chart #47 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:31 Chart #48 has tagged chart #49 for full recalculation. Chartbook: EMINI.cht | 2015-01-27 15:45:31 Chart #49 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:31 Chart #47 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-01-27 15:45:31 Socket (61) | Connected. | 2015-01-27 15:45:31 HD Request # 58 | Sending historical data logon request message. | 2015-01-27 15:45:31 HD Request # 58 | Requesting Intraday data. Start Date-Time: 2015-01-27 15:45:12. Record interval: 0. Symbol: ZNH5 | 2015-01-27 15:45:31 HD Request # 58 | Decompressing data. | 2015-01-27 15:45:31 HD Request # 58 | Receiving Intraday data for F.US.TYAH15 starting at 2015-01-27 15:45:12 | 2015-01-27 15:45:31 Socket (61) | Shutdown and closed. | 2015-01-27 15:45:31 The network socket for historical data has been closed. | 2015-01-27 15:45:31 HD Request # 58 | Received 1 record from 2015-01-27 15:45:12 to 2015-01-27 15:45:12 (0.0 seconds) and wrote 0 records for F.US.TYAH15 | 2015-01-27 15:45:31 HD Request # 58 | Intraday download COMPLETE for F.US.TYAH15. Completion time: 0s. Unique request ID: 57 | 2015-01-27 15:45:31 Removed historical data download ID 57 | 2015-01-27 15:45:31 Real-time Intraday chart data file updates started for F.US.TYAH15 | 2015-01-27 15:45:31 |
[2015-01-27 20:49:21] |
What is the symbol of the chart that is not updating? Or describe the problem.
[2015-01-27 20:55:01] |
crazybears - Posts: 314 |
in this case TF start updating again. usually is only TF that doesn't start to update again . i see other chat moving and new candles are formed instead TF is blocked on the bar was building when the disconnection happened. |
[2015-01-27 21:00:39] |
The market data request for TF was successful: CQG FIX Trading | Requesting market data for F.US.TFEH15 | 2015-01-27 15:45:25 If the chart is not updating, refer to help topic 3 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html If the connection is lost to CQG, upon the new connection, market data will be requested again for this symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-28 20:52:53] |
problem starts again after 2pm EST i see the interruption appears comparing TF charts between SC and another platform. other platform use CQG data too. after maximum 3 minute i see sierra chart download data like it had lost connection. to make it clear ,it's only TF that is stuck, so i presume only data that come directly from CQG because others EMINI which i'm using your datafeed works fine . and usually TF chart start works fine again . as usually SC starts to work faster than other platform again. it's these random disconnections that i don't understand why they happen :( and why they happen from the afternoon usually around 2pm EST and seem to stop before 4pm |
[2015-01-28 21:37:27] |
User11942 - Posts: 298 |
Hi Crazybears, I also had some disconnections today but with different error code though. It also happened a month ago for me and I created thread about it on this board. The answer from SC did indeed indicate a problem with receiving data on my side. That time I resolved the problem by cleaning cache and removing errors in my router. I think I have to do it again now. Although I have absolutely no idea what the code 1000 stands for (your case), but you may want to check your internet link and network hardware first.
[2015-01-28 22:24:33] |
In response to post #20, at the moment you are having the problem and when the TF chart is not updating, post approximately last 200 lines of the Message Log. In response to post #21, a status code of 1000 from the web socket is from CQG and we do not know what it means. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-04 20:50:43] |
HI :( after 4 minutes i was waiting if chart of TF starts i selected download data Intraday data recording state for symbol F.US.TFEH15 is set to download pending. | 2015-02-04 15:46:33 Reloading all charts with filename: F.US.TFEH15.scid | 2015-02-04 15:46:33 HD Request # 46 | Downloading Intraday chart data for F.US.TFEH15 to the file F.US.TFEH15.scid. Service: cqg | 2015-02-04 15:46:33 HD Request # 46 | Download start Date-Time: 2015-02-04 15:42:30.0 | 2015-02-04 15:46:33 HD Request # 46 | Using server: ds3.sierracharts.com port 10149 | 2015-02-04 15:46:33 Date rule based rollover from F.US.TFEH15 to next contract occurs at 2015-03-12. | 2015-02-04 15:46:33 Checking Intraday data file for symbol F.US.TFEH15 for the date range from 2014-12-11 to 0. | 2015-02-04 15:46:33 F.US.TFEH15 [C] 1 Min #4 | Symbols used for continuous contract chart: | 2015-02-04 15:46:33 F.US.TFEH15 | 2015-02-04 15:46:33 Date rule based rollover from F.US.TFEH15 to next contract occurs at 2015-03-12. | 2015-02-04 15:46:33 Checking Intraday data file for symbol F.US.TFEH15 for the date range from 2014-12-11 to 0. | 2015-02-04 15:46:33 F.US.TFEH15 [C] Renko 5-4-1-x #32 | Symbols used for continuous contract chart: | 2015-02-04 15:46:33 F.US.TFEH15 | 2015-02-04 15:46:33 Date rule based rollover from F.US.TFEH15 to next contract occurs at 2015-03-12. | 2015-02-04 15:46:33 Checking Intraday data file for symbol F.US.TFEH15 for the date range from 2014-12-11 to 0. | 2015-02-04 15:46:33 F.US.TFEH15 [C] 1 Min #13 | Symbols used for continuous contract chart: | 2015-02-04 15:46:33 F.US.TFEH15 | 2015-02-04 15:46:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-02-04 15:46:33 Socket (46) | Connected. | 2015-02-04 15:46:33 HD Request # 46 | Sending historical data logon request message. | 2015-02-04 15:46:33 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:33 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:33 HD Request # 46 | Requesting Intraday data. Start Date-Time: 2015-02-04 15:42:30. Record interval: 0. Symbol: F.US.TFEH15 | 2015-02-04 15:46:33 Chart #13 has tagged chart #4 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:33 Chart #13 has tagged chart #4 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:33 Chart #4 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:46:33 HD Request # 46 | Decompressing data. | 2015-02-04 15:46:33 HD Request # 46 | Receiving Intraday data for F.US.TFEH15 starting at 2015-02-04 15:42:30 | 2015-02-04 15:46:33 HD Request # 46 | Timestamp of first Intraday data file record written: 2015-02-04 15:42:31 | 2015-02-04 15:46:33 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:33 Chart #32 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:46:33 Socket (46) | Shutdown and closed. | 2015-02-04 15:46:34 The network socket for historical data has been closed. | 2015-02-04 15:46:34 HD Request # 46 | Received 2629 records from 2015-02-04 15:42:30 to 2015-02-04 15:46:32 (4.0 minutes) and wrote 2625 records for F.US.TFEH15 | 2015-02-04 15:46:34 HD Request # 46 | Intraday download COMPLETE for F.US.TFEH15. Completion time: 1s. Unique request ID: 49 | 2015-02-04 15:46:34 Removed historical data download ID 49 | 2015-02-04 15:46:34 Real-time Intraday chart data file updates started for F.US.TFEH15 | 2015-02-04 15:46:34 Chart #13 has tagged chart #4 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:34 Chart #4 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:46:34 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:34 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:46:34 Chart #32 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:46:34 |
[2015-02-04 20:55:46] |
Socket (31) | Closed. No error. | 2015-02-04 15:48:46
Websocket | Received opcode Close. Received status code: 1000 | 2015-02-04 15:48:46 CQG FIX Trading | Websocket closed. | 2015-02-04 15:48:46 Connection to the external service has been lost. | 2015-02-04 15:48:46 Socket (31) | SSL has been shut down. | 2015-02-04 15:48:46 Socket (31) | SSL object has been freed. SSL state is now disconnected. | 2015-02-04 15:48:46 Socket (31) | Shutdown and closed. | 2015-02-04 15:48:46 Network socket for websocket has been closed by remote side. | 2015-02-04 15:48:46 CQG FIX Trading | Websocket closed. | 2015-02-04 15:48:46 CQG FIX Trading FIX: DisconnectFIX called. | 2015-02-04 15:48:46 CQG FIX Trading FIX: Sending a Logout message. | 2015-02-04 15:48:46 CQG FIX Trading | Disconnected. | 2015-02-04 15:48:46 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-04 15:48:46 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-02-04 15:48:47 socket (30) | Shutdown and closed. | 2015-02-04 15:48:47 CQG FIX Trading FIX: Logged out and disconnected. | 2015-02-04 15:48:47 CQG FIX Trading FIX: Disconnected. | 2015-02-04 15:48:47 Socket (48) | Closed. No error. | 2015-02-04 15:52:08 Websocket | Received opcode Close. Received status code: 1000 | 2015-02-04 15:52:08 CQG FIX Trading | Websocket closed. | 2015-02-04 15:52:08 Connection to the external service has been lost. | 2015-02-04 15:52:08 Socket (48) | SSL has been shut down. | 2015-02-04 15:52:08 Socket (48) | SSL object has been freed. SSL state is now disconnected. | 2015-02-04 15:52:08 Socket (48) | Shutdown and closed. | 2015-02-04 15:52:08 Network socket for websocket has been closed by remote side. | 2015-02-04 15:52:08 CQG FIX Trading | Websocket closed. | 2015-02-04 15:52:08 CQG FIX Trading FIX: DisconnectFIX called. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Sending a Logout message. | 2015-02-04 15:52:08 CQG FIX Trading | Disconnected. | 2015-02-04 15:52:08 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-02-04 15:52:08 socket (47) | Shutdown and closed. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Logged out and disconnected. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Disconnected. | 2015-02-04 15:52:08 |
[2015-02-04 20:58:28] |
