Date/Time: Mon, 29 Apr 2024 18:14:54 +0000
FXCM and data
View Count: 1865
[2015-01-16 12:37:57] |
ripsdips - Posts: 143 |
Any potential interruption with data from SC due to FXCM capital issue?
[2015-01-16 14:01:58] |
Trint - Posts: 112 |
Was about to ask the same thing.... apparently they are going to make an announcement in the next hour or so.
[2015-01-16 14:03:34] |
who is? FXCM or SC?
[2015-01-16 14:05:32] |
FXCM
[2015-01-16 14:33:34] |
What announcement?
[2015-01-16 14:37:41] |
FXCM and its potential insolvency. The question that Im posing is about the SC/FXCM feed and whether it gets affected.
[2015-01-16 14:52:42] |
It certainly would if FXCM closes down operations but as long as they continue to operate we do not believe that it would be affected. If they were to close down operations, then we will immediately work on an alternative. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-16 16:25:44] |
it looks like fxcm will live on.
[2015-01-22 02:43:55] |
Rainer - Posts: 108 |
"FXCM dead?" not if but when' ... Alternative = IG Markets > soon available on/with SC [ IG Index ]
[2015-01-22 03:22:32] |
We are definitely underway now with IG market integration. Should not take long to get done. Hopefully within three weeks.
[2015-01-22 09:12:30] |
great. Thanks
[2015-01-22 18:05:48] |
The change has been partially implemented. We just need to do some additional testing before fully implementing this.
