Date/Time: Tue, 16 Jun 2026 03:16:05 +0000
Stochastics cutting off on bottom of pane
View Count: 1305
[2014-12-24 09:32:06]
peaceland - Posts: 95
I am not able to contain small stochastic settings inside the pane. The lines are cutting off. Please advise, and Happy Holidays! Thank you! Like 2,2,2 or 4,1,2 they cut off. You can't see the point at which they turn or connect bottom of pane. It just "disappears"...
[2014-12-24 11:14:21]
Select Chart >> Reset Scales.
[2014-12-24 11:17:15]
Nope, doesn't work...
[2014-12-24 19:55:52]
[2014-12-24 23:26:59]
May have discovered what it is. When using some indicators, you guys force us to use Line 1 and Line 2, and I didn't realize you can select "hidden", so I was making it black and putting it at the bottom at ZERO. And I think it was covering up the bottom of the indicator line. Sorry for the trouble.