since last disconnection and reconnection TF hangs at 15:53 others works fine Socket (48) | Closed. No error. | 2015-02-04 15:52:08 Websocket | Received opcode Close. Received status code: 1000 | 2015-02-04 15:52:08 CQG FIX Trading | Websocket closed. | 2015-02-04 15:52:08 Connection to the external service has been lost. | 2015-02-04 15:52:08 Socket (48) | SSL has been shut down. | 2015-02-04 15:52:08 Socket (48) | SSL object has been freed. SSL state is now disconnected. | 2015-02-04 15:52:08 Socket (48) | Shutdown and closed. | 2015-02-04 15:52:08 Network socket for websocket has been closed by remote side. | 2015-02-04 15:52:08 CQG FIX Trading | Websocket closed. | 2015-02-04 15:52:08 CQG FIX Trading FIX: DisconnectFIX called. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Sending a Logout message. | 2015-02-04 15:52:08 CQG FIX Trading | Disconnected. | 2015-02-04 15:52:08 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-02-04 15:52:08 socket (47) | Shutdown and closed. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Logged out and disconnected. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Disconnected. | 2015-02-04 15:52:08 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-02-04 15:52:13 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-02-04 15:52:13 socket (56) | Connected. | 2015-02-04 15:52:13 CQG FIX Trading FIX: Sending the Logon message. | 2015-02-04 15:52:13 CQG FIX Trading | Connected to trading server. | 2015-02-04 15:52:14 CQG FIX Trading | Connecting to market data server. | 2015-02-04 15:52:14 Connecting to websocket server. | 2015-02-04 15:52:14 Socket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-02-04 15:52:14 CQG FIX Trading FIX - FCM name: AMP | 2015-02-04 15:52:14 Socket (57) | Connected. | 2015-02-04 15:52:17 Socket (57) | Starting SSL connection. | 2015-02-04 15:52:17 Socket (57) | SSL connection established. | 2015-02-04 15:52:18 Opening websocket. | 2015-02-04 15:52:18 Sending websocket handshake. | 2015-02-04 15:52:18 Received websocket handshake acknowledgment. | 2015-02-04 15:52:18 Web socket state is now open. | 2015-02-04 15:52:18 CQG FIX Trading | Websocket connected. | 2015-02-04 15:52:18 CQG FIX Trading | Sending market data logon message. | 2015-02-04 15:52:18 CQG FIX Trading | Logon successful. | 2015-02-04 15:52:19 CQG FIX Trading | Market data session connected. | 2015-02-04 15:52:19 Socket (50) | Shutdown and closed. | 2015-02-04 15:52:19 SC Exchange Data | Disconnected from the server. | 2015-02-04 15:52:19 Mapping F.US.TYAH15 to ZNH5. Service code: cbot | 2015-02-04 15:52:19 SC Exchange Data | Starting real-time market data updates for: ZNH5. ID: 1 | 2015-02-04 15:52:19 Using username 0 | 2015-02-04 15:52:19 SC Exchange Data | Connecting to the server scdf2.sierracharts.com. Port 443 | 2015-02-04 15:52:19 Mapping F.US.YMH15 to YMH5. Service code: cbot | 2015-02-04 15:52:19 SC Exchange Data | Starting real-time market data updates for: YMH5. ID: 2 | 2015-02-04 15:52:19 CQG FIX Trading | Starting real-time market data updates for: F.US.TFEH15. ID: 3 | 2015-02-04 15:52:19 CQG FIX Trading | Sending symbol resolution request for F.US.TFEH15 | 2015-02-04 15:52:19 Intraday data recording state for symbol F.US.TFEH15 is set to download pending. | 2015-02-04 15:52:19 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-02-04 15:52:19 HD Request # 53 | Downloading Intraday chart data for F.US.TFEH15 to the file F.US.TFEH15.scid. Service: cqg | 2015-02-04 15:52:19 HD Request # 53 | Download start Date-Time: 2015-02-04 15:50:34.0 | 2015-02-04 15:52:19 HD Request # 53 | Using server: ds5.sierracharts.com port 10149 | 2015-02-04 15:52:19 Mapping F.US.CLEH15 to CLH5. Service code: nymex | 2015-02-04 15:52:19 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-02-04 15:52:19 SC Exchange Data | Starting real-time market data updates for: CLH5. ID: 4 | 2015-02-04 15:52:19 Mapping F.US.GCEJ15 to GCJ5. Service code: comex | 2015-02-04 15:52:19 SC Exchange Data | Starting real-time market data updates for: GCJ5. ID: 5 | 2015-02-04 15:52:19 Mapping F.US.EU6H15 to 6EH5. Service code: cme | 2015-02-04 15:52:19 SC Exchange Data | Starting real-time market data updates for: 6EH5. ID: 6 | 2015-02-04 15:52:19 Mapping F.US.EPH15 to ESH5. Service code: cme | 2015-02-04 15:52:19 SC Exchange Data | Starting real-time market data updates for: ESH5. ID: 7 | 2015-02-04 15:52:19 Intraday data recording state for symbol F.US.EPH15 is set to download pending. | 2015-02-04 15:52:19 Mapping F.US.ENQH15 to NQH5. Service code: cme | 2015-02-04 15:52:19 SC Exchange Data | Starting real-time market data updates for: NQH5. ID: 8 | 2015-02-04 15:52:19 Intraday data recording state for symbol F.US.ENQH15 is set to download pending. | 2015-02-04 15:52:19 Intraday data recording state for symbol F.US.YMH15 is set to download pending. | 2015-02-04 15:52:19 Intraday data recording state for symbol F.US.CLEH15 is set to download pending. | 2015-02-04 15:52:19 Intraday data recording state for symbol F.US.GCEJ15 is set to download pending. | 2015-02-04 15:52:19 Socket (58) | Connected. | 2015-02-04 15:52:19 SC Exchange Data | Connected to server. | 2015-02-04 15:52:19 SC Exchange Data | Sending logon request message. | 2015-02-04 15:52:19 CQG FIX Trading | Requesting market data for F.US.TFEH15 | 2015-02-04 15:52:19 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-02-04 15:52:19 SC Exchange Data | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-02-04 15:52:19 SC Exchange Data | Successfully connected. | 2015-02-04 15:52:19 SC Exchange Data | Restarting real-time data updates for symbol: F.US.CLEH15 -> CLH5 | 2015-02-04 15:52:19 SC Exchange Data | Restarting real-time data updates for symbol: F.US.ENQH15 -> NQH5 | 2015-02-04 15:52:19 SC Exchange Data | Restarting real-time data updates for symbol: F.US.EPH15 -> ESH5 | 2015-02-04 15:52:19 SC Exchange Data | Restarting real-time data updates for symbol: F.US.EU6H15 -> 6EH5 | 2015-02-04 15:52:19 SC Exchange Data | Restarting real-time data updates for symbol: F.US.GCEJ15 -> GCJ5 | 2015-02-04 15:52:19 SC Exchange Data | Restarting real-time data updates for symbol: F.US.TYAH15 -> ZNH5 | 2015-02-04 15:52:19 SC Exchange Data | Restarting real-time data updates for symbol: F.US.YMH15 -> YMH5 | 2015-02-04 15:52:19 Date rule based rollover from ESZ06 to next contract occurs at 2006-12-07. | 2015-02-04 15:52:19 Date rule based rollover from ESH07 to next contract occurs at 2007-03-08. | 2015-02-04 15:52:19 Date rule based rollover from ESM07 to next contract occurs at 2007-06-07. | 2015-02-04 15:52:19 Date rule based rollover from ESU07 to next contract occurs at 2007-09-13. | 2015-02-04 15:52:19 Date rule based rollover from ESZ07 to next contract occurs at 2007-12-13. | 2015-02-04 15:52:19 Date rule based rollover from ESH08 to next contract occurs at 2008-03-13. | 2015-02-04 15:52:19 Date rule based rollover from ESM08 to next contract occurs at 2008-06-12. | 2015-02-04 15:52:19 Date rule based rollover from ESU08 to next contract occurs at 2008-09-11. | 2015-02-04 15:52:19 Date rule based rollover from ESZ08 to next contract occurs at 2008-12-11. | 2015-02-04 15:52:19 Date rule based rollover from ESH09 to next contract occurs at 2009-03-12. | 2015-02-04 15:52:19 Date rule based rollover from ESM09 to next contract occurs at 2009-06-11. | 2015-02-04 15:52:19 Date rule based rollover from ESU09 to next contract occurs at 2009-09-10. | 2015-02-04 15:52:19 Date rule based rollover from ESZ09 to next contract occurs at 2009-12-10. | 2015-02-04 15:52:19 Date rule based rollover from ESH10 to next contract occurs at 2010-03-11. | 2015-02-04 15:52:19 Date rule based rollover from ESM10 to next contract occurs at 2010-06-10. | 2015-02-04 15:52:19 Date rule based rollover from ESU10 to next contract occurs at 2010-09-09. | 2015-02-04 15:52:19 Date rule based rollover from ESZ10 to next contract occurs at 2010-12-09. | 2015-02-04 15:52:19 Date rule based rollover from ESH11 to next contract occurs at 2011-03-10. | 2015-02-04 15:52:19 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09. | 2015-02-04 15:52:19 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08. | 2015-02-04 15:52:19 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2015-02-04 15:52:19 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-02-04 15:52:19 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-02-04 15:52:19 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-02-04 15:52:19 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-02-04 15:52:19 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-02-04 15:52:19 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-02-04 15:52:19 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-02-04 15:52:19 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-02-04 15:52:19 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-02-04 15:52:19 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-02-04 15:52:19 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-02-04 15:52:19 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-02-04 15:52:19 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-02-04. | 2015-02-04 15:52:19 ESH15/F.US.EPH15 [C] [M] Daily #11 | Symbols used for continuous contract chart: | 2015-02-04 15:52:19 ESZ06 | 2015-02-04 15:52:19 ESH07 | 2015-02-04 15:52:19 ESM07 | 2015-02-04 15:52:19 ESU07 | 2015-02-04 15:52:19 ESZ07 | 2015-02-04 15:52:19 ESH08 | 2015-02-04 15:52:19 ESM08 | 2015-02-04 15:52:19 ESU08 | 2015-02-04 15:52:19 ESZ08 | 2015-02-04 15:52:19 ESH09 | 2015-02-04 15:52:19 ESM09 | 2015-02-04 15:52:19 ESU09 | 2015-02-04 15:52:19 ESZ09 | 2015-02-04 15:52:19 ESH10 | 2015-02-04 15:52:19 ESM10 | 2015-02-04 15:52:19 ESU10 | 2015-02-04 15:52:19 ESZ10 | 2015-02-04 15:52:19 ESH11 | 2015-02-04 15:52:19 ESM11 | 2015-02-04 15:52:19 ESU11 | 2015-02-04 15:52:19 ESZ11 | 2015-02-04 15:52:19 ESH12 | 2015-02-04 15:52:19 ESM12 | 2015-02-04 15:52:19 ESU12 | 2015-02-04 15:52:19 ESZ12 | 2015-02-04 15:52:19 ESH13 | 2015-02-04 15:52:19 ESM13 | 2015-02-04 15:52:19 ESU13 | 2015-02-04 15:52:19 ESZ13 | 2015-02-04 15:52:19 ESH14 | 2015-02-04 15:52:19 ESM14 | 2015-02-04 15:52:19 ESU14 | 2015-02-04 15:52:19 ESZ14 | 2015-02-04 15:52:19 ESH15 | 2015-02-04 15:52:19 Date rule based rollover from YMZ06 to next contract occurs at 2006-12-07. | 2015-02-04 15:52:19 Date rule based rollover from YMH07 to next contract occurs at 2007-03-08. | 2015-02-04 15:52:19 Date rule based rollover from YMM07 to next contract occurs at 2007-06-07. | 2015-02-04 15:52:19 Date rule based rollover from YMU07 to next contract occurs at 2007-09-13. | 2015-02-04 15:52:19 Date rule based rollover from YMZ07 to next contract occurs at 2007-12-13. | 2015-02-04 15:52:19 Date rule based rollover from YMH08 to next contract occurs at 2008-03-13. | 2015-02-04 15:52:19 Date rule based rollover from YMM08 to next contract occurs at 2008-06-12. | 2015-02-04 15:52:19 Date rule based rollover from YMU08 to next contract occurs at 2008-09-11. | 2015-02-04 15:52:19 Date rule based rollover from YMZ08 to next contract occurs at 2008-12-11. | 2015-02-04 15:52:19 Date rule based rollover from YMH09 to next contract occurs at 2009-03-12. | 2015-02-04 15:52:19 Date rule based rollover from YMM09 to next contract occurs at 2009-06-11. | 2015-02-04 15:52:19 Date rule based rollover from YMU09 to next contract occurs at 2009-09-10. | 2015-02-04 15:52:19 Date rule based rollover from YMZ09 to next contract occurs at 2009-12-10. | 2015-02-04 15:52:19 Date rule based rollover from YMH10 to next contract occurs at 2010-03-11. | 2015-02-04 15:52:19 Date rule based rollover from YMM10 to next contract occurs at 2010-06-10. | 2015-02-04 15:52:19 Date rule based rollover from YMU10 to next contract occurs at 2010-09-09. | 2015-02-04 15:52:19 Date rule based rollover from YMZ10 to next contract occurs at 2010-12-09. | 2015-02-04 15:52:19 Date rule based rollover from YMH11 to next contract occurs at 2011-03-10. | 2015-02-04 15:52:19 Date rule based rollover from YMM11 to next contract occurs at 2011-06-09. | 2015-02-04 15:52:19 Date rule based rollover from YMU11 to next contract occurs at 2011-09-08. | 2015-02-04 15:52:19 Date rule based rollover from YMZ11 to next contract occurs at 2011-12-08. | 2015-02-04 15:52:19 Date rule based rollover from YMH12 to next contract occurs at 2012-03-08. | 2015-02-04 15:52:19 Date rule based rollover from YMM12 to next contract occurs at 2012-06-07. | 2015-02-04 15:52:19 Date rule based rollover from YMU12 to next contract occurs at 2012-09-13. | 2015-02-04 15:52:19 Date rule based rollover from YMZ12 to next contract occurs at 2012-12-13. | 2015-02-04 15:52:19 Date rule based rollover from YMH13 to next contract occurs at 2013-03-07. | 2015-02-04 15:52:19 Date rule based rollover from YMM13 to next contract occurs at 