Date/Time: Tue, 07 May 2024 20:34:41 +0000
Downloading intraday data
View Count: 4908
[2013-05-20 09:25:42] |
User95208 - Posts: 26 |
Hello, I have just started a free trial yesterday, mainly for Market Profile and FootPrint charts. I did manage to find my way through in creating charts or using studies. However, I am a little lost as far as downloading historical intraday data for symbols from IQFeed. The footprint needs bid/ask/volume on a tick-by-tick basis (120 days in IQFEED), while I also need a 1 minute history (5-10 years in IQFEED) for market profile analysis on 30 minutes, daily and weekly buckets. I want to download historical tick-by-tick and 1 minute history. I used the chart and data settings and adjusted the number of intaday days to download the historical 1 minute and tick data. I tried the download in non-trading hours. I also tried "delete and download data" . I could only download the daily data. The SC did not download any historical tick and 1 minute data for any instrument. Please also advise if it is possible to import the IQFEED symbol list (which is missing for Forex) and steps to download all historical (tick, 1 minute and daily) for a specified set of symbol lists. Thanks, |
[2013-05-20 09:34:39] |
So basically what you are saying is that your Intraday charts are blank? We see no reason why there would be such a problem. We have not heard of this with IQ Feed. What is the symbol of one of the charts? Do you see a message that says "Downloading Historical Data" on an Intraday chart that you open? You can add symbols through Global Symbol Settings: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php To work with lists of symbols, please see: http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html Refer to the Associated Watch List section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-20 09:35:59
[2013-05-20 09:40:15] |
Thanks for the quick response! Any symbol: examples are EURUSD.ABBA, GBPUSD.ABBA.... |
[2013-05-20 09:45:25] |
After opening an Intraday chart for one of those symbols, please post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-20 10:00:53] |
A few strange behaviour related to IQFEED, which is unusual. Please note that I do no have a Level II subscription as I do not needit for my trading. Massive gap in the chart, where intraday is loaded or just a few bars starting yesterday. Missing data http://www.sierrachart.com/image.php?l=1369043875519.png http://www.sierrachart.com/image.php?l=136904393348.png no backfills http://www.sierrachart.com/image.php?l=1369043969550.png |
[2013-05-20 10:05:37] |
For help with these, please refer to help topic 7 here: http://www.sierrachart.com/index.php?l=doc/helpdetails7.html If you need more help please contact IQ Feed as these appear to be an IQ Feed problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-20 10:06:22
[2013-05-20 10:11:26] |
I will give it a try....
[2013-05-20 12:09:48] |
could you please advise how to stop this error from appearing..I think there should be an option to disable this warning: IQFEED Level 2 error: Account not authorised to receive Level II.... |
[2013-05-20 16:08:02] |
We have implemented a patch for this in the latest release. Please update by selecting Help >> Download Prerelease. The reason it occurs is because the IQ Feed software is sending it continuously. The problem is not from Sierra Chart.We do not know why IQ Feed cannot promptly resolve this. They should be able to take care of this promptly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-20 16:20:59
[2013-05-20 16:30:52] |
Thanks. I will update this patch. As a partner in service, perhaps, you may want to send your recommendation to IQFeed to fix this continuous warning. BTW, IQFeed states that Historical intraday backfill is internal to SC and not IQFeed. They see a clean account status on their side. |
[2013-05-20 16:43:46] |
