Date/Time: Sat, 04 May 2024 09:36:04 +0000
NISS-NYSE and TICK-NYSE opening values
View Count: 2011
[2014-12-12 05:16:24] |
User31050 - Posts: 3 |
The NYSE advance-decline and TICK opened negative today (9:30am EST, 11 Dec 14). That seemed strange given where the overall market opened, and also inconsistent with other data providers. Is there a reason for this, or was there a data error? Thank you. |
[2014-12-12 08:39:27] |
We are checking on this.
[2014-12-12 18:09:14] |
When you look at NISS-NYSE, it is also negative at the open of -55 and goes to -828. So a TICK reading of -200 is not out of line. We have no reason to believe the calculations are incorrect. How the calculations are performed are documented here: Sierra Chart Market Statistics: Calculations and Algorithms Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
