Date/Time: Sun, 28 Apr 2024 19:51:33 +0000
User Questions
View Count: 914
[2014-12-08 18:01:44] |
Sierra Chart - Max - Posts: 5597 |
Greetings, GC is not freeing up memory when a chartbook is closed. I just opened up my Echo 6 Major Pairs chart and a custom chart that had 17 pairs each with 100 days worth of history. After closing the bigger chartbook, GC is still using far more memory than the Echo 6 Major Pairs chartbook uses. It is really impacting the performance of my machine and is a huge issue. When I close a chartbook, it should free up the memory it previously used. It will only clear after a reboot. It is very unreasonable to need to reboot every time we open a big chartbook. Please see attached screenshots. Brenden Greetings, It would be awesome if we could make the horizontal lines on the Reward / Risk took wider than we currently can now. The widest we can go now is only 25 pixels: Honestly, I'd like the option to have more of a full line so that I can match my targets to previous support/resistance and see that line moving forward into the future. Sierra Chart Support Date Time Of Last Edit: 2014-12-08 18:03:20
after closing big chartbook.png / V - Attached On 2014-12-08 18:01:30 UTC - Size: 535.49 KB - 334 views after reboot.png / V - Attached On 2014-12-08 18:03:13 UTC - Size: 549.91 KB - 363 views |
[2014-12-08 18:27:00] |
What you are describing with memory use is 100% a system issue on your side. We have prepared documentation for this here: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.31 https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.25 We will see if we can increase the Marker Type >> Size for the Risk/Reward tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