We have told them. They plan to correct it, but we do not know why it takes such a long time for a simple change to be released. The historical Intraday data is downloaded from IQ Feed. Re-download the data again by selecting Edit >> Delete All Data And Download. Or right-click on the chart before the missing data and select Delete Data and Download. If it is still missing, it is clearly an issue on IQ Feed side. Also please refer to help topic 7.3 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-20 16:44:01
[2013-05-20 22:10:28] |
I keep getting blank data or gaps in the data. BTW, when I click back-fill or download historical daily or intraday 1 minute or 120 days of tick history in AmiBroker or Ninja Trader, the data sets are downloaded completely without any problem. Strangely, the problem seems specific to SC. If other applications could download the data without a problem, why should that be problematic in SC? If I want to download the full suite of tick (120 days) and 1 minute data, how does one accomplish that together please? Thanks |
[2013-05-20 23:04:34] |
There could not be any problems in Sierra Chart with data downloading. The problem must be external. We do not have any other reports of this and we are not noticing a problem ourselves. We did a download using one of the symbols you have shown in one of the charts. Here is the log: HD Request # 5 - Downloading Intraday chart data for AUDUSD.ABBA to the file AUDUSD.ABBA.temp.scid. Service: dtn | 2013-05-20 18:58:39 HD Request # 5 - Requesting Minute data beginning at 2012-04-15 18:58:39 US Eastern Time. | 2013-05-20 18:58:39 Symbol Error: AUDUSD.ABBA is unknown, unavailable, or improperly formatted. | 2013-05-20 18:58:39 HD Request # 5 - Receiving Intraday Minute data for AUDUSD.ABBA | 2013-05-20 18:58:40 HD Request # 5 - Receiving Intraday data for AUDUSD.ABBA starting at 2012-04-15 18:59:00 | 2013-05-20 18:58:40 HD Request # 5 - Timestamp of first Intraday data file record written: 2012-04-15 18:59:00 | 2013-05-20 18:58:40 HD Request # 5 - Received 411717 records from 2012-04-15 18:59:00 to 2013-05-20 18:58:00 (400.0 days) and wrote 411717 records for AUDUSD.ABBA | 2013-05-20 18:58:53 HD Request # 6 - Downloading Intraday chart data for AUDUSD.ABBA to the file AUDUSD.ABBA.temp.scid. Service: dtn | 2013-05-20 18:58:53 HD Request # 6 - Requesting Tick data beginning at 2012-04-15 18:58:53 US Eastern Time. | 2013-05-20 18:58:53 HD Request # 6 - Receiving historical Intraday Tick data for AUDUSD.ABBA | 2013-05-20 18:58:54 HD Request # 6 - Receiving Intraday data for AUDUSD.ABBA starting at 2013-01-06 17:00:02 | 2013-05-20 18:58:54 HD Request # 6 - Timestamp of first Intraday data file record written: 2013-01-06 17:00:02 | 2013-05-20 18:58:54 HD Request # 6 - Received 14240652 records from 2013-01-06 17:00:02 to 2013-05-20 19:01:10 (134.0 days) and wrote 14240652 records for AUDUSD.ABBA | 2013-05-20 19:01:28 HD Request # 6 - Copying downloaded Intraday chart data from AUDUSD.ABBA.temp.scid to AUDUSD.ABBA.scid | 2013-05-20 19:01:28 HD Request # 6 - Intraday download COMPLETE for AUDUSD.ABBA | 2013-05-20 19:01:28 Real-time intraday chart data file updates started for AUDUSD.ABBA | 2013-05-20 19:01:28 Here is the chart image: http://www.sierrachart.com/image.php?l=1369091004285.png Please go to one of the chart you have a problem with and re-download the data with Edit >> Delete All Data and Download. It may take a while because there is a lot of data to download. When it is done, let us know what symbol it is and then post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-20 23:05:37
[2013-05-21 06:47:00] |
I have managed to get the data for some instruments. I will continue with the rest before I start evaluating. The critical question is this: I want to download both the historical tick data for 120 days and all available intraday day, which is a 1 minute history. What should be the setting on Global Settings >> Data/Trade Service Settings...Should the download historical intraday data as be in ticks or minutes ? I think it should be both ticks and minutes as one would want both of them. The ticks are for footprints and the minutes for everything else. Perhaps, this needs to be looked into closely.... Date Time Of Last Edit: 2013-05-21 06:48:14
[2013-05-21 06:58:28] |
It needs to be set to Ticks and Sierra Chart properly manage this and download both types of data.