2013-06-13. | 2015-02-04 15:52:19 Date rule based rollover from YMU13 to next contract occurs at 2013-09-12. | 2015-02-04 15:52:19 Date rule based rollover from YMZ13 to next contract occurs at 2013-12-12. | 2015-02-04 15:52:19 Date rule based rollover from YMH14 to next contract occurs at 2014-03-13. | 2015-02-04 15:52:19 Date rule based rollover from YMM14 to next contract occurs at 2014-06-12. | 2015-02-04 15:52:19 Date rule based rollover from YMU14 to next contract occurs at 2014-09-11. | 2015-02-04 15:52:19 Date rule based rollover from YMZ14 to next contract occurs at 2014-12-11. | 2015-02-04 15:52:19 Date rule based rollover from YMH15 to next contract occurs at 2015-03-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol YMH15 for the date range from 2014-12-11 to 2015-02-04. | 2015-02-04 15:52:19 YMH15/F.US.YMH15 [C] [M] Daily #21 | Symbols used for continuous contract chart: | 2015-02-04 15:52:19 YMZ06 | 2015-02-04 15:52:19 YMH07 | 2015-02-04 15:52:19 YMM07 | 2015-02-04 15:52:19 YMU07 | 2015-02-04 15:52:19 YMZ07 | 2015-02-04 15:52:19 YMH08 | 2015-02-04 15:52:19 YMM08 | 2015-02-04 15:52:19 YMU08 | 2015-02-04 15:52:19 YMZ08 | 2015-02-04 15:52:19 YMH09 | 2015-02-04 15:52:19 YMM09 | 2015-02-04 15:52:19 YMU09 | 2015-02-04 15:52:19 YMZ09 | 2015-02-04 15:52:19 YMH10 | 2015-02-04 15:52:19 YMM10 | 2015-02-04 15:52:19 YMU10 | 2015-02-04 15:52:19 YMZ10 | 2015-02-04 15:52:19 YMH11 | 2015-02-04 15:52:19 YMM11 | 2015-02-04 15:52:19 YMU11 | 2015-02-04 15:52:19 YMZ11 | 2015-02-04 15:52:19 YMH12 | 2015-02-04 15:52:19 YMM12 | 2015-02-04 15:52:19 YMU12 | 2015-02-04 15:52:19 YMZ12 | 2015-02-04 15:52:19 YMH13 | 2015-02-04 15:52:19 YMM13 | 2015-02-04 15:52:19 YMU13 | 2015-02-04 15:52:19 YMZ13 | 2015-02-04 15:52:19 YMH14 | 2015-02-04 15:52:19 YMM14 | 2015-02-04 15:52:19 YMU14 | 2015-02-04 15:52:19 YMZ14 | 2015-02-04 15:52:19 YMH15 | 2015-02-04 15:52:19 Date rule based rollover from RJZ06 to next contract occurs at 2006-12-07. | 2015-02-04 15:52:19 Date rule based rollover from RJH07 to next contract occurs at 2007-03-08. | 2015-02-04 15:52:19 Date rule based rollover from RJM07 to next contract occurs at 2007-06-07. | 2015-02-04 15:52:19 Date rule based rollover from RJU07 to next contract occurs at 2007-09-13. | 2015-02-04 15:52:19 Date rule based rollover from RJZ07 to next contract occurs at 2007-12-13. | 2015-02-04 15:52:19 Date rule based rollover from RJH08 to next contract occurs at 2008-03-13. | 2015-02-04 15:52:19 Date rule based rollover from RJM08 to next contract occurs at 2008-06-12. | 2015-02-04 15:52:19 Date rule based rollover from RJU08 to next contract occurs at 2008-09-11. | 2015-02-04 15:52:19 Date rule based rollover from RJZ08 to next contract occurs at 2008-12-11. | 2015-02-04 15:52:19 Date rule based rollover from RJH09 to next contract occurs at 2009-03-12. | 2015-02-04 15:52:19 Date rule based rollover from RJM09 to next contract occurs at 2009-06-11. | 2015-02-04 15:52:19 Date rule based rollover from RJU09 to next contract occurs at 2009-09-10. | 2015-02-04 15:52:19 Date rule based rollover from RJZ09 to next contract occurs at 2009-12-10. | 2015-02-04 15:52:19 Date rule based rollover from RJH10 to next contract occurs at 2010-03-11. | 2015-02-04 15:52:19 Date rule based rollover from RJM10 to next contract occurs at 2010-06-10. | 2015-02-04 15:52:19 Date rule based rollover from RJU10 to next contract occurs at 2010-09-09. | 2015-02-04 15:52:19 Date rule based rollover from RJZ10 to next contract occurs at 2010-12-09. | 2015-02-04 15:52:19 Date rule based rollover from RJH11 to next contract occurs at 2011-03-10. | 2015-02-04 15:52:19 Date rule based rollover from RJM11 to next contract occurs at 2011-06-09. | 2015-02-04 15:52:19 Date rule based rollover from RJU11 to next contract occurs at 2011-09-08. | 2015-02-04 15:52:19 Date rule based rollover from RJZ11 to next contract occurs at 2011-12-08. | 2015-02-04 15:52:19 Date rule based rollover from RJH12 to next contract occurs at 2012-03-08. | 2015-02-04 15:52:19 Date rule based rollover from RJM12 to next contract occurs at 2012-06-07. | 2015-02-04 15:52:19 Date rule based rollover from RJU12 to next contract occurs at 2012-09-13. | 2015-02-04 15:52:19 Date rule based rollover from RJZ12 to next contract occurs at 2012-12-13. | 2015-02-04 15:52:19 Date rule based rollover from RJH13 to next contract occurs at 2013-03-07. | 2015-02-04 15:52:19 Date rule based rollover from RJM13 to next contract occurs at 2013-06-13. | 2015-02-04 15:52:19 Date rule based rollover from RJU13 to next contract occurs at 2013-09-12. | 2015-02-04 15:52:19 Date rule based rollover from RJZ13 to next contract occurs at 2013-12-12. | 2015-02-04 15:52:19 Date rule based rollover from RJH14 to next contract occurs at 2014-03-13. | 2015-02-04 15:52:19 Date rule based rollover from RJM14 to next contract occurs at 2014-06-12. | 2015-02-04 15:52:19 Date rule based rollover from RJU14 to next contract occurs at 2014-09-11. | 2015-02-04 15:52:19 Date rule based rollover from RJZ14 to next contract occurs at 2014-12-11. | 2015-02-04 15:52:19 Date rule based rollover from RJH15 to next contract occurs at 2015-03-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-02-04 15:52:19 Checking Daily data file for symbol RJH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol RJH15 for the date range from 2014-12-11 to 2015-02-04. | 2015-02-04 15:52:20 RJH15/F.US.TFEH15 [C] Daily #22 | Symbols used for continuous contract chart: | 2015-02-04 15:52:20 RJZ06 | 2015-02-04 15:52:20 RJH07 | 2015-02-04 15:52:20 RJM07 | 2015-02-04 15:52:20 RJU07 | 2015-02-04 15:52:20 RJZ07 | 2015-02-04 15:52:20 RJH08 | 2015-02-04 15:52:20 RJM08 | 2015-02-04 15:52:20 RJU08 | 2015-02-04 15:52:20 RJZ08 | 2015-02-04 15:52:20 RJH09 | 2015-02-04 15:52:20 RJM09 | 2015-02-04 15:52:20 RJU09 | 2015-02-04 15:52:20 RJZ09 | 2015-02-04 15:52:20 RJH10 | 2015-02-04 15:52:20 RJM10 | 2015-02-04 15:52:20 RJU10 | 2015-02-04 15:52:20 RJZ10 | 2015-02-04 15:52:20 RJH11 | 2015-02-04 15:52:20 RJM11 | 2015-02-04 15:52:20 RJU11 | 2015-02-04 15:52:20 RJZ11 | 2015-02-04 15:52:20 RJH12 | 2015-02-04 15:52:20 RJM12 | 2015-02-04 15:52:20 RJU12 | 2015-02-04 15:52:20 RJZ12 | 2015-02-04 15:52:20 RJH13 | 2015-02-04 15:52:20 RJM13 | 2015-02-04 15:52:20 RJU13 | 2015-02-04 15:52:20 RJZ13 | 2015-02-04 15:52:20 RJH14 | 2015-02-04 15:52:20 RJM14 | 2015-02-04 15:52:20 RJU14 | 2015-02-04 15:52:20 RJZ14 | 2015-02-04 15:52:20 RJH15 | 2015-02-04 15:52:20 Date rule based rollover from E6Z06 to next contract occurs at 2006-12-18. | 2015-02-04 15:52:20 Date rule based rollover from E6H07 to next contract occurs at 2007-03-19. | 2015-02-04 15:52:20 Date rule based rollover from E6M07 to next contract occurs at 2007-06-18. | 2015-02-04 15:52:20 Date rule based rollover from E6U07 to next contract occurs at 2007-09-17. | 2015-02-04 15:52:20 Date rule based rollover from E6Z07 to next contract occurs at 2007-12-17. | 2015-02-04 15:52:20 Date rule based rollover from E6H08 to next contract occurs at 2008-03-17. | 2015-02-04 15:52:20 Date rule based rollover from E6M08 to next contract occurs at 2008-06-16. | 2015-02-04 15:52:20 Date rule based rollover from E6U08 to next contract occurs at 2008-09-15. | 2015-02-04 15:52:20 Date rule based rollover from E6Z08 to next contract occurs at 2008-12-15. | 2015-02-04 15:52:20 Date rule based rollover from E6H09 to next contract occurs at 2009-03-16. | 2015-02-04 15:52:20 Date rule based rollover from E6M09 to next contract occurs at 2009-06-15. | 2015-02-04 15:52:20 Date rule based rollover from E6U09 to next contract occurs at 2009-09-14. | 2015-02-04 15:52:20 Date rule based rollover from E6Z09 to next contract occurs at 2009-12-14. | 2015-02-04 15:52:20 Date rule based rollover from E6H10 to next contract occurs at 2010-03-15. | 2015-02-04 15:52:20 Date rule based rollover from E6M10 to next contract occurs at 2010-06-14. | 2015-02-04 15:52:20 Date rule based rollover from E6U10 to next contract occurs at 2010-09-13. | 2015-02-04 15:52:20 Date rule based rollover from E6Z10 to next contract occurs at 2010-12-13. | 2015-02-04 15:52:20 Date rule based rollover from E6H11 to next contract occurs at 2011-03-14. | 2015-02-04 15:52:20 Date rule based rollover from E6M11 to next contract occurs at 2011-06-13. | 2015-02-04 15:52:20 Date rule based rollover from E6U11 to next contract occurs at 2011-09-19. | 2015-02-04 15:52:20 Date rule based rollover from E6Z11 to next contract occurs at 2011-12-19. | 2015-02-04 15:52:20 Date rule based rollover from E6H12 to next contract occurs at 2012-03-19. | 2015-02-04 15:52:20 Date rule based rollover from E6M12 to next contract occurs at 2012-06-18. | 2015-02-04 15:52:20 Date rule based rollover from E6U12 to next contract occurs at 2012-09-17. | 2015-02-04 15:52:20 Date rule based rollover from E6Z12 to next contract occurs at 2012-12-17. | 2015-02-04 15:52:20 Date rule based rollover from E6H13 to next contract occurs at 2013-03-18. | 2015-02-04 15:52:20 Date rule based rollover from E6M13 to next contract occurs at 2013-06-17. | 2015-02-04 15:52:20 Date rule based rollover from E6U13 to next contract occurs at 2013-09-16. | 2015-02-04 15:52:20 Date rule based rollover from E6Z13 to next contract occurs at 2013-12-16. | 2015-02-04 15:52:20 Date rule based rollover from E6H14 to next contract occurs at 2014-03-17. | 2015-02-04 15:52:20 Date rule based rollover from E6M14 to next contract occurs at 2014-06-16. | 2015-02-04 15:52:20 Date rule based rollover from E6U14 to next contract occurs at 2014-09-15. | 2015-02-04 15:52:20 Date rule based rollover from E6Z14 to next contract occurs at 2014-12-15. | 2015-02-04 15:52:20 Date rule based rollover from E6H15 to next contract occurs at 2015-03-16. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z06 for the date range from 2006-09-18 to 2006-12-18. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H07 for the date range from 2006-12-18 to 2007-03-19. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M07 for the date range from 2007-03-19 to 2007-06-18. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U07 for the date range from 2007-06-18 to 2007-09-17. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z07 for the date range from 2007-09-17 to 2007-12-17. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H08 for the date range from 2007-12-17 to 2008-03-17. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M08 for the date range from 2008-03-17 to 2008-06-16. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U08 for the date range from 2008-06-16 to 2008-09-15. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z08 for the date range from 2008-09-15 to 2008-12-15. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H09 for the date range from 2008-12-15 to 2009-03-16. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M09 for the date range from 2009-03-16 to 2009-06-15. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U09 for the date range from 2009-06-15 to 2009-09-14. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z09 for the date range from 2009-09-14 to 2009-12-14. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H10 for the date range from 2009-12-14 to 2010-03-15. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M10 for the date range from 2010-03-15 to 2010-06-14. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U10 for the date range from 2010-06-14 to 2010-09-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z10 for the date range from 2010-09-13 to 2010-12-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H11 for the date range from 2010-12-13 to 2011-03-14. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M11 for the date range from 2011-03-14 to 2011-06-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U11 for the date range from 2011-06-13 to 2011-09-19. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z11 for the date range from 2011-09-19 to 2011-12-19. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H12 for the date range from 2011-12-19 to 2012-03-19. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M12 for the date range from 2012-03-19 to 2012-06-18. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U12 for the date range from 2012-06-18 to 2012-09-17. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z12 for the date range from 2012-09-17 to 2012-12-17. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-18. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-17. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-16. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-16. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-17. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 2014-09-15. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6Z14 for the date range from 2014-09-15 to 2014-12-15. | 2015-02-04 15:52:20 Checking Daily data file for symbol E6H15 for the date range from 2014-12-15 to 2015-02-04. | 2015-02-04 15:52:20 E6H15/F.US.EU6H15 [C] [M] Daily #36 | Symbols used for continuous contract chart: | 2015-02-04 15:52:20 E6Z06 | 2015-02-04 15:52:20 E6H07 | 2015-02-04 15:52:20 E6M07 | 2015-02-04 15:52:20 E6U07 | 2015-02-04 15:52:20 E6Z07 | 2015-02-04 15:52:20 E6H08 | 2015-02-04 15:52:20 E6M08 | 2015-02-04 15:52:20 E6U08 | 2015-02-04 15:52:20 E6Z08 | 2015-02-04 15:52:20 E6H09 | 2015-02-04 15:52:20 E6M09 | 2015-02-04 15:52:20 E6U09 | 2015-02-04 15:52:20 E6Z09 | 2015-02-04 15:52:20 E6H10 | 2015-02-04 15:52:20 E6M10 | 2015-02-04 15:52:20 E6U10 | 2015-02-04 15:52:20 E6Z10 | 2015-02-04 15:52:20 E6H11 | 2015-02-04 15:52:20 E6M11 | 2015-02-04 15:52:20 E6U11 | 2015-02-04 15:52:20 E6Z11 | 2015-02-04 15:52:20 E6H12 | 2015-02-04 15:52:20 E6M12 | 2015-02-04 15:52:20 E6U12 | 2015-02-04 15:52:20 E6Z12 | 2015-02-04 15:52:20 E6H13 | 2015-02-04 15:52:20 E6M13 | 2015-02-04 15:52:20 E6U13 | 2015-02-04 15:52:20 E6Z13 | 2015-02-04 15:52:20 E6H14 | 2015-02-04 15:52:20 E6M14 | 2015-02-04 15:52:20 E6U14 | 2015-02-04 15:52:20 E6Z14 | 2015-02-04 15:52:20 E6H15 | 2015-02-04 15:52:20 Date rule based rollover from NQZ06 to next contract occurs at 2006-12-07. | 2015-02-04 15:52:20 Date rule based rollover from NQH07 to next contract occurs at 2007-03-08. | 2015-02-04 15:52:20 Date rule based rollover from NQM07 to next contract occurs at 2007-06-07. | 2015-02-04 15:52:20 Date rule based rollover from NQU07 to next contract occurs at 2007-09-13. | 2015-02-04 15:52:20 Date rule based rollover from NQZ07 to next contract occurs at 2007-12-13. | 2015-02-04 15:52:20 Date rule based rollover from NQH08 to next contract occurs at 2008-03-13. | 2015-02-04 15:52:20 Date rule based rollover from NQM08 to next contract occurs at 2008-06-12. | 2015-02-04 15:52:20 Date rule based rollover from NQU08 to next contract occurs at 2008-09-11. | 2015-02-04 15:52:20 Date rule based rollover from NQZ08 to next contract occurs at 2008-12-11. | 2015-02-04 15:52:20 Date rule based rollover from NQH09 to next contract occurs at 2009-03-12. | 2015-02-04 15:52:20 Date rule based rollover from NQM09 to next contract occurs at 2009-06-11. | 2015-02-04 15:52:20 Date rule based rollover from NQU09 to next contract occurs at 2009-09-10. | 2015-02-04 15:52:20 Date rule based rollover from NQZ09 to next contract occurs at 2009-12-10. | 2015-02-04 15:52:20 Date rule based rollover from NQH10 to next contract occurs at 2010-03-11. | 2015-02-04 15:52:20 Date rule based rollover from NQM10 to next contract occurs at 2010-06-10. | 2015-02-04 15:52:20 Date rule based rollover from NQU10 to next contract occurs at 2010-09-09. | 2015-02-04 15:52:20 Date rule based rollover from NQZ10 to next contract occurs at 2010-12-09. | 2015-02-04 15:52:20 Date rule based rollover from NQH11 to next contract occurs at 2011-03-10. | 2015-02-04 15:52:20 Date rule based rollover from NQM11 to next contract occurs at 2011-06-09. | 2015-02-04 15:52:20 Date rule based rollover from NQU11 to next contract occurs at 2011-09-08. | 2015-02-04 15:52:20 Date rule based rollover from NQZ11 to next contract occurs at 2011-12-08. | 2015-02-04 15:52:20 Date rule based rollover from NQH12 to next contract occurs at 2012-03-08. | 2015-02-04 15:52:20 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2015-02-04 15:52:20 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2015-02-04 15:52:20 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2015-02-04 15:52:20 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2015-02-04 15:52:20 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2015-02-04 15:52:20 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2015-02-04 15:52:20 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2015-02-04 15:52:20 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2015-02-04 15:52:20 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2015-02-04 15:52:20 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2015-02-04 15:52:20 Date rule based rollover from NQZ14 to next contract occurs at 2014-12-11. | 2015-02-04 15:52:20 Date rule based rollover from NQH15 to next contract occurs at 2015-03-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-02-04 15:52:20 Checking Daily data file for symbol NQH15 for the date range from 2014-12-11 to 2015-02-04. | 2015-02-04 15:52:20 NQH15/F.US.ENQH15 [C] [M] Daily #20 | Symbols used for continuous contract chart: | 2015-02-04 15:52:20 NQZ06 | 2015-02-04 15:52:20 NQH07 | 2015-02-04 15:52:20 NQM07 | 2015-02-04 15:52:20 NQU07 | 2015-02-04 15:52:20 NQZ07 | 2015-02-04 15:52:20 NQH08 | 2015-02-04 15:52:20 NQM08 | 2015-02-04 15:52:20 NQU08 | 2015-02-04 15:52:20 NQZ08 | 2015-02-04 15:52:20 NQH09 | 2015-02-04 15:52:20 NQM09 | 2015-02-04 15:52:20 NQU09 | 2015-02-04 15:52:20 NQZ09 | 2015-02-04 15:52:20 NQH10 | 2015-02-04 15:52:20 NQM10 | 2015-02-04 15:52:20 NQU10 | 2015-02-04 15:52:20 NQZ10 | 2015-02-04 15:52:20 NQH11 | 2015-02-04 15:52:20 NQM11 | 2015-02-04 15:52:20 NQU11 | 2015-02-04 15:52:20 NQZ11 | 2015-02-04 15:52:20 NQH12 | 2015-02-04 15:52:20 NQM12 | 2015-02-04 15:52:20 NQU12 | 2015-02-04 15:52:20 NQZ12 | 2015-02-04 15:52:20 NQH13 | 2015-02-04 15:52:20 NQM13 | 2015-02-04 15:52:20 NQU13 | 2015-02-04 15:52:20 NQZ13 | 2015-02-04 15:52:20 NQH14 | 2015-02-04 15:52:20 NQM14 | 2015-02-04 15:52:20 NQU14 | 2015-02-04 15:52:20 NQZ14 | 2015-02-04 15:52:20 NQH15 | 2015-02-04 15:52:20 Date rule based rollover from GCZ06 to next contract occurs at 2006-11-29. | 2015-02-04 15:52:20 Date rule based rollover from GCG07 to next contract occurs at 2007-01-30. | 2015-02-04 15:52:20 Date rule based rollover from GCJ07 to next contract occurs at 2007-03-29. | 2015-02-04 15:52:20 Date rule based rollover from GCM07 to next contract occurs at 2007-05-30. | 2015-02-04 15:52:20 Date rule based rollover from GCQ07 to next contract occurs at 2007-07-30. | 2015-02-04 15:52:20 Date rule based rollover from GCZ07 to next contract occurs at 2007-11-29. | 2015-02-04 15:52:20 Date rule based rollover from GCG08 to next contract occurs at 2008-01-30. | 2015-02-04 15:52:20 Date rule based rollover from GCJ08 to next contract occurs at 2008-03-28. | 2015-02-04 15:52:20 Date rule based rollover from GCM08 to next contract occurs at 2008-05-29. | 2015-02-04 15:52:20 Date rule based rollover from GCQ08 to next contract occurs at 2008-07-30. | 2015-02-04 15:52:20 Date rule based rollover from GCZ08 to next contract occurs at 2008-11-27. | 2015-02-04 15:52:20 Date rule based rollover from GCG09 to next contract occurs at 2009-01-29. | 2015-02-04 15:52:20 Date rule based rollover from GCJ09 to next contract occurs at 2009-03-30. | 2015-02-04 15:52:20 Date rule based rollover from GCM09 to next contract occurs at 2009-05-28. | 2015-02-04 15:52:20 Date rule based rollover from GCQ09 to next contract occurs at 2009-07-30. | 2015-02-04 15:52:20 Date rule based rollover from GCZ09 to next contract occurs at 2009-11-27. | 2015-02-04 15:52:20 Date rule based rollover from GCG10 to next contract occurs at 2010-01-28. | 2015-02-04 15:52:20 Date rule based rollover from GCJ10 to next contract occurs at 2010-03-30. | 2015-02-04 15:52:20 Date rule based rollover from GCM10 to next contract occurs at 2010-05-28. | 2015-02-04 15:52:20 Date rule based rollover from GCQ10 to next contract occurs at 2010-07-29. | 2015-02-04 15:52:20 Date rule based rollover from GCZ10 to next contract occurs at 2010-11-29. | 2015-02-04 15:52:20 Date rule based rollover from GCG11 to next contract occurs at 2011-01-28. | 2015-02-04 15:52:20 Date rule based rollover from GCJ11 to next contract occurs at 2011-03-30. | 2015-02-04 15:52:20 Date rule based rollover from GCM11 to next contract occurs at 2011-05-30. | 2015-02-04 15:52:20 Date rule based rollover from GCQ11 to next contract occurs at 2011-07-28. | 2015-02-04 15:52:20 Date rule based rollover from GCZ11 to next contract occurs at 2011-11-29. | 2015-02-04 15:52:20 Date rule based rollover from GCG12 to next contract occurs at 2012-01-30. | 2015-02-04 15:52:20 Date rule based rollover from GCJ12 to next contract occurs at 2012-03-29. | 2015-02-04 15:52:20 Date rule based rollover from GCM12 to next contract occurs at 2012-05-30. | 2015-02-04 15:52:20 Date rule based rollover from GCQ12 to next contract occurs at 2012-07-30. | 2015-02-04 15:52:20 Date rule based rollover from GCZ12 to next contract occurs at 2012-11-29. | 2015-02-04 15:52:20 Date rule based rollover from GCG13 to next contract occurs at 2013-01-30. | 2015-02-04 15:52:20 Date rule based rollover from GCJ13 to next contract occurs at 2013-03-28. | 2015-02-04 15:52:20 Date rule based rollover from GCM13 to next contract occurs at 2013-05-30. | 2015-02-04 15:52:20 Date rule based rollover from GCQ13 to next contract occurs at 2013-07-30. | 2015-02-04 15:52:20 Date rule based rollover from GCZ13 to next contract occurs at 2013-11-28. | 2015-02-04 15:52:20 Date rule based rollover from GCG14 to next contract occurs at 2014-01-30. | 2015-02-04 15:52:20 Date rule based rollover from GCJ14 to next contract occurs at 2014-03-28. | 2015-02-04 15:52:20 Date rule based rollover from GCM14 to next contract occurs at 2014-05-29. | 2015-02-04 15:52:20 Date rule based rollover from GCQ14 to next contract occurs at 2014-07-30. | 2015-02-04 15:52:20 Date rule based rollover from GCZ14 to next contract occurs at 2014-11-27. | 2015-02-04 15:52:20 Date rule based rollover from GCG15 to next contract occurs at 2015-01-29. | 2015-02-04 15:52:20 Date rule based rollover from GCJ15 to next contract occurs at 2015-03-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCZ06 for the date range from 2006-07-28 to 2006-11-29. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCG07 for the date range from 2006-11-29 to 2007-01-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCJ07 for the date range from 2007-01-30 to 2007-03-29. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCM07 for the date range from 2007-03-29 to 2007-05-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCQ07 for the date range from 2007-05-30 to 2007-07-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCZ07 for the date range from 2007-07-30 to 2007-11-29. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCG08 for the date range from 2007-11-29 to 2008-01-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCJ08 for the date range from 2008-01-30 to 2008-03-28. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCM08 for the date range from 2008-03-28 to 2008-05-29. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCQ08 for the date range from 2008-05-29 to 2008-07-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCZ08 for the date range from 2008-07-30 to 2008-11-27. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCG09 for the date range from 2008-11-27 to 2009-01-29. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCJ09 for the date range from 2009-01-29 to 2009-03-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCM09 for the date range from 2009-03-30 to 2009-05-28. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCQ09 for the date range from 2009-05-28 to 2009-07-30. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCZ09 for the date range from 2009-07-30 to 2009-11-27. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCG10 for the date range from 2009-11-27 to 2010-01-28. | 2015-02-04 15:52:20 Checking Daily data file for symbol GCJ10 for the date range from 2010-01-28 to 2010-03-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCM10 for the date range from 2010-03-30 to 2010-05-28. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCQ10 for the date range from 2010-05-28 to 2010-07-29. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCZ10 for the date range from 2010-07-29 to 2010-11-29. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCG11 for the date range from 2010-11-29 to 2011-01-28. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCJ11 for the date range from 2011-01-28 to 2011-03-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCM11 for the date range from 2011-03-30 to 2011-05-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCQ11 for the date range from 2011-05-30 to 2011-07-28. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCZ11 for the date range from 2011-07-28 to 2011-11-29. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCG12 for the date range from 2011-11-29 to 2012-01-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCJ12 for the date range from 2012-01-30 to 2012-03-29. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCM12 for the date range from 2012-03-29 to 2012-05-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCQ12 for the date range from 2012-05-30 to 2012-07-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCZ12 for the date range from 2012-07-30 to 2012-11-29. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCG13 for the date range from 2012-11-29 to 2013-01-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCJ13 for the date range from 2013-01-30 to 2013-03-28. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCM13 for the date range from 2013-03-28 to 2013-05-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCQ13 for the date range from 2013-05-30 to 2013-07-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCZ13 for the date range from 2013-07-30 to 2013-11-28. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCG14 for the date range from 2013-11-28 to 2014-01-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCJ14 for the date range from 2014-01-30 to 2014-03-28. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCM14 for the date range from 2014-03-28 to 2014-05-29. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCQ14 for the date range from 2014-05-29 to 2014-07-30. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCZ14 for the date range from 2014-07-30 to 2014-11-27. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCG15 for the date range from 2014-11-27 to 2015-01-29. | 2015-02-04 15:52:21 Checking Daily data file for symbol GCJ15 for the date range from 2015-01-29 to 2015-02-04. | 2015-02-04 15:52:21 GCJ15/F.US.GCEJ15 [C] [M] Daily #39 | Symbols used for continuous contract chart: | 2015-02-04 15:52:21 GCZ06 | 2015-02-04 15:52:21 GCG07 | 2015-02-04 15:52:21 GCJ07 | 2015-02-04 15:52:21 GCM07 | 2015-02-04 15:52:21 GCQ07 | 2015-02-04 15:52:21 GCZ07 | 2015-02-04 15:52:21 GCG08 | 2015-02-04 15:52:21 GCJ08 | 2015-02-04 15:52:21 GCM08 | 2015-02-04 15:52:21 GCQ08 | 2015-02-04 15:52:21 GCZ08 | 2015-02-04 15:52:21 GCG09 | 2015-02-04 15:52:21 GCJ09 | 2015-02-04 15:52:21 GCM09 | 2015-02-04 15:52:21 GCQ09 | 2015-02-04 15:52:21 GCZ09 | 2015-02-04 15:52:21 GCG10 | 2015-02-04 15:52:21 GCJ10 | 2015-02-04 15:52:21 GCM10 | 2015-02-04 15:52:21 GCQ10 | 2015-02-04 15:52:21 GCZ10 | 2015-02-04 15:52:21 GCG11 | 2015-02-04 15:52:21 GCJ11 | 2015-02-04 15:52:21 GCM11 | 2015-02-04 15:52:21 GCQ11 | 2015-02-04 15:52:21 GCZ11 | 2015-02-04 15:52:21 GCG12 | 2015-02-04 15:52:21 GCJ12 | 2015-02-04 15:52:21 GCM12 | 2015-02-04 15:52:21 GCQ12 | 2015-02-04 15:52:21 GCZ12 | 2015-02-04 15:52:21 GCG13 | 2015-02-04 15:52:21 GCJ13 | 2015-02-04 15:52:21 GCM13 | 2015-02-04 15:52:21 GCQ13 | 2015-02-04 15:52:21 GCZ13 | 2015-02-04 15:52:21 GCG14 | 2015-02-04 15:52:21 GCJ14 | 2015-02-04 15:52:21 GCM14 | 2015-02-04 15:52:21 GCQ14 | 2015-02-04 15:52:21 GCZ14 | 2015-02-04 15:52:21 GCG15 | 2015-02-04 15:52:21 GCJ15 | 2015-02-04 15:52:21 Socket (59) | Connected. | 2015-02-04 15:52:22 HD Request # 53 | Sending historical data logon request message. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ06 to next contract occurs at 2006-11-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNH07 to next contract occurs at 2007-02-28. | 2015-02-04 15:52:22 Date rule based rollover from ZNM07 to next contract occurs at 2007-05-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNU07 to next contract occurs at 2007-08-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ07 to next contract occurs at 2007-11-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNH08 to next contract occurs at 2008-02-29. | 2015-02-04 15:52:22 Date rule based rollover from ZNM08 to next contract occurs at 2008-05-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNU08 to next contract occurs at 2008-08-29. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ08 to next contract occurs at 2008-11-28. | 2015-02-04 15:52:22 Date rule based rollover from ZNH09 to next contract occurs at 2009-02-27. | 2015-02-04 15:52:22 Date rule based rollover from ZNM09 to next contract occurs at 2009-05-29. | 2015-02-04 15:52:22 Date rule based rollover from ZNU09 to next contract occurs at 2009-08-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ09 to next contract occurs at 2009-11-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNH10 to next contract occurs at 2010-02-26. | 2015-02-04 15:52:22 Date rule based rollover from ZNM10 to next contract occurs at 2010-05-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNU10 to next contract occurs at 2010-08-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ10 to next contract occurs at 2010-11-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNH11 to next contract occurs at 2011-02-28. | 2015-02-04 15:52:22 Date rule based rollover from ZNM11 to next contract occurs at 2011-05-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNU11 to next contract occurs at 2011-08-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ11 to next contract occurs at 2011-11-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNH12 to next contract occurs at 2012-02-29. | 2015-02-04 15:52:22 Date rule based rollover from ZNM12 to next contract occurs at 2012-05-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNU12 to next contract occurs at 2012-08-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ12 to next contract occurs at 2012-11-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNH13 to next contract occurs at 2013-02-28. | 2015-02-04 15:52:22 Date rule based rollover from ZNM13 to next contract occurs at 2013-05-31. | 2015-02-04 15:52:22 Date rule based rollover from ZNU13 to next contract occurs at 2013-08-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ13 to next contract occurs at 2013-11-29. | 2015-02-04 15:52:22 Date rule based rollover from ZNH14 to next contract occurs at 2014-02-28. | 2015-02-04 15:52:22 Date rule based rollover from ZNM14 to next contract occurs at 2014-05-30. | 2015-02-04 15:52:22 Date rule based rollover from ZNU14 to next contract occurs at 2014-08-29. | 2015-02-04 15:52:22 Date rule based rollover from ZNZ14 to next contract occurs at 2014-11-28. | 2015-02-04 15:52:22 Date rule based rollover from ZNH15 to next contract occurs at 2015-02-27. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ06 for the date range from 2006-08-31 to 2006-11-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH07 for the date range from 2006-11-30 to 2007-02-28. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM07 for the date range from 2007-02-28 to 2007-05-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU07 for the date range from 2007-05-31 to 2007-08-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ07 for the date range from 2007-08-31 to 2007-11-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH08 for the date range from 2007-11-30 to 2008-02-29. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM08 for the date range from 2008-02-29 to 2008-05-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU08 for the date range from 2008-05-30 to 2008-08-29. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ08 for the date range from 2008-08-29 to 2008-11-28. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH09 for the date range from 2008-11-28 to 2009-02-27. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM09 for the date range from 2009-02-27 to 2009-05-29. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU09 for the date range from 2009-05-29 to 2009-08-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ09 for the date range from 2009-08-31 to 2009-11-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH10 for the date range from 2009-11-30 to 2010-02-26. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM10 for the date range from 2010-02-26 to 2010-05-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU10 for the date range from 2010-05-31 to 2010-08-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ10 for the date range from 2010-08-31 to 2010-11-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH11 for the date range from 2010-11-30 to 2011-02-28. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM11 for the date range from 2011-02-28 to 2011-05-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU11 for the date range from 2011-05-31 to 2011-08-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ11 for the date range from 2011-08-31 to 2011-11-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH12 for the date range from 2011-11-30 to 2012-02-29. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM12 for the date range from 2012-02-29 to 2012-05-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU12 for the date range from 2012-05-31 to 2012-08-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ12 for the date range from 2012-08-31 to 2012-11-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH13 for the date range from 2012-11-30 to 2013-02-28. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM13 for the date range from 2013-02-28 to 2013-05-31. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU13 for the date range from 2013-05-31 to 2013-08-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ13 for the date range from 2013-08-30 to 2013-11-29. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH14 for the date range from 2013-11-29 to 2014-02-28. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNM14 for the date range from 2014-02-28 to 2014-05-30. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNU14 for the date range from 2014-05-30 to 2014-08-29. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNZ14 for the date range from 2014-08-29 to 2014-11-28. | 2015-02-04 15:52:22 Checking Daily data file for symbol ZNH15 for the date range from 2014-11-28 to 2015-02-04. | 2015-02-04 15:52:22 ZNH15/F.US.TYAH15 [C] [M] Daily #35 | Symbols used for continuous contract chart: | 2015-02-04 15:52:22 ZNZ06 | 2015-02-04 15:52:22 ZNH07 | 2015-02-04 15:52:22 ZNM07 | 2015-02-04 15:52:22 ZNU07 | 2015-02-04 15:52:22 ZNZ07 | 2015-02-04 15:52:22 ZNH08 | 2015-02-04 15:52:22 ZNM08 | 2015-02-04 15:52:22 ZNU08 | 2015-02-04 15:52:22 ZNZ08 | 2015-02-04 15:52:22 ZNH09 | 2015-02-04 15:52:22 ZNM09 | 2015-02-04 15:52:22 ZNU09 | 2015-02-04 15:52:22 ZNZ09 | 2015-02-04 15:52:22 ZNH10 | 2015-02-04 15:52:22 ZNM10 | 2015-02-04 15:52:22 ZNU10 | 2015-02-04 15:52:22 ZNZ10 | 2015-02-04 15:52:22 ZNH11 | 2015-02-04 15:52:22 ZNM11 | 2015-02-04 15:52:22 ZNU11 | 2015-02-04 15:52:22 ZNZ11 | 2015-02-04 15:52:22 ZNH12 | 2015-02-04 15:52:22 ZNM12 | 2015-02-04 15:52:22 ZNU12 | 2015-02-04 15:52:22 ZNZ12 | 2015-02-04 15:52:22 ZNH13 | 2015-02-04 15:52:22 ZNM13 | 2015-02-04 15:52:22 ZNU13 | 2015-02-04 15:52:22 ZNZ13 | 2015-02-04 15:52:22 ZNH14 | 2015-02-04 15:52:22 ZNM14 | 2015-02-04 15:52:22 ZNU14 | 2015-02-04 15:52:22 ZNZ14 | 2015-02-04 15:52:22 ZNH15 | 2015-02-04 15:52:22 Date rule based rollover from CLX06 to next contract occurs at 2006-10-19. | 2015-02-04 15:52:22 Date rule based rollover from CLZ06 to next contract occurs at 2006-11-20. | 2015-02-04 15:52:22 Date rule based rollover from CLF07 to next contract occurs at 2006-12-19. | 2015-02-04 15:52:22 Date rule based rollover from CLG07 to next contract occurs at 2007-01-19. | 2015-02-04 15:52:22 Date rule based rollover from CLH07 to next contract occurs at 2007-02-19. | 2015-02-04 15:52:22 Date rule based rollover from CLJ07 to next contract occurs at 2007-03-19. | 2015-02-04 15:52:22 Date rule based rollover from CLK07 to next contract occurs at 2007-04-19. | 2015-02-04 15:52:22 Date rule based rollover from CLM07 to next contract occurs at 2007-05-21. | 2015-02-04 15:52:22 Date rule based rollover from CLN07 to next contract occurs at 2007-06-19. | 2015-02-04 15:52:22 Date rule based rollover from CLQ07 to next contract occurs at 2007-07-19. | 2015-02-04 15:52:22 Date rule based rollover from CLU07 to next contract occurs at 2007-08-20. | 2015-02-04 15:52:22 Date rule based rollover from CLV07 to next contract occurs at 2007-09-19. | 2015-02-04 15:52:22 Date rule based rollover from CLX07 to next contract occurs at 2007-10-19. | 2015-02-04 15:52:22 Date rule based rollover from CLZ07 to next contract occurs at 2007-11-19. | 2015-02-04 15:52:22 Date rule based rollover from CLF08 to next contract occurs at 2007-12-19. | 2015-02-04 15:52:22 Date rule based rollover from CLG08 to next contract occurs at 2008-01-21. | 2015-02-04 15:52:22 Date rule based rollover from CLH08 to next contract occurs at 2008-02-19. | 2015-02-04 15:52:22 Date rule based rollover from CLJ08 to next contract occurs at 2008-03-19. | 2015-02-04 15:52:22 Date rule based rollover from CLK08 to next contract occurs at 2008-04-21. | 2015-02-04 15:52:22 Date rule based rollover from CLM08 to next contract occurs at 2008-05-19. | 2015-02-04 15:52:22 Date rule based rollover from CLN08 to next contract occurs at 2008-06-19. | 2015-02-04 15:52:22 Date rule based rollover from CLQ08 to next contract occurs at 2008-07-21. | 2015-02-04 15:52:22 Date rule based rollover from CLU08 to next contract occurs at 2008-08-19. | 2015-02-04 15:52:22 Date rule based rollover from CLV08 to next contract occurs at 2008-09-19. | 2015-02-04 15:52:22 Date rule based rollover from CLX08 to next contract occurs at 2008-10-20. | 2015-02-04 15:52:22 Date rule based rollover from CLZ08 to next contract occurs at 2008-11-19. | 2015-02-04 15:52:22 Date rule based rollover from CLF09 to next contract occurs at 2008-12-19. | 2015-02-04 15:52:22 Date rule based rollover from CLG09 to next contract occurs at 2009-01-19. | 2015-02-04 15:52:22 Date rule based rollover from CLH09 to next contract occurs at 2009-02-19. | 2015-02-04 15:52:22 Date rule based rollover from CLJ09 to next contract occurs at 2009-03-19. | 2015-02-04 15:52:22 Date rule based rollover from CLK09 to next contract occurs at 2009-04-20. | 2015-02-04 15:52:22 Date rule based rollover from CLM09 to next contract occurs at 2009-05-19. | 2015-02-04 15:52:22 Date rule based rollover from CLN09 to next contract occurs at 2009-06-19. | 2015-02-04 15:52:22 Date rule based rollover from CLQ09 to next contract occurs at 2009-07-20. | 2015-02-04 15:52:22 Date rule based rollover from CLU09 to next contract occurs at 2009-08-19. | 2015-02-04 15:52:22 Date rule based rollover from CLV09 to next contract occurs at 2009-09-21. | 2015-02-04 15:52:22 Date rule based rollover from CLX09 to next contract occurs at 2009-10-19. | 2015-02-04 15:52:22 Date rule based rollover from CLZ09 to next contract occurs at 2009-11-19. | 2015-02-04 15:52:22 Date rule based rollover from CLF10 to next contract occurs at 2009-12-21. | 2015-02-04 15:52:22 Date rule based rollover from CLG10 to next contract occurs at 2010-01-19. | 2015-02-04 15:52:22 Date rule based rollover from CLH10 to next contract occurs at 2010-02-19. | 2015-02-04 15:52:22 Date rule based rollover from CLJ10 to next contract occurs at 2010-03-19. | 2015-02-04 15:52:22 Date rule based rollover from CLK10 to next contract occurs at 2010-04-19. | 2015-02-04 15:52:22 Date rule based rollover from CLM10 to next contract occurs at 2010-05-19. | 2015-02-04 15:52:22 Date rule based rollover from CLN10 to next contract occurs at 2010-06-21. | 2015-02-04 15:52:22 Date rule based rollover from CLQ10 to next contract occurs at 2010-07-19. | 2015-02-04 15:52:22 Date rule based rollover from CLU10 to next contract occurs at 2010-08-19. | 2015-02-04 15:52:22 Date rule based rollover from CLV10 to next contract occurs at 2010-09-20. | 2015-02-04 15:52:22 Date rule based rollover from CLX10 to next contract occurs at 2010-10-19. | 2015-02-04 15:52:22 Date rule based rollover from CLZ10 to next contract occurs at 2010-11-19. | 2015-02-04 15:52:22 Date rule based rollover from CLF11 to next contract occurs at 2010-12-20. | 2015-02-04 15:52:22 Date rule based rollover from CLG11 to next contract occurs at 2011-01-19. | 2015-02-04 15:52:22 Date rule based rollover from CLH11 to next contract occurs at 2011-02-21. | 2015-02-04 15:52:22 Date rule based rollover from CLJ11 to next contract occurs at 2011-03-21. | 2015-02-04 15:52:22 Date rule based rollover from CLK11 to next contract occurs at 2011-04-19. | 2015-02-04 15:52:22 Date rule based rollover from CLM11 to next contract occurs at 2011-05-19. | 2015-02-04 15:52:22 Date rule based rollover from CLN11 to next contract occurs at 2011-06-20. | 2015-02-04 15:52:22 Date rule based rollover from CLQ11 to next contract occurs at 2011-07-19. | 2015-02-04 15:52:22 Date rule based rollover from CLU11 to next contract occurs at 2011-08-19. | 2015-02-04 15:52:22 Date rule based rollover from CLV11 to next contract occurs at 2011-09-19. | 2015-02-04 15:52:22 Date rule based rollover from CLX11 to next contract occurs at 2011-10-19. | 2015-02-04 15:52:22 Date rule based rollover from CLZ11 to next contract occurs at 2011-11-21. | 2015-02-04 15:52:22 Date rule based rollover from CLF12 to next contract occurs at 2011-12-19. | 2015-02-04 15:52:22 Date rule based rollover from CLG12 to next contract occurs at 2012-01-19. | 2015-02-04 15:52:22 Date rule based rollover from CLH12 to next contract occurs at 2012-02-20. | 2015-02-04 15:52:22 Date rule based rollover from CLJ12 to next contract occurs at 2012-03-19. | 2015-02-04 15:52:22 Date rule based rollover from CLK12 to next contract occurs at 2012-04-19. | 2015-02-04 15:52:22 Date rule based rollover from CLM12 to next contract occurs at 2012-05-21. | 2015-02-04 15:52:22 Date rule based rollover from CLN12 to next contract occurs at 2012-06-19. | 2015-02-04 15:52:22 Date rule based rollover from CLQ12 to next contract occurs at 2012-07-19. | 2015-02-04 15:52:22 Date rule based rollover from CLU12 to next contract occurs at 2012-08-20. | 2015-02-04 15:52:22 Date rule based rollover from CLV12 to next contract occurs at 2012-09-19. | 2015-02-04 15:52:22 Date rule based rollover from CLX12 to next contract occurs at 2012-10-19. | 2015-02-04 15:52:22 Date rule based rollover from CLZ12 to next contract occurs at 2012-11-19. | 2015-02-04 15:52:22 Date rule based rollover from CLF13 to next contract occurs at 2012-12-19. | 2015-02-04 15:52:22 Date rule based rollover from CLG13 to next contract occurs at 2013-01-21. | 2015-02-04 15:52:22 Date rule based rollover from CLH13 to next contract occurs at 2013-02-19. | 2015-02-04 15:52:22 Date rule based rollover from CLJ13 to next contract occurs at 2013-03-19. | 2015-02-04 15:52:22 Date rule based rollover from CLK13 to next contract occurs at 2013-04-19. | 2015-02-04 15:52:22 Date rule based rollover from CLM13 to next contract occurs at 2013-05-20. | 2015-02-04 15:52:22 Date rule based rollover from CLN13 to next contract occurs at 2013-06-19. | 2015-02-04 15:52:22 Date rule based rollover from CLQ13 to next contract occurs at 2013-07-19. | 2015-02-04 15:52:22 Date rule based rollover from CLU13 to next contract occurs at 2013-08-19. | 2015-02-04 15:52:22 Date rule based rollover from CLV13 to next contract occurs at 2013-09-19. | 2015-02-04 15:52:22 Date rule based rollover from CLX13 to next contract occurs at 2013-10-21. | 2015-02-04 15:52:22 Date rule based rollover from CLZ13 to next contract occurs at 2013-11-19. | 2015-02-04 15:52:22 Date rule based rollover from CLF14 to next contract occurs at 2013-12-19. | 2015-02-04 15:52:22 Date rule based rollover from CLG14 to next contract occurs at 2014-01-20. | 2015-02-04 15:52:22 Date rule based rollover from CLH14 to next contract occurs at 2014-02-19. | 2015-02-04 15:52:22 Date rule based rollover from CLJ14 to next contract occurs at 2014-03-19. | 2015-02-04 15:52:22 Date rule based rollover from CLK14 to next contract occurs at 2014-04-21. | 2015-02-04 15:52:22 Date rule based rollover from CLM14 to next contract occurs at 2014-05-19. | 2015-02-04 15:52:22 Date rule based rollover from CLN14 to next contract occurs at 2014-06-19. | 2015-02-04 15:52:22 Date rule based rollover from CLQ14 to next contract occurs at 2014-07-21. | 2015-02-04 15:52:22 Date rule based rollover from CLU14 to next contract occurs at 2014-08-19. | 2015-02-04 15:52:22 Date rule based rollover from CLV14 to next contract occurs at 2014-09-19. | 2015-02-04 15:52:22 Date rule based rollover from CLX14 to next contract occurs at 2014-10-20. | 2015-02-04 15:52:22 Date rule based rollover from CLZ14 to next contract occurs at 2014-11-19. | 2015-02-04 15:52:22 Date rule based rollover from CLF15 to next contract occurs at 2014-12-19. | 2015-02-04 15:52:22 Date rule based rollover from CLG15 to next contract occurs at 2015-01-19. | 2015-02-04 15:52:22 Date rule based rollover from CLH15 to next contract occurs at 2015-02-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX06 for the date range from 2006-09-19 to 2006-10-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ06 for the date range from 2006-10-19 to 2006-11-20. | 2015-02-04 15:52:22 Skipping Daily data download for symbol CLZ06 since download was already done in last 24 hours. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF07 for the date range from 2006-11-20 to 2006-12-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG07 for the date range from 2006-12-19 to 2007-01-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH07 for the date range from 2007-01-19 to 2007-02-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ07 for the date range from 2007-02-19 to 2007-03-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK07 for the date range from 2007-03-19 to 2007-04-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM07 for the date range from 2007-04-19 to 2007-05-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN07 for the date range from 2007-05-21 to 2007-06-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ07 for the date range from 2007-06-19 to 2007-07-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU07 for the date range from 2007-07-19 to 2007-08-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV07 for the date range from 2007-08-20 to 2007-09-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX07 for the date range from 2007-09-19 to 2007-10-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ07 for the date range from 2007-10-19 to 2007-11-19. | 2015-02-04 15:52:22 Skipping Daily data download for symbol CLZ07 since download was already done in last 24 hours. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF08 for the date range from 2007-11-19 to 2007-12-19. | 2015-02-04 15:52:22 Skipping Daily data download for symbol CLF08 since download was already done in last 24 hours. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG08 for the date range from 2007-12-19 to 2008-01-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH08 for the date range from 2008-01-21 to 2008-02-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ08 for the date range from 2008-02-19 to 2008-03-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK08 for the date range from 2008-03-19 to 2008-04-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM08 for the date range from 2008-04-21 to 2008-05-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN08 for the date range from 2008-05-19 to 2008-06-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ08 for the date range from 2008-06-19 to 2008-07-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU08 for the date range from 2008-07-21 to 2008-08-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV08 for the date range from 2008-08-19 to 2008-09-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX08 for the date range from 2008-09-19 to 2008-10-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ08 for the date range from 2008-10-20 to 2008-11-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF09 for the date range from 2008-11-19 to 2008-12-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG09 for the date range from 2008-12-19 to 2009-01-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH09 for the date range from 2009-01-19 to 2009-02-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ09 for the date range from 2009-02-19 to 2009-03-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK09 for the date range from 2009-03-19 to 2009-04-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM09 for the date range from 2009-04-20 to 2009-05-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN09 for the date range from 2009-05-19 to 2009-06-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ09 for the date range from 2009-06-19 to 2009-07-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU09 for the date range from 2009-07-20 to 2009-08-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV09 for the date range from 2009-08-19 to 2009-09-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX09 for the date range from 2009-09-21 to 2009-10-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ09 for the date range from 2009-10-19 to 2009-11-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF10 for the date range from 2009-11-19 to 2009-12-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG10 for the date range from 2009-12-21 to 2010-01-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH10 for the date range from 2010-01-19 to 2010-02-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ10 for the date range from 2010-02-19 to 2010-03-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK10 for the date range from 2010-03-19 to 2010-04-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM10 for the date range from 2010-04-19 to 2010-05-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN10 for the date range from 2010-05-19 to 2010-06-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ10 for the date range from 2010-06-21 to 2010-07-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU10 for the date range from 2010-07-19 to 2010-08-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV10 for the date range from 2010-08-19 to 2010-09-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX10 for the date range from 2010-09-20 to 2010-10-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ10 for the date range from 2010-10-19 to 2010-11-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF11 for the date range from 2010-11-19 to 2010-12-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG11 for the date range from 2010-12-20 to 2011-01-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH11 for the date range from 2011-01-19 to 2011-02-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ11 for the date range from 2011-02-21 to 2011-03-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK11 for the date range from 2011-03-21 to 2011-04-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM11 for the date range from 2011-04-19 to 2011-05-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN11 for the date range from 2011-05-19 to 2011-06-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ11 for the date range from 2011-06-20 to 2011-07-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU11 for the date range from 2011-07-19 to 2011-08-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV11 for the date range from 2011-08-19 to 2011-09-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX11 for the date range from 2011-09-19 to 2011-10-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ11 for the date range from 2011-10-19 to 2011-11-21. | 2015-02-04 15:52:22 Skipping Daily data download for symbol CLZ11 since download was already done in last 24 hours. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF12 for the date range from 2011-11-21 to 2011-12-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG12 for the date range from 2011-12-19 to 2012-01-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH12 for the date range from 2012-01-19 to 2012-02-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ12 for the date range from 2012-02-20 to 2012-03-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK12 for the date range from 2012-03-19 to 2012-04-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM12 for the date range from 2012-04-19 to 2012-05-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2015-02-04 15:52:22 HD Request # 53 | Requesting Intraday data. Start Date-Time: 2015-02-04 15:50:34. Record interval: 0. Symbol: F.US.TFEH15 | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-20. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLZ14 for the date range from 2014-10-20 to 2014-11-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLF15 for the date range from 2014-11-19 to 2014-12-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLG15 for the date range from 2014-12-19 to 2015-01-19. | 2015-02-04 15:52:22 Checking Daily data file for symbol CLH15 for the date range from 2015-01-19 to 2015-02-04. | 2015-02-04 15:52:22 CLH15/F.US.CLEH15 [C] [M] Daily #14 | Symbols used for continuous contract chart: | 2015-02-04 15:52:22 CLX06 | 2015-02-04 15:52:22 CLZ06 | 2015-02-04 15:52:22 CLF07 | 2015-02-04 15:52:22 CLG07 | 2015-02-04 15:52:22 CLH07 | 2015-02-04 15:52:22 CLJ07 | 2015-02-04 15:52:22 CLK07 | 2015-02-04 15:52:22 CLM07 | 2015-02-04 15:52:22 CLN07 | 2015-02-04 15:52:22 CLQ07 | 2015-02-04 15:52:22 CLU07 | 2015-02-04 15:52:22 CLV07 | 2015-02-04 15:52:22 CLX07 | 2015-02-04 15:52:22 CLZ07 | 2015-02-04 15:52:22 CLF08 | 2015-02-04 15:52:22 CLG08 | 2015-02-04 15:52:22 CLH08 | 2015-02-04 15:52:22 CLJ08 | 2015-02-04 15:52:22 CLK08 | 2015-02-04 15:52:22 CLM08 | 2015-02-04 15:52:22 CLN08 | 2015-02-04 15:52:22 CLQ08 | 2015-02-04 15:52:22 CLU08 | 2015-02-04 15:52:22 CLV08 | 2015-02-04 15:52:22 CLX08 | 2015-02-04 15:52:22 CLZ08 | 2015-02-04 15:52:22 CLF09 | 2015-02-04 15:52:22 CLG09 | 2015-02-04 15:52:22 CLH09 | 2015-02-04 15:52:22 CLJ09 | 2015-02-04 15:52:22 CLK09 | 2015-02-04 15:52:22 CLM09 | 2015-02-04 15:52:22 CLN09 | 2015-02-04 15:52:22 CLQ09 | 2015-02-04 15:52:22 CLU09 | 2015-02-04 15:52:22 CLV09 | 2015-02-04 15:52:22 CLX09 | 2015-02-04 15:52:22 CLZ09 | 2015-02-04 15:52:22 CLF10 | 2015-02-04 15:52:22 CLG10 | 2015-02-04 15:52:22 CLH10 | 2015-02-04 15:52:22 CLJ10 | 2015-02-04 15:52:22 CLK10 | 2015-02-04 15:52:22 CLM10 | 2015-02-04 15:52:22 CLN10 | 2015-02-04 15:52:22 CLQ10 | 2015-02-04 15:52:22 CLU10 | 2015-02-04 15:52:22 CLV10 | 2015-02-04 15:52:22 CLX10 | 2015-02-04 15:52:22 CLZ10 | 2015-02-04 15:52:22 CLF11 | 2015-02-04 15:52:22 CLG11 | 2015-02-04 15:52:22 CLH11 | 2015-02-04 15:52:22 CLJ11 | 2015-02-04 15:52:22 CLK11 | 2015-02-04 15:52:22 CLM11 | 2015-02-04 15:52:22 CLN11 | 2015-02-04 15:52:22 CLQ11 | 2015-02-04 15:52:22 CLU11 | 2015-02-04 15:52:22 CLV11 | 2015-02-04 15:52:22 CLX11 | 2015-02-04 15:52:22 CLZ11 | 2015-02-04 15:52:22 CLF12 | 2015-02-04 15:52:22 CLG12 | 2015-02-04 15:52:22 CLH12 | 2015-02-04 15:52:22 CLJ12 | 2015-02-04 15:52:22 CLK12 | 2015-02-04 15:52:22 CLM12 | 2015-02-04 15:52:22 CLN12 | 2015-02-04 15:52:22 CLQ12 | 2015-02-04 15:52:22 CLU12 | 2015-02-04 15:52:22 CLV12 | 2015-02-04 15:52:22 CLX12 | 2015-02-04 15:52:22 CLZ12 | 2015-02-04 15:52:22 CLF13 | 2015-02-04 15:52:22 CLG13 | 2015-02-04 15:52:22 CLH13 | 2015-02-04 15:52:22 CLJ13 | 2015-02-04 15:52:22 CLK13 | 2015-02-04 15:52:22 CLM13 | 2015-02-04 15:52:22 CLN13 | 2015-02-04 15:52:22 CLQ13 | 2015-02-04 15:52:22 CLU13 | 2015-02-04 15:52:22 CLV13 | 2015-02-04 15:52:22 CLX13 | 2015-02-04 15:52:22 CLZ13 | 2015-02-04 15:52:22 CLF14 | 2015-02-04 15:52:22 CLG14 | 2015-02-04 15:52:22 CLH14 | 2015-02-04 15:52:22 CLJ14 | 2015-02-04 15:52:22 CLK14 | 2015-02-04 15:52:22 CLM14 | 2015-02-04 15:52:22 CLN14 | 2015-02-04 15:52:22 CLQ14 | 2015-02-04 15:52:22 CLU14 | 2015-02-04 15:52:22 CLV14 | 2015-02-04 15:52:22 CLX14 | 2015-02-04 15:52:22 CLZ14 | 2015-02-04 15:52:22 CLF15 | 2015-02-04 15:52:22 CLG15 | 2015-02-04 15:52:22 CLH15 | 2015-02-04 15:52:22 HD Request # 53 | Decompressing data. | 2015-02-04 15:52:22 HD Request # 53 | Receiving Intraday data for F.US.TFEH15 starting at 2015-02-04 15:50:34 | 2015-02-04 15:52:22 HD Request # 53 | Timestamp of first Intraday data file record written: 2015-02-04 15:50:35 | 2015-02-04 15:52:22 Socket (59) | Shutdown and closed. | 2015-02-04 15:52:22 The network socket for historical data has been closed. | 2015-02-04 15:52:22 HD Request # 53 | Received 899 records from 2015-02-04 15:50:34 to 2015-02-04 15:52:21 (107.0 seconds) and wrote 856 records for F.US.TFEH15 | 2015-02-04 15:52:22 Added 1 Time and Sales records to Intraday data file for F.US.TFEH15 after download. | 2015-02-04 15:52:22 HD Request # 53 | Intraday download COMPLETE for F.US.TFEH15. Completion time: 3s. Unique request ID: 56 | 2015-02-04 15:52:22 Removed historical data download ID 56 | 2015-02-04 15:52:22 Real-time Intraday chart data file updates started for F.US.TFEH15 | 2015-02-04 15:52:22 HD Request # 54 | Downloading Intraday chart data for F.US.EPH15 to the file F.US.EPH15.scid. Service: cme | 2015-02-04 15:52:22 HD Request # 54 | Download start Date-Time: 2015-02-04 15:52:18.0 | 2015-02-04 15:52:22 HD Request # 54 | Using server: scdf1.sierracharts.com port 10149 | 2015-02-04 15:52:22 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-02-04 15:52:22 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #32 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #13 has tagged chart #4 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #4 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #4 has tagged chart #32 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #32 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Socket (60) | Connected. | 2015-02-04 15:52:23 HD Request # 54 | Sending historical data logon request message. | 2015-02-04 15:52:23 HD Request # 54 | Requesting Intraday data. Start Date-Time: 2015-02-04 15:52:18. Record interval: 0. Symbol: ESH5 | 2015-02-04 15:52:23 HD Request # 54 | Decompressing data. | 2015-02-04 15:52:23 HD Request # 54 | Receiving Intraday data for F.US.EPH15 starting at 2015-02-04 15:52:18 | 2015-02-04 15:52:23 HD Request # 54 | Timestamp of first Intraday data file record written: 2015-02-04 15:52:18 | 2015-02-04 15:52:23 Socket (60) | Shutdown and closed. | 2015-02-04 15:52:23 The network socket for historical data has been closed. | 2015-02-04 15:52:23 HD Request # 54 | Received 312 records from 2015-02-04 15:52:18 to 2015-02-04 15:52:23 (5.1 seconds) and wrote 284 records for F.US.EPH15 | 2015-02-04 15:52:23 HD Request # 54 | Intraday download COMPLETE for F.US.EPH15. Completion time: 1s. Unique request ID: 57 | 2015-02-04 15:52:23 Removed historical data download ID 57 | 2015-02-04 15:52:23 Real-time Intraday chart data file updates started for F.US.EPH15 | 2015-02-04 15:52:23 HD Request # 55 | Downloading Intraday chart data for F.US.ENQH15 to the file F.US.ENQH15.scid. Service: cme | 2015-02-04 15:52:23 HD Request # 55 | Download start Date-Time: 2015-02-04 15:52:18.0 | 2015-02-04 15:52:23 HD Request # 55 | Using server: scdf2.sierracharts.com port 10149 | 2015-02-04 15:52:23 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-02-04 15:52:23 Chart #1 has tagged chart #24 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #34 has tagged chart #1 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #34 has tagged chart #24 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #1 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Chart #1 has tagged chart #24 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:23 Socket (61) | Connected. | 2015-02-04 15:52:23 HD Request # 55 | Sending historical data logon request message. | 2015-02-04 15:52:23 Chart #24 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:23 HD Request # 55 | Requesting Intraday data. Start Date-Time: 2015-02-04 15:52:18. Record interval: 0. Symbol: NQH5 | 2015-02-04 15:52:24 HD Request # 55 | Decompressing data. | 2015-02-04 15:52:24 HD Request # 55 | Receiving Intraday data for F.US.ENQH15 starting at 2015-02-04 15:52:18 | 2015-02-04 15:52:24 HD Request # 55 | Timestamp of first Intraday data file record written: 2015-02-04 15:52:18 | 2015-02-04 15:52:24 Socket (61) | Shutdown and closed. | 2015-02-04 15:52:24 The network socket for historical data has been closed. | 2015-02-04 15:52:24 HD Request # 55 | Received 118 records from 2015-02-04 15:52:18 to 2015-02-04 15:52:23 (5.1 seconds) and wrote 108 records for F.US.ENQH15 | 2015-02-04 15:52:24 HD Request # 55 | Intraday download COMPLETE for F.US.ENQH15. Completion time: 1s. Unique request ID: 58 | 2015-02-04 15:52:24 Removed historical data download ID 58 | 2015-02-04 15:52:24 Real-time Intraday chart data file updates started for F.US.ENQH15 | 2015-02-04 15:52:24 HD Request # 56 | Downloading Intraday chart data for F.US.YMH15 to the file F.US.YMH15.scid. Service: cbot | 2015-02-04 15:52:24 HD Request # 56 | Download start Date-Time: 2015-02-04 15:52:18.0 | 2015-02-04 15:52:24 HD Request # 56 | Using server: scdf1.sierracharts.com port 10149 | 2015-02-04 15:52:24 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-02-04 15:52:24 Chart #31 has tagged chart #2 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:24 Chart #2 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:24 Chart #2 has tagged chart #16 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:24 Chart #2 has tagged chart #16 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:24 Chart #16 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:24 Socket (62) | Connected. | 2015-02-04 15:52:24 HD Request # 56 | Sending historical data logon request message. | 2015-02-04 15:52:24 HD Request # 56 | Requesting Intraday data. Start Date-Time: 2015-02-04 15:52:18. Record interval: 0. Symbol: YMH5 | 2015-02-04 15:52:24 HD Request # 56 | Decompressing data. | 2015-02-04 15:52:25 HD Request # 56 | Receiving Intraday data for F.US.YMH15 starting at 2015-02-04 15:52:18 | 2015-02-04 15:52:25 HD Request # 56 | Timestamp of first Intraday data file record written: 2015-02-04 15:52:18 | 2015-02-04 15:52:25 Socket (62) | Shutdown and closed. | 2015-02-04 15:52:25 The network socket for historical data has been closed. | 2015-02-04 15:52:25 HD Request # 56 | Received 64 records from 2015-02-04 15:52:18 to 2015-02-04 15:52:24 (6.0 seconds) and wrote 52 records for F.US.YMH15 | 2015-02-04 15:52:25 HD Request # 56 | Intraday download COMPLETE for F.US.YMH15. Completion time: 0s. Unique request ID: 59 | 2015-02-04 15:52:25 Removed historical data download ID 59 | 2015-02-04 15:52:25 Real-time Intraday chart data file updates started for F.US.YMH15 | 2015-02-04 15:52:25 HD Request # 57 | Downloading Intraday chart data for F.US.CLEH15 to the file F.US.CLEH15.scid. Service: nymex | 2015-02-04 15:52:25 HD Request # 57 | Download start Date-Time: 2015-02-04 15:52:18.0 | 2015-02-04 15:52:25 HD Request # 57 | Using server: scdf2.sierracharts.com port 10149 | 2015-02-04 15:52:25 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-02-04 15:52:25 Chart #3 has tagged chart #15 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:25 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:25 Chart #33 has tagged chart #3 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:25 Chart #3 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:25 Socket (63) | Connected. | 2015-02-04 15:52:25 HD Request # 57 | Sending historical data logon request message. | 2015-02-04 15:52:25 Chart #3 has tagged chart #15 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:25 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:25 HD Request # 57 | Requesting Intraday data. Start Date-Time: 2015-02-04 15:52:18. Record interval: 0. Symbol: CLH5 | 2015-02-04 15:52:25 HD Request # 57 | Decompressing data. | 2015-02-04 15:52:25 HD Request # 57 | Receiving Intraday data for F.US.CLEH15 starting at 2015-02-04 15:52:18 | 2015-02-04 15:52:25 HD Request # 57 | Timestamp of first Intraday data file record written: 2015-02-04 15:52:22 | 2015-02-04 15:52:25 Socket (63) | Shutdown and closed. | 2015-02-04 15:52:25 The network socket for historical data has been closed. | 2015-02-04 15:52:25 HD Request # 57 | Received 30 records from 2015-02-04 15:52:18 to 2015-02-04 15:52:24 (6.0 seconds) and wrote 29 records for F.US.CLEH15 | 2015-02-04 15:52:25 HD Request # 57 | Intraday download COMPLETE for F.US.CLEH15. Completion time: 0s. Unique request ID: 60 | 2015-02-04 15:52:25 Removed historical data download ID 60 | 2015-02-04 15:52:25 Real-time Intraday chart data file updates started for F.US.CLEH15 | 2015-02-04 15:52:25 HD Request # 58 | Downloading Intraday chart data for F.US.GCEJ15 to the file F.US.GCEJ15.scid. Service: comex | 2015-02-04 15:52:25 HD Request # 58 | Download start Date-Time: 2015-02-04 15:52:16.0 | 2015-02-04 15:52:25 HD Request # 58 | Using server: scdf1.sierracharts.com port 10149 | 2015-02-04 15:52:25 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-02-04 15:52:25 Chart #30 has tagged chart #29 for full recalculation. Chartbook: EMINI.cht | 2015-02-04 15:52:25 Chart #29 is performing a full recalculation because it has been tagged. Chartbook: EMINI.cht | 2015-02-04 15:52:25 Socket (64) | Connected. | 2015-02-04 15:52:25 HD Request # 58 | Sending historical data logon request message. | 2015-02-04 15:52:25 HD Request # 58 | Requesting Intraday data. Start Date-Time: 2015-02-04 15:52:16. Record interval: 0. Symbol: GCJ5 | 2015-02-04 15:52:26 HD Request # 58 | Decompressing data. | 2015-02-04 15:52:26 HD Request # 58 | Receiving Intraday data for F.US.GCEJ15 starting at 2015-02-04 15:52:16 | 2015-02-04 15:52:26 HD Request # 58 | Timestamp of first Intraday data file record written: 2015-02-04 15:52:19 | 2015-02-04 15:52:26 Socket (64) | Shutdown and closed. | 2015-02-04 15:52:26 The network socket for historical data has been closed. | 2015-02-04 15:52:26 HD Request # 58 | Received 22 records from 2015-02-04 15:52:16 to 2015-02-04 15:52:24 (8.0 seconds) and wrote 15 records for F.US.GCEJ15 | 2015-02-04 15:52:26 HD Request # 58 | Intraday download COMPLETE for F.US.GCEJ15. Completion time: 1s. Unique request ID: 61 | 2015-02-04 15:52:26 Removed historical data download ID 61 | 2015-02-04 15:52:26 Real-time Intraday chart data file updates started for F.US.GCEJ15 | 2015-02-04 15:52:26 |
