Date/Time: Thu, 11 Jun 2026 19:04:27 +0000
TuS
View Count: 2502
[2013-05-22 18:22:11]
User39772 - Posts: 311
I use IQFeed Forex data feed and when i open a TuS window there is no TuS visible.
[2013-05-23 05:20:01]
Make sure you do not have any Volume Filter settings set for the Time and Sales window. And go into the Time and Sales Settings window and enable the option to display the Bid and Ask records to see if you see data.
[2013-05-23 13:01:02]
Ok I enabled Bid/ask records and have no volume filter. No data visible in TuS.
[2013-05-23 16:47:48]
Please let us know the symbol.
[2013-05-23 18:13:16]
EURUSD.FXCM and AUDUSD.FXCM, all Forex symbols via IQFeed.
[2013-05-24 00:06:33]
It works for us. Please see the attached image.
For further help contact IQ Feed and make certain you are receiving data for this symbol.
imageEURUSD_FXCM.png / V - Attached On 2013-05-24 00:06:12 UTC - Size: 9.26 KB - 911 views
[2013-05-24 12:29:14]
Of course I have the data feed available and receive date (see chart attached) - otherwise I would not ask :-).
attachmentEURUSDFXCM.snag - Attached On 2013-05-24 12:29:02 UTC - Size: 40.02 KB - 995 views
[2013-05-24 17:34:42]
We cannot view that image.
Go to a chart for the symbol. Open the Time and Sales window and place it over the chart and then select Edit >> Screen Images >> Upload Chart with Overlays. Post a link to the image here.
[2013-05-24 18:33:22]
http://www.sierrachart.com/image.php?l=1369420342619.png
[2013-05-24 18:51:46]
The problem is the chart is open from a remote instance of Sierra Chart. You will need to use the Use Non Chart Data from Remote Instances option:
http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#NonChartDataRemoteInstances
