Date/Time: Sun, 28 Apr 2024 14:31:28 +0000
No output after building a custom DLL
View Count: 904
[2014-12-11 03:28:41] |
jaschoi - Posts: 2 |
Hi, I am new to Sierra chart and i am trying to build a custom DLL, however i cannot find the output DLL in the default location C:\SierraChart\Data\ Here is the build message: -- Starting build of Custom Studies Source files: HighVAP.cpp. -- 19:50:19 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\HighVAP.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\HighVAP.dll" -- End of Build -- 19:50:20 Please advice, thanks |
[2014-12-11 18:23:02] |
Usually what this means is that tthere is a missing file with the installation of the CPP compiler. Delete this folder from your system: C:\SierraChart\CPPCompiler Install the compiler again through Analysis >> Build Custom Studies DLL >> Install Compiler. Let us know if you still have a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-11 18:24:05
[2014-12-12 04:02:38] |
Re-installing the compiler solved the problem. Thanks a lot
