Date/Time: Mon, 29 Apr 2024 07:26:25 +0000
Oil chart problem
View Count: 914
[2014-11-29 10:28:25] |
User57111 - Posts: 25 |
Can you tell me why I have two different weekly chart of OIL?
CLF15 [CV] Weekly #4 2014-11-29 11_25_39.379.png / V - Attached On 2014-11-29 10:27:00 UTC - Size: 144.62 KB - 296 views CLF15 [CV] Weekly #1 2014-11-29 11_25_47.836.png / V - Attached On 2014-11-29 10:27:04 UTC - Size: 144.53 KB - 307 views |
[2014-11-30 21:53:36] |
We can tell you are being affected by the Windows number formatting bug. Refer to this post here about it: Critical Number Formatting Bug in Windows | Post: 44857 You need to update Sierra Chart to the latest version by following these instructions: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate After the update, go to one of those charts and fully re-download the data for all contracts of the chart, following the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-30 21:57:10
