Date/Time: Sat, 18 May 2024 12:40:25 +0000
TPO Profile Chart
View Count: 1208
[2015-01-13 20:12:21] |
User888876 - Posts: 33 |
Good day, I chose in studies TPO profile chart, but it shows only yesterday's chart and backwards. It does not presents today's chart. What should I do to actual data to my chart? |
[2015-01-13 20:16:19] |
When you remove the TPO Profile Chart study from the chart, do you see data for the current day up to the current moment in time? If not, refer to the first part of this page for help with this kind of problem. https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-14 19:10:46] |
When I removed TPO Profile chart, I can see candle sticks showing actual price. Today 14th Jan I can see only TPO Profile Chart from yesterday 13.01.2015
[2015-01-14 19:13:10] |
Provide an image of the chart without the TPO Profile Chart study. And provide an image of the chart with the TPO Profile Chart study. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Please do not follow any other method to attach an image of a chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-15 20:16:09] |
http://www.sierrachart.com/image.php?l=142135269572.png http://www.sierrachart.com/image.php?l=1421352861934.png First chart is just with candlesticks and reali time data, second link is with TPOProfile chart ending on 14th January. Today is 15th January, and no chart real time is shown. |
[2015-01-15 23:22:05] |
The Date-Times you see on the timescale, are the starting time of the TPO Profiles. The reason you see the day before is because you have reversed Session Times: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php It is fine to use reversed Session Times, but the start of the day will be in the prior day. We see no indication that the TPO Profile Chart is not updating in real-time. If it is not, refer to help topic 3.3: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-22 15:11:42] |
good day, I tries to download data to SC from IB for different stocks. For some it worked without problems, some did not download showing "waiting to Download Historical Data" What I can do to fix it?
[2015-09-22 15:26:52] |
Are these US stocks or from another exchange? At the time you have this problem, provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog We also need to know one of the symbols of the charts that shows "Waiting to download". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-22 15:28:22
[2015-09-23 15:39:13] |
http://www.sierrachart.com/image.php?l=1443022635962.png see above the chart |
[2015-09-23 18:34:37] |
Follow the instructions here to use the Sierra Chart Historical Data Service: https://www.sierrachart.com/index.php?page=doc/IB.php#UsingSierraChartHistoricalData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