[2013-05-21 08:37:48] |
Thank you for the reply. I have downloaded G10 majors and crosses data. My first observation of the backfill is apparent missing data mostly in 2013...Almost all G10 Major pairs ran into blank screen from Jan to early May...Interestingly, this is the period where back-fill history is available for both 1 minute and tick. I wonder if there is a hidden conflict when it attempts to download both of them. I know the SC would say there is no problem. This is not a criticism but I think it is worth investigating the source code of the SC a little bit where the minutes and ticks are handled and sorted. This is an example of a cross FX image. I am in the process of checking the rest of the Major FX crosses history before I proceeding with the rest of the download. Thanks. http://www.sierrachart.com/image.php?l=1369124839765.png |
[2013-05-21 09:14:11] |
We have provided specific instructions to help identify the problem. There is no hidden conflict . Please follow our previous instructions: Please go to one of the chart you have a problem with and re-download the data with Edit >> Delete All Data and Download. It may take a while because there is a lot of data to download. When it is done, let us know what symbol it is and then post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-21 09:29:22] |
We opened a new chart for the same symbol as the image that you posted. And there were no problems receiving and processing both the Tick and Minute data: http://www.sierrachart.com/image.php?l=136912842158.png Quite honestly, we are puzzled by the problem that you have. There is no one else reporting anything like this. Sierra Chart works fine when it comes to processing this data. We know that. There is some other problem going on in your case. Make sure you are running the latest IQ Feed software and if you are running any firewall, Antivirus, anti-malware, anti-spyware software, disable those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-21 09:40:50
[2013-05-21 09:44:58] |
Thanks. I am aware of your Edit >> Del instructions..I have done that a few dozen times in the last couple of days...I using this method for almost all IQFeed instruments. I do not see any point in supplying you the full list. You may check out IQFEED FX (.abba, .fxcm, .comp) as starters. Please note that I never experienced this massive data download problem with any other software, Ninja Trader, Amibroker to name a few. Download has been pretty smooth with the IQFeed interface every where except SC. While your support is excellent, I am sorry that your response to download related issues does not surprise me at all. Every instrument fails the download a few times before it becomes alright...I am at it for more than 48 hours and still unable to download a full history of even a couple of dozen instruments, let alone a few hundred instruments. Probably I need to spend the entire free trial period day and night in trying to download a couple of dozen instruments. It is a luxury, which I cannot afford as I have trade and make a living! It will be a real shame if I give this up without even testing out the SC features. The attached is just one example. There were several....I am not attaching them for reasons of time. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=464 Date Time Of Last Edit: 2013-05-21 09:52:18
Capture.JPG / V - Attached On 2013-05-21 09:33:25 UTC - Size: 171.58 KB - 710 views |
[2013-05-21 09:55:42] |
Why are you not providing the Message Log and are being critical.? How do you expect us to help you, if you do not provide us the Message Log which will to help us diagnose the problem. We can see from the image, the download is failing and the Message Log will indicate why. The download failure is not due to Sierra Chart, but some other reason. Once again here are the instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log If you do not want to provide us the Log file, then there is no reason to post anything further. We asked for the Message Log in post 4, 13 and post 17 . This post also. From what we can tell, the downloads are very slow and timing out. This is going to usually be the result of antivirus, anti-spyware, or third-party firewall software. Try disabling those. Once again, please do provide us the Message Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-21 21:07:52
[2013-05-21 10:39:29] |
There is no reason for not providing the log. I am sorry you take my comments as critical but they are not! If you wish, you may disable my free trial and delete the account. Please do let me now if you take this route. Thanks I have exceptions added in AV/Malware, while native FW on win7 64 bit permits outbound connection for all internet facing applications. This setup functions well for all charting systems since 2008. While one of them may be disabled briefly for a few minutes for troubleshooting, please note that I will not be able to disable them permanently. Recent log file after a few attempts to download CHFJPY data failed. The data is still incomplete. Log file IQ Feed: Disconnected from Level 2 port. | 2013-05-21 06:39:05 c_StreamBuffer::Remove: Trying to remove more data (40 bytes) than the buffer contains (0 bytes). This indicates there is a programming error. Not downloading historical Intraday data for EURUSD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for GBPUSD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for NZDUSD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for DX.X because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDCAD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDCHF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDJPY.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDNOK.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDSEK.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDZAR.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDSGD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for AUDCAD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for AUDCHF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for AUDJPY.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for AUDNZD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for CADCHF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for CADJPY.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for CHFJPY.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURAUD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURCAD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURCHF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURGBP.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURJPY.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURNZD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURNOK.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURSEK.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for GBPAUD.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for GBPCHF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for GBPJPY.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for GBPNZD.FXCM, because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for NZDCAD.FXCM because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for NZDCHF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for NZDJPY.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURCZK.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURHUF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURPLN.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURZAR.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for EURTRY.FXCM because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDBRL.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDCZK.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDHUF.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDILS.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 Not downloading historical Intraday data for USDPLN.ABBA because it is in a real-time data recording state. | 2013-05-21 06:54:20 HD Request # 48 - Downloading Intraday chart data for USDCHF.ABBA to the file USDCHF.ABBA.temp.scid. Service: dtn | 2013-05-21 07:02:37 Compressing file: C:\SierraChart\Data\USDCHF.ABBA.temp.scid. This may take a while... | 2013-05-21 07:02:37 HD Request # 48 - Starting date and time: 2013-01-23 20:59:59 | 2013-05-21 07:02:37 HD Request # 48 - Requesting Minute data beginning at 2013-01-23 15:59:59 US Eastern Time. | 2013-05-21 07:02:37 HD Request # 48 - Receiving Intraday Minute data for USDCHF.ABBA | 2013-05-21 07:02:38 HD Request # 48 - Receiving Intraday data for USDCHF.ABBA starting at 2013-01-23 21:00:00 | 2013-05-21 07:02:38 HD Request # 48 - Timestamp of first Intraday data file record written: 2013-01-23 21:00:00 | 2013-05-21 07:02:38 HD Request # 48 - Received 120168 records from 2013-01-23 21:00:00 to 2013-05-21 07:02:00 (117.4 days) and wrote 120168 records for USDCHF.ABBA | 2013-05-21 07:02:41 HD Request # 49 - Downloading Intraday chart data for USDCHF.ABBA to the file USDCHF.ABBA.temp.scid. Service: dtn | 2013-05-21 07:02:41 HD Request # 49 - Starting date and time: 2013-01-23 20:59:59 | 2013-05-21 07:02:41 HD Request # 51 - Starting date and time: 2013-03-27 08:59:59 | 2013-05-21 07:21:18 HD Request # 51 - Requesting Tick data beginning at 2013-03-27 04:59:59 US Eastern Time. | 2013-05-21 07:21:18 HD Request # 51 - Receiving historical Intraday Tick data for USDSEK.ABBA | 2013-05-21 07:21:18 HD Request # 51 - Receiving Intraday data for USDSEK.ABBA starting at 2013-03-27 08:59:59 | 2013-05-21 07:21:18 HD Request # 51 - Timestamp of first Intraday data file record written: 2013-03-27 08:59:59 | 2013-05-21 07:21:18 HD Request # 51 - Received 5807220 records from 2013-03-27 08:59:59 to 2013-05-21 07:22:25 (54.9 days) and wrote 5807220 records for USDSEK.ABBA | 2013-05-21 07:23:57 HD Request # 51 - Copying downloaded Intraday chart data from USDSEK.ABBA.temp.scid to USDSEK.ABBA.scid | 2013-05-21 07:23:57 HD Request # 51 - Timestamp of first Intraday data file record written: 2013-03-27 08:59:59 | 2013-05-21 07:23:57 HD Request # 51 - Intraday download COMPLETE for USDSEK.ABBA | 2013-05-21 07:26:29 Real-time intraday chart data file updates started for USDSEK.ABBA | 2013-05-21 07:26:29 HD Request # 53 - Downloading Intraday chart data for AUDCHF.ABBA to the file AUDCHF.ABBA.temp.scid. Service: dtn | 2013-05-21 07:47:34 HD Request # 53 - Starting date and time: 2013-01-23 08:59:59 | 2013-05-21 07:47:34 HD Request # 53 - Requesting Tick data beginning at 2013-01-23 03:59:59 US Eastern Time. | 2013-05-21 07:47:34 HD Request # 53 - Receiving historical Intraday Tick data for AUDCHF.ABBA | 2013-05-21 07:47:34 HD Request # 53 - Receiving Intraday data for AUDCHF.ABBA starting at 2013-01-23 08:59:59 | 2013-05-21 07:47:34 HD Request # 53 - Timestamp of first Intraday data file record written: 2013-01-23 08:59:59 | 2013-05-21 07:47:34 HD Request # 53 - Error downloading historical Intraday data for AUDCHF.ABBA. The download timed out. | 2013-05-21 07:52:08 HD Request # 53 - Received 3444737 records from 2013-01-23 08:59:59 to 2013-02-07 11:45:22 (15.1 days) and wrote 3444737 records for AUDCHF.ABBA | 2013-05-21 07:52:08 HD Request # 53 - Copying downloaded Intraday chart data from AUDCHF.ABBA.temp.scid to AUDCHF.ABBA.scid | 2013-05-21 07:52:08 HD Request # 53 - Timestamp of first Intraday data file record written: 2013-01-23 08:59:59 | 2013-05-21 07:52:08 HD Request # 53 - Intraday download COMPLETE for AUDCHF.ABBA | 2013-05-21 07:53:42 Real-time intraday chart data file updates started for AUDCHF.ABBA | 2013-05-21 07:53:42 HD Request # 58 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 09:07:52 Compressing file: C:\SierraChart\Data\CHFJPY.ABBA.temp.scid. This may take a while... | 2013-05-21 09:07:52 HD Request # 58 - Starting date and time: 2010-04-09 19:59:00 | 2013-05-21 09:07:52 HD Request # 58 - Requesting Minute data beginning at 2010-04-09 15:59:00 US Eastern Time. | 2013-05-21 09:07:52 HD Request # 58 - Warning: Receiving data for a different historical Intraday data request. Data ignored. Request ID received: 57 | 2013-05-21 09:07:52 HD Request # 58 - Receiving Intraday Minute data for CHFJPY.ABBA | 2013-05-21 09:13:41 HD Request # 58 - Receiving Intraday data for CHFJPY.ABBA starting at 2010-04-09 19:59:00 | 2013-05-21 09:13:41 HD Request # 58 - Timestamp of first Intraday data file record written: 2010-04-09 19:59:00 | 2013-05-21 09:13:41 HD Request # 58 - Received 1168074 records from 2010-04-09 19:59:00 to 2013-05-21 09:14:00 (3.1 years) and wrote 1168074 records for CHFJPY.ABBA | 2013-05-21 09:14:17 HD Request # 59 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 09:14:17 HD Request # 59 - Starting date and time: 2010-04-09 19:59:00 | 2013-05-21 09:14:17 HD Request # 59 - Requesting Tick data beginning at 2010-04-09 15:59:00 US Eastern Time. | 2013-05-21 09:14:17 HD Request # 59 - Receiving historical Intraday Tick data for CHFJPY.ABBA | 2013-05-21 09:14:17 HD Request # 59 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-01-06 22:00:01 | 2013-05-21 09:14:17 HD Request # 59 - Timestamp of first Intraday data file record written: 2013-01-06 22:00:01 | 2013-05-21 09:14:18 HD Request # 59 - Error downloading historical Intraday data for CHFJPY.ABBA. The download timed out. | 2013-05-21 09:18:54 HD Request # 59 - Received 3450555 records from 2013-01-06 22:00:01 to 2013-01-16 05:43:11 (9.3 days) and wrote 3450555 records for CHFJPY.ABBA | 2013-05-21 09:18:54 HD Request # 59 - Copying downloaded Intraday chart data from CHFJPY.ABBA.temp.scid to CHFJPY.ABBA.scid | 2013-05-21 09:18:54 HD Request # 59 - Timestamp of first Intraday data file record written: 2010-04-09 19:59:00 | 2013-05-21 09:18:54 HD Request # 59 - Intraday download COMPLETE for CHFJPY.ABBA | 2013-05-21 09:20:59 Real-time intraday chart data file updates started for CHFJPY.ABBA | 2013-05-21 09:20:59 HD Request # 60 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 09:22:45 Compressing file: C:\SierraChart\Data\CHFJPY.ABBA.temp.scid. This may take a while... | 2013-05-21 09:22:45 HD Request # 60 - Starting date and time: 2012-07-24 15:59:00 | 2013-05-21 09:22:45 HD Request # 60 - Requesting Minute data beginning at 2012-07-24 11:59:00 US Eastern Time. | 2013-05-21 09:22:45 HD Request # 60 - Warning: Receiving data for a different historical Intraday data request. Data ignored. Request ID received: 59 | 2013-05-21 09:22:45 HD Request # 60 - Receiving Intraday Minute data for CHFJPY.ABBA | 2013-05-21 09:30:14 HD Request # 60 - Receiving Intraday data for CHFJPY.ABBA starting at 2012-07-24 15:59:00 | 2013-05-21 09:30:14 HD Request # 60 - Timestamp of first Intraday data file record written: 2012-07-24 15:59:00 | 2013-05-21 09:30:14 HD Request # 60 - Received 309139 records from 2012-07-24 15:59:00 to 2013-05-21 09:30:00 (300.7 days) and wrote 309139 records for CHFJPY.ABBA | 2013-05-21 09:30:24 HD Request # 61 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 09:30:24 HD Request # 61 - Starting date and time: 2012-07-24 15:59:00 | 2013-05-21 09:30:24 HD Request # 61 - Requesting Tick data beginning at 2012-07-24 11:59:00 US Eastern Time. | 2013-05-21 09:30:24 HD Request # 61 - Receiving historical Intraday Tick data for CHFJPY.ABBA | 2013-05-21 09:30:25 HD Request # 61 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-01-06 22:00:01 | 2013-05-21 09:30:25 HD Request # 61 - Timestamp of first Intraday data file record written: 2013-01-06 22:00:01 | 2013-05-21 09:30:25 HD Request # 61 - Error downloading historical Intraday data for CHFJPY.ABBA. The download timed out. | 2013-05-21 09:34:57 HD Request # 61 - Received 3317693 records from 2013-01-06 22:00:01 to 2013-01-15 22:36:55 (9.0 days) and wrote 3317693 records for CHFJPY.ABBA | 2013-05-21 09:34:57 HD Request # 61 - Copying downloaded Intraday chart data from CHFJPY.ABBA.temp.scid to CHFJPY.ABBA.scid | 2013-05-21 09:34:57 HD Request # 61 - Timestamp of first Intraday data file record written: 2012-07-24 15:59:00 | 2013-05-21 09:34:57 HD Request # 61 - Intraday download COMPLETE for CHFJPY.ABBA | 2013-05-21 09:36:31 Real-time intraday chart data file updates started for CHFJPY.ABBA | 2013-05-21 09:36:31 HD Request # 62 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 09:47:37 Compressing file: C:\SierraChart\Data\CHFJPY.ABBA.temp.scid. This may take a while... | 2013-05-21 09:47:37 HD Request # 62 - Starting date and time: 2013-01-15 17:59:59 | 2013-05-21 09:47:37 HD Request # 62 - Requesting Minute data beginning at 2013-01-15 12:59:59 US Eastern Time. | 2013-05-21 09:47:37 HD Request # 62 - Warning: Receiving data for a different historical Intraday data request. Data ignored. Request ID received: 61 | 2013-05-21 09:47:38 HD Request # 62 - Receiving Intraday Minute data for CHFJPY.ABBA | 2013-05-21 09:55:15 HD Request # 62 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-01-15 18:00:00 | 2013-05-21 09:55:15 HD Request # 62 - Timestamp of first Intraday data file record written: 2013-01-15 18:00:00 | 2013-05-21 09:55:15 HD Request # 62 - Received 129162 records from 2013-01-15 18:00:00 to 2013-05-21 09:55:00 (125.7 days) and wrote 129162 records for CHFJPY.ABBA | 2013-05-21 09:55:23 HD Request # 63 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 09:55:23 HD Request # 63 - Starting date and time: 2013-01-15 17:59:59 | 2013-05-21 09:55:23 HD Request # 63 - Requesting Tick data beginning at 2013-01-15 12:59:59 US Eastern Time. | 2013-05-21 09:55:23 HD Request # 63 - Receiving historical Intraday Tick data for CHFJPY.ABBA | 2013-05-21 09:55:23 HD Request # 63 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-01-15 17:59:59 | 2013-05-21 09:55:23 HD Request # 63 - Timestamp of first Intraday data file record written: 2013-01-15 17:59:59 | 2013-05-21 09:55:23 HD Request # 63 - Error downloading historical Intraday data for CHFJPY.ABBA. The download timed out. | 2013-05-21 10:00:07 HD Request # 63 - Received 3662160 records from 2013-01-15 17:59:59 to 2013-01-24 09:40:25 (8.7 days) and wrote 3662160 records for CHFJPY.ABBA | 2013-05-21 10:00:07 HD Request # 63 - Copying downloaded Intraday chart data from CHFJPY.ABBA.temp.scid to CHFJPY.ABBA.scid | 2013-05-21 10:00:07 HD Request # 63 - Timestamp of first Intraday data file record written: 2013-01-15 17:59:59 | 2013-05-21 10:00:07 HD Request # 63 - Intraday download COMPLETE for CHFJPY.ABBA | 2013-05-21 10:01:44 Real-time intraday chart data file updates started for CHFJPY.ABBA | 2013-05-21 10:01:44 http://www.sierrachart.com/image.php?l=1369132426318.png |
[2013-05-21 10:41:51] |
BTW, I have provided the log files directly from the system a few times (through send for analysis).....
[2013-05-21 11:09:20] |
Another log file and incomplete CHFJPY HD Request # 64 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 10:42:54 Compressing file: C:\SierraChart\Data\CHFJPY.ABBA.temp.scid. This may take a while... | 2013-05-21 10:42:54 HD Request # 64 - Starting date and time: 2013-01-23 23:59:59 | 2013-05-21 10:42:54 HD Request # 64 - Requesting Minute data beginning at 2013-01-23 18:59:59 US Eastern Time. | 2013-05-21 10:42:54 HD Request # 64 - Warning: Receiving data for a different historical Intraday data request. Data ignored. Request ID received: 63 | 2013-05-21 10:42:54 HD Request # 64 - Receiving Intraday Minute data for CHFJPY.ABBA | 2013-05-21 10:49:58 HD Request # 64 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-01-24 00:00:00 | 2013-05-21 10:49:58 HD Request # 64 - Timestamp of first Intraday data file record written: 2013-01-24 00:00:00 | 2013-05-21 10:49:58 HD Request # 64 - Received 120218 records from 2013-01-24 00:00:00 to 2013-05-21 10:50:00 (117.5 days) and wrote 120218 records for CHFJPY.ABBA | 2013-05-21 10:50:02 HD Request # 65 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 10:50:02 HD Request # 65 - Starting date and time: 2013-01-23 23:59:59 | 2013-05-21 10:50:02 HD Request # 65 - Requesting Tick data beginning at 2013-01-23 18:59:59 US Eastern Time. | 2013-05-21 10:50:02 HD Request # 65 - Receiving historical Intraday Tick data for CHFJPY.ABBA | 2013-05-21 10:50:03 HD Request # 65 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-01-23 23:59:59 | 2013-05-21 10:50:03 HD Request # 65 - Timestamp of first Intraday data file record written: 2013-01-23 23:59:59 | 2013-05-21 10:50:03 HD Request # 65 - Error downloading historical Intraday data for CHFJPY.ABBA. The download timed out. | 2013-05-21 10:57:32 HD Request # 65 - Received 9264850 records from 2013-01-23 23:59:59 to 2013-02-18 05:09:59 (25.2 days) and wrote 9264850 records for CHFJPY.ABBA | 2013-05-21 10:57:32 HD Request # 65 - Copying downloaded Intraday chart data from CHFJPY.ABBA.temp.scid to CHFJPY.ABBA.scid | 2013-05-21 10:57:32 HD Request # 65 - Timestamp of first Intraday data file record written: 2013-01-23 23:59:59 | 2013-05-21 10:57:32 HD Request # 65 - Intraday download COMPLETE for CHFJPY.ABBA | 2013-05-21 11:01:36 Real-time intraday chart data file updates started for CHFJPY.ABBA | 2013-05-21 11:01:36 http://www.sierrachart.com/image.php?l=1369134553663.png |
[2013-05-21 11:36:17] |
Uploaded an image to the server. Request ID: 3 | 2013-05-21 11:09:10 HD Request # 66 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 11:09:48 Compressing file: C:\SierraChart\Data\CHFJPY.ABBA.temp.scid. This may take a while... | 2013-05-21 11:09:48 HD Request # 66 - Starting date and time: 2013-02-15 07:59:59 | 2013-05-21 11:09:48 HD Request # 66 - Requesting Minute data beginning at 2013-02-15 02:59:59 US Eastern Time. | 2013-05-21 11:09:48 HD Request # 66 - Warning: Receiving data for a different historical Intraday data request. Data ignored. Request ID received: 65 | 2013-05-21 11:09:49 HD Request # 66 - Receiving Intraday Minute data for CHFJPY.ABBA | 2013-05-21 11:16:40 HD Request # 66 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-02-15 08:00:00 | 2013-05-21 11:16:40 HD Request # 66 - Timestamp of first Intraday data file record written: 2013-02-15 08:00:00 | 2013-05-21 11:16:40 HD Request # 66 - Received 96725 records from 2013-02-15 08:00:00 to 2013-05-21 11:16:00 (95.1 days) and wrote 96725 records for CHFJPY.ABBA | 2013-05-21 11:16:45 HD Request # 67 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 11:16:45 HD Request # 67 - Starting date and time: 2013-02-15 07:59:59 | 2013-05-21 11:16:45 HD Request # 67 - Requesting Tick data beginning at 2013-02-15 02:59:59 US Eastern Time. | 2013-05-21 11:16:45 HD Request # 67 - Receiving historical Intraday Tick data for CHFJPY.ABBA | 2013-05-21 11:16:46 HD Request # 67 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-02-15 07:59:59 | 2013-05-21 11:16:46 HD Request # 67 - Timestamp of first Intraday data file record written: 2013-02-15 07:59:59 | 2013-05-21 11:16:46 HD Request # 67 - Error downloading historical Intraday data for CHFJPY.ABBA. The download timed out. | 2013-05-21 11:21:34 HD Request # 67 - Received 3650194 records from 2013-02-15 07:59:59 to 2013-02-26 08:47:32 (11.0 days) and wrote 3650194 records for CHFJPY.ABBA | 2013-05-21 11:21:34 HD Request # 67 - Copying downloaded Intraday chart data from CHFJPY.ABBA.temp.scid to CHFJPY.ABBA.scid | 2013-05-21 11:21:34 HD Request # 67 - Timestamp of first Intraday data file record written: 2013-02-15 07:59:59 | 2013-05-21 11:21:34 HD Request # 67 - Intraday download COMPLETE for CHFJPY.ABBA | 2013-05-21 11:23:09 Real-time intraday chart data file updates started for CHFJPY.ABBA | 2013-05-21 11:23:09 http://www.sierrachart.com/image.php?l=1369136155446.png |
[2013-05-21 12:19:45] |
Please look at this log for CHFJPY.ABBA....It received the missing data from 26-2-13 to 21-5-13 for 84.2 days and then tick data for 6.7 days from 26-2-13 to 4-3-13 for 6.7 days...but does not plot the data for these period on the chart....this log is produced when the SC was started but the chart was not opened...the chart was opened after the log was captured... HD Request # 19 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 12:02:34 Compressing file: C:\SierraChart\Data\CHFJPY.ABBA.temp.scid. This may take a while... | 2013-05-21 12:02:34 HD Request # 19 - Starting date and time: 2013-02-26 06:59:59 | 2013-05-21 12:02:34 HD Request # 19 - Requesting Minute data beginning at 2013-02-26 01:59:59 US Eastern Time. | 2013-05-21 12:02:34 HD Request # 19 - Receiving Intraday Minute data for CHFJPY.ABBA | 2013-05-21 12:02:35 HD Request # 19 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-02-26 07:00:00 | 2013-05-21 12:02:35 HD Request # 19 - Timestamp of first Intraday data file record written: 2013-02-26 07:00:00 | 2013-05-21 12:02:35 HD Request # 19 - Received 86752 records from 2013-02-26 07:00:00 to 2013-05-21 12:02:00 (84.2 days) and wrote 86752 records for CHFJPY.ABBA | 2013-05-21 12:02:37 HD Request # 20 - Downloading Intraday chart data for CHFJPY.ABBA to the file CHFJPY.ABBA.temp.scid. Service: dtn | 2013-05-21 12:02:37 HD Request # 20 - Starting date and time: 2013-02-26 06:59:59 | 2013-05-21 12:02:37 HD Request # 20 - Requesting Tick data beginning at 2013-02-26 01:59:59 US Eastern Time. | 2013-05-21 12:02:37 HD Request # 20 - Receiving historical Intraday Tick data for CHFJPY.ABBA | 2013-05-21 12:02:38 HD Request # 20 - Receiving Intraday data for CHFJPY.ABBA starting at 2013-02-26 06:59:59 | 2013-05-21 12:02:38 HD Request # 20 - Timestamp of first Intraday data file record written: 2013-02-26 06:59:59 | 2013-05-21 12:02:38 HD Request # 20 - Error downloading historical Intraday data for CHFJPY.ABBA. The download timed out. | 2013-05-21 12:06:55 HD Request # 20 - Received 2793228 records from 2013-02-26 06:59:59 to 2013-03-04 22:46:55 (6.7 days) and wrote 2793228 records for CHFJPY.ABBA | 2013-05-21 12:06:55 HD Request # 20 - Copying downloaded Intraday chart data from CHFJPY.ABBA.temp.scid to CHFJPY.ABBA.scid | 2013-05-21 12:06:55 HD Request # 20 - Timestamp of first Intraday data file record written: 2013-02-26 06:59:59 | 2013-05-21 12:06:55 HD Request # 20 - Intraday download COMPLETE for CHFJPY.ABBA | 2013-05-21 12:08:11 Starting updates for: CHFJPY.ABBA | 2013-05-21 12:08:11 Real-time intraday chart data file updates started for CHFJPY.ABBA | 2013-05-21 12:08:11 http://www.sierrachart.com/image.php?l=1369138774541.png (I had full data...now blank in 2013) http://www.sierrachart.com/image.php?l=1369139005247.png http://www.sierrachart.com/image.php?l=1369139234462.png (I had full data after a few downloads..the chart shows missing data in 2013)... Most of the instruments, where I had downloaded the data with a few retries per instrument shows a missing data for 2013 intraday.... Date Time Of Last Edit: 2013-05-21 12:29:22
